How can I send Data from nRF9160 to external module using UART?
Hi all
I am able to do start loopback using the example of UART.
But how to send data to external modules ( like ESP32) via UART from nRF9160.
I tried this example Thread And also This its working fine and compile also but not send data on UART.
and little beat confused about UART pin configuration How to do that I also use overlay file but actually
what is the pin for RX and TX not understand?
  • Hi
    Ok P0.10 and P0.11 already used in first UART.
    Can you tell me what are pins safe for second UART like?
    And for 2nd Query
    Here is my code
    * Copyright (c) 2012-2014 Wind River Systems, Inc.
    #include <zephyr.h>
    #include <misc/printk.h>
    #include <uart.h>
    #include <string.h>
    #include <stdlib.h>
    static u8_t uart_buf[1024];
    static K_FIFO_DEFINE(fifo_uart_tx_data);
    static K_FIFO_DEFINE(fifo_uart_rx_data);
    struct uart_data_t {
    	void  *fifo_reserved;
    	u8_t    data[1024];
    	u16_t   len;
    void uart_sendCOM(struct device *x,  u8_t *Cont)
             u16_t len = strlen(Cont);
             uart_fifo_fill(x, Cont,len );
             uart_irq_tx_enable(x);
    void uart_cb(struct device *x)
    	uart_irq_update(x);
    	int data_length = 0;
    	if (uart_irq_rx_ready(x)) {
                    data_length = uart_fifo_read(x, uart_buf, sizeof(uart_buf));
    		uart_buf[data_length] = 0;
    	printk("%s", uart_buf);
           	if (uart_irq_tx_ready(x)) {
            	struct uart_data_t *buf =
    			k_fifo_get(&fifo_uart_tx_data, K_NO_WAIT);
    		u16_t written = 0;
    		/* Nothing in the FIFO, nothing to send */
    		if (!buf) {
    			uart_irq_tx_disable(x);
    			return;
    		while (buf->len > written) {
    			written += uart_fifo_fill(x,
    						  &buf->data[written],
    						  buf->len - written);
    		while (!uart_irq_tx_complete(x)) {
    			/* Wait for the last byte to get
    			 * shifted out of the module
    		if (k_fifo_is_empty(&fifo_uart_tx_data)) {
    		k_free(buf);
    void main(void)
            struct device *uart1 = device_get_binding("UART_1");
            uart_irq_rx_enable(uart1);
            uart_irq_callback_set(uart1, uart_cb);
            k_sleep(3000);
            uart_sendCOM(uart1,"AT+CMGF=1\r\n");
            k_sleep(3000);
            uart_sendCOM(uart1,"AT+CMGS=\"xxxxxxxxxx\"\r\n"); //Mobile no. 9xxxxxxxxx
            k_sleep(3000);
            uart_sendCOM(uart1,"\rCall and SMS both\r\n");
            k_sleep(3000);
            uart_sendCOM(uart1,"\x1A");
            k_sleep(3000);
            while(1);
    So in This code
    in this function on [ uart_buf ] received both TX and RX string data
    how can i received only RX data.
    Right now i am receiving like A,T,+,C,M,G,F,=,1,\r,\n and O,K also
    I only need O, K so that is an issue.
     All unused GPIOs are safe to use, but on the DK, there are some pins that overlap with others, and are not routed out on the pin list.
    Here's the documentation on GPIOs:
    https://infocenter.nordicsemi.com/topic/ug_nrf91_dk/UG/nrf91_DK/if_connector.html?cp=2_0_4_3_5
    Try to use P0.12 and P0.13 for the next uart.
     Are you certain that the external module isn't echo'ing back the command with the status? you can use standard string functions to delimit the string. I would recommend reading up on the standard functions provided in string.h:
    https://en.wikibooks.org/wiki/C_Programming/String_manipulation
    Håkon
