A multiperipheral connection to a central, all with custom nordic devices (nRF52840) has been stablished. Comunication and connection work just fine, but after a synchronization method via BLE was added to the system (broadcast timer transmitted from central to all peripherals) the initial stage of the connection generates the 0x3E error.
It connects and inmediately disconnects again with this error. If at least one peripheral is connected, and a new peripheral wants to connect again, this error does not appear. Only in the first connection to a peripheral.
I don't believe this is a HW problem because the error appears when the synchronization method was added!
Is it possible that some parameter needs to be adjusted on central side?
Thanks in advance for your attention.
