Flash can't not erase and write when a table in code
hi
i use the example flashwriting in nRF5_SDK_15.3.0_59ac345, i set a table at 0xfd000:
// ProgramSection alignment="4" keep="Yes" load="yes" name=".tabletest" address_symbol="__tabletest_start" end_symbol="__tabletest_end"  start="0x000fd000" size="0x1000"
uint8_t const testtable[] __attribute__((section(".tabletest"))) __attribute__((used))={0xff,0xff,0xff,0xff};
//the test code in main.c
    uint32_t err_code;
    err_code = app_timer_init();
    err_code = clock_config();
    flash_page_init();
    nrf_nvmc_write_word((uint32_t) &testtable,0);             //wirte 0xfd000 fail
    nrf_nvmc_page_erase((uint32_t) &testtable);               //erase 0xfd000 fail
but the if don't load the table 1st, it can work well
// ProgramSection alignment="4" keep="Yes" load="No" name=".tabletest" address_symbol="__tabletest_start" end_symbol="__tabletest_end"  start="0x000fd000" size="0x1000"
    uint32_t err_code;
    flash_page_init();
    nrf_nvmc_write_word((uint32_t) &testtable,0);             //wirte OK
    nrf_nvmc_page_erase((uint32_t) &testtable);               //erase Ok
so, why it's can't write and erase when set
load="yes" ?
  • Hi
    There are a few details I need from you.
    • What device are you seeing this issue on? nRF52832 or nRF52840?
    • How do you see that the write and erase fail? Is there any error code that might help us see what's causing this?
    • Can you try to explain what exactly you want to achieve with this?
    It seems to me like using the fstorage example instead might be easier, as that is a more "user-friendly" example.
    Simon
  • HI Simonr,
    I tested it in nrf52840 , your can find the code and some picture in attached file;
    I have one project, there are some config data tables, and the data can be modified by app, but when i try to modify the data, i found that the the data had no any change, so i try test in flashwrite sample , but it still the same result.  I had checked the ACL register ,but all of ALL register is 0, Is there any other register do protect  the code size ?
    flashwrite.zip
  • Hi
    Sorry about the delayed reply, but I was out of the office last Friday.
     I'm sorry, but can you try to specify what it is you want to achieve with your project, as I'm having some trouble understanding what exactly you want to do. I need some more information regarding the goal of your project in order to help you.
    Simon
    I'm sorry, the description is not clear:I mean is there any other registers like ACL-Access Control Lists,Because I had checked NRF_ACL registers is set to 0x00, not block flash read or write; but flash page in 0xfd000 is still can not be write and erased when
    load="yes"(see the flash_placement.xml)
     Can you help to check my code in attachments is correct?
  • Hi
    I can't see anything wrong right off the bat with your main file. Have you made any other changes than adding the .testtable and the write/erase commands to the main.c file? Please double check that you've configured the flash_placement.xml file correctly as well. This is very well described by a SEGGER employee in this case.
    Simon
