Hi, I need to white list the AWS URL used by the nRF9160 dev kit asset tracker example, could someone tell me what it is?
Thanks
Thanks
If I'm not mistaken. The Asset Tracker uses AWS IoT Core via MQTT, this uses a dynamic range of IP addresses and has no one specific IP address.
I know it's dynamic, what I need to know is the URL not an IP address.
Probably this from the aws_fota sample:
config MQTT_BROKER_HOSTNAME string "AWS IoT MQTT broker hostname" default "a2n7tk1kp18wix-ats.iot.us-east-1.amazonaws.com" help Default is set to be the NRF Cloud MQTT broker
Also found deep inside the nrf_cloud sub-system
Thanks for that, its some URL!
I presume Vodafone can open up their firewalls for amazonaws.com and it will allow this through!
I doubt that, if you are on the same trial contract that I am on with Vodafone. I had to get creative to get around the whitelisting of 2 IP addresses only.
