How can I send Data from nRF9160 to external module using UART?
Hi all
I am able to do start loopback using the example of UART.
But how to send data to external modules ( like ESP32) via UART from nRF9160.
I tried this example Thread And also This its working fine and compile also but not send data on UART.
and little beat confused about UART pin configuration How to do that I also use overlay file but actually
what is the pin for RX and TX not understand?
    What pins are you using, and which UARTx are you using? Not all pins are routed to the pin-header on the DK, as they are dedicated for other connections, so a safe choice is to use P0.10 and P0.11 for instance.
    Can you share your source code and .overlay file?
    Håkon
  • Hi
    Thanks for your Valuable Replay now I am able to send data to the external module.
    There are 2 things I changed [1] rename file nrf9160_pca10090.overlay to nrf9160_pca10090ns.overlay
    and [2] also changes pin no. what you suggest like P0.10 as TX and P0.11 as RX so That's Work Thanks
    I need a suggestion for 2 things
    1. When I receive read data in this uart_fifo_read(x, uart_buf, sizeof(uart_buf)) function and in uart_buf received both data
    like A, T,\r,\n and then OK so how can I get only received data like ok.
    2. And How can I use uart2 for another second module and what are pins of it
    Thanks Again
    Jaydip Kavaiya
    I do not understand. Can you elaborate on what the issue is? Do you want to do string compare on your received data?
    Its the exact same procedure, where you define uart2 in your overlay file, and set the wanted GPIOs.
    Here's a thread where the configs are posted:
    https://devzone.nordicsemi.com/f/nordic-q-a/45166/nrf9160-at_client-sample-default-uart-port/177737#177737
    Håkon
  • Hi Hakon Alseth
    Thanks for your kind response
    [1] In Which function I get only RX response string (Data)? like I send AT get in only OK Not AT + OK both.
    Right now I am getting both string TX and RX in [ uart_buf ] function I want only RX string Data
    how can I neglect TX data in this array?
    [2] I meant to say how can I use both UART for 2 external modules like 1st is GSM and 2nd is ESP32
    Right now I am able to use UART1 in P0.10 and P0.11 for GSM
    and Now How can I use the second UART for ESP32 so what are pins and which UART I use?
    Because I use Both UART same time.
    You need to use one UART for each device. The nRF9160 has 3 UARTs, so you can enable another one.
    Its the same procedure as enabling other UART.
    Note: CONFIG_BSD_LIBRARY_TRACE_ENABLED should be set to "n" if you plan to use UART1 for the application.
    I do not understand. Are you reusing the same buffer for transmitting and receiving? Could you post your code?
    Håkon
