snip
What kind of error code do you get from debugging? Could you please add your code as well?
Thanks!
Øyvind
Based on the debug information you have given, and your project, the error seems to come from line 180 (0xB4) in COMP-adxl372_spi.c which gives error_code 17 (0x11). This equals NRF_ERROR_BUSY.
ret = nrfx_spim_xfer(&spi, &xfer_desc, 0); APP_ERROR_CHECK(ret);
* @brief Function for starting the SPI data transfer.
* Additional options are provided using the @c flags parameter:
* - @ref NRFX_SPIM_FLAG_TX_POSTINC and @ref NRFX_SPIM_FLAG_RX_POSTINC<span></span>:
* Post-incrementation of buffer addresses. Supported only by SPIM.
* - @ref NRFX_SPIM_FLAG_HOLD_XFER<span></span>: Driver is not starting the transfer. Use this
* flag if the transfer is triggered externally by PPI. Supported only by SPIM. Use
* @ref nrfx_spim_start_task_get to get the address of the start task.
* - @ref NRFX_SPIM_FLAG_NO_XFER_EVT_HANDLER<span></span>: No user event handler after transfer
* completion. This also means no interrupt at the end of the transfer. Supported only by SPIM.
* If @ref NRFX_SPIM_FLAG_NO_XFER_EVT_HANDLER is used, the driver does not set the instance into
* busy state, so you must ensure that the next transfers are set up when SPIM is not active.
* @ref nrfx_spim_end_event_get function can be used to detect end of transfer. Option can be used
* together with @ref NRFX_SPIM_FLAG_REPEATED_XFER to prepare a sequence of SPI transfers
* without interruptions.
* - @ref NRFX_SPIM_FLAG_REPEATED_XFER<span></span>: Prepare for repeated transfers. You can set
* up a number of transfers that will be triggered externally (for example by PPI). An example is
* a TXRX transfer with the options @ref NRFX_SPIM_FLAG_RX_POSTINC,
* @ref NRFX_SPIM_FLAG_NO_XFER_EVT_HANDLER, and @ref NRFX_SPIM_FLAG_REPEATED_XFER. After the
* transfer is set up, a set of transfers can be triggered by PPI that will read, for example,
* the same register of an external component and put it into a RAM buffer without any interrupts.
* @ref nrfx_spim_end_event_get can be used to get the address of the END event, which can be
* used to count the number of transfers. If @ref NRFX_SPIM_FLAG_REPEATED_XFER is used,
* the driver does not set the instance into busy state, so you must ensure that the next
* transfers are set up when SPIM is not active. Supported only by SPIM.
* @note Peripherals using EasyDMA (including SPIM) require the transfer buffers
* to be placed in the Data RAM region. If this condition is not met,
* this function will fail with the error code NRFX_ERROR_INVALID_ADDR.
* @param p_instance Pointer to the driver instance structure.
* @param p_xfer_desc Pointer to the transfer descriptor.
* @param flags Transfer options (0 for default settings).
* @retval NRFX_SUCCESS If the procedure was successful.
* @retval NRFX_ERROR_BUSY If the driver is not ready for a new transfer.
* @retval NRFX_ERROR_NOT_SUPPORTED If the provided parameters are not supported.
* @retval NRFX_ERROR_INVALID_ADDR If the provided buffers are not placed in the Data
* RAM region.
nrfx_err_t nrfx_spim_xfer(nrfx_spim_t const * const p_instance,
nrfx_spim_xfer_desc_t const * p_xfer_desc,
uint32_t flags);
thanks, I found the problem...
can we remove or private this thread now please? I'd prefer the code wasn't shared publicly
