Issue: CONFIG_ACCEL_CALIBRATE is NOT generated for PCA20035
I would like to read accelerometer value from orientation_detector_calibrate()  (in asset_tracker/src/orientation_detector/orientation_detector.c).
But from main.c (in asset_tracker/src/main.c). it has a dependency on "CONFIG_ACCEL_CALIBRATE", which is defined like below.
#ifdef CONFIG_ACCEL_USE_SIM
#define FLIP_INPUT CONFIG_FLIP_INPUT
#define CALIBRATION_INPUT -1
#else
#define FLIP_INPUT -1
#ifdef CONFIG_ACCEL_CALIBRATE
#define CALIBRATION_INPUT CONFIG_CALIBRATION_INPUT
#else
#endif /* CONFIG_ACCEL_CALIBRATE */
#endif /* CONFIG_ACCEL_USE_SIM */
After some debugging, I got to know that, these CONFIG_ macro values should be automatically generated and must be in "ncs\nrf\applications\asset_tracker\build\zephyr\include\generated\autoconf.h"
But unfortunately, I didn't see them in "autoconf.h" for the PCA20035 thingy91    (west build -b nrf9160_pca20035ns) device.
Please guide me the correct way to get generate them in order to access the orientation detector
Thank you.
    Those defines are related to a accelerometer that were used on prototypes of the thingy:91, and is not used for the finalized version, were you needed to calibrate it regularly.
    Thank you for letting us know about this, I'll make sure that the developers remove unused defines/kconfig entries.
    Håkon
  • No problem. Even I figured it out, how to read/calibrate the accelerometer values.
    Could you please let me know, how can I interact with nRF52840 from nRF9160 on Thingy91 (PCA20035) device.
    Basically, I would like to know the interface between the nRF52840 ad nRf9160 on the  (Thingy91) PCA20035 device.
    Thank you.
    The nRF52840 is made to serve the nRF9160 in terms of UART/USB connections, and to be able to program the nRF9160 device over UART as well (using mcuboot)
    The physical interface between the two nRF's are a set of GPIOs, and they are used for UART communication (RXD, TXD, CTS, RTS). What specifically are you looking for?
    Håkon
    Thanks for your reply.
    I am specifically looking for RSSI implementation using the BLE module on nrf52840 SOC. How to obtain the RSSI values for asset tracker application on Nordic Thingy:91(nRF9160 SiP)?
    I want to perform a BLE scan based on the timeout values and sort the result by RSSI implementation with nRF52840 for PCA20035 and pass the BLE_SCANLIST_ENTRIES over UART.
    Looking forward to your help. Please guide me the correct way and let me know how to proceed to start the RSSI measurement.
    Thanks
     In order to use the BLE part of the nRF52840 SoC on the thingy:91 board, you'll have to reprogram the nRF52840 with hci_uart, then run lte_ble_gateway on nRF9160 device, but; this will cause the USB-UART bridge to be overwritten. We do not have an example that combines the usb_uart + hci_uart sample, unfortunately; but I have provided this feedback to the thingy:91 team so that they are aware of this scenario.
    Håkon
