BLE_GAP_EVT_DISCONNECTED Reason 0x2A
Hi,I need your help.
I use NRF51822QFAA, SDK nRF51_SDK_9.0.0 and iPhone 11 ( IOS 13.2)
I use a project is ble_app_ancs_c at nRF51_SDK_9.0.0\examples\ble_peripheral\ble_app_ancs_c\pca10028\s110\arm4
I modified the following content:
#define MIN_CONN_INTERVAL MSEC_TO_UNITS(500, UNIT_1_25_MS) /**< Minimum acceptable connection interval (0.5 seconds). */
#define MAX_CONN_INTERVAL MSEC_TO_UNITS(1000, UNIT_1_25_MS) /**< Maximum acceptable connection interval (1 second). */
#define SLAVE_LATENCY 0 /**< Slave latency. */
#define CONN_SUP_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS) /**< Connection supervisory time-out (4 seconds). */
after modified:
#define MIN_CONN_INTERVAL MSEC_TO_UNITS(220, UNIT_1_25_MS) /**< Minimum acceptable connection interval (0.5 seconds). */
#define MAX_CONN_INTERVAL MSEC_TO_UNITS(280, UNIT_1_25_MS) /**< Maximum acceptable connection interval (1 second). */
#define SLAVE_LATENCY 4 /**< Slave latency. */
#define CONN_SUP_TIMEOUT MSEC_TO_UNITS(6000, UNIT_10_MS) /**< Connection supervisory time-out (4 seconds). */
The problem is that the connection to the phone is often broken, the reason is 0x2A
Parents Reply
    I have reproduced this issue and collected a sniffer trace. Looking at it, I see that the peer (iPhone) is initiating new LL control procedures before the previous one has completed, which is violating the Bluetooth specification. Therefore the nRF disconnect with disconnect reason 0x2A (BLE_HCI_DIFFERENT_TRANSACTION_COLLISION). This is an issue on the iPhone and should be solved there.
    We have seen these issues a few times before, and therefore have added workaround in recent SoftDevice versions (starting with 5.x.x), but there are no SoftDevice versions for nRF51 with this workaround implemented. nor do we plan to make any new nRF51 SoftDevices. So unfortunately this means that you have to wait for Apple to fix the bug.
