Thingy:91 functional in Germany (Karlsruhe) ? Strange Msg. from nrfcloud
Hello Forum,
I got a Thingy:91 today and of course I wanted to test it immediatelly), but I wonder:
Is the nrfcloud.message simply because of no LTE-NB1 network / roaming or did I get incompatible Hardware?
The rfcloud shows me a "certificate update" required?
Thanks for a short feedback, Jo
This is my Hardware:
/resized-image/__size/320x240/__key/support-attachments/beef5d1b77644c448dabff31668f3a47-02138044164c4096bf495b448bc6ccf3/20191106_5F00_172444.jpg
    I checked with the production data, and your device should have certificates preloaded.
    have you powered on your thingy:91 device, and has it been able to contact the cloud prior to adding it on nrfcloud.com?
    With the newer certificates scheme in nrfcloud.com, the certificates are not associated until a device tries to use them. So in order for you to add your specific thingy:91 to the cloud, it has to have tried to connect prior to this.
    Håkon
  • Hi Håkon ,
    yes, finally I checkd it via LTE-Monitor and it seems the iBasis SIM can not see any NB1/M1 net here, but Telekom-SIMs work (at least with a modem from an other manufacturer).
    Maybe the message with the certificate is a little bit missleading and the blinking signals of the Thingy:91 need a little bit more explanation. In any case: the nrf9160 is really a very smart and promissing solution.
    Best regards, Jo
