Configuration error at "NODE_SETUP_CONFIG_COMPOSITION_GET" (inspired by light_switch)
I have successfully managed to both provision and configure the simple:_on_of_client.
but i'm having troubles configuring the simple_on_off server. I really have no idea how to fix the issue, but what seems to be the problem is getting a response from the server node. all this happens at the intial step (in the switch case).
Server output:
<t:          0>, main.c,  191, ----- BLE Mesh Light Switch Server Demo -----
<t:      13242>, main.c,  171, Initializing and adding models
<t:      13244>, simple_on_off_server.c,  137, MODEL INIT SUCCESS
<t:      17997>, mesh_app_utils.c,   65, Device UUID (raw): ABA35353C189664FB261427FA6ACB866
<t:      18000>, mesh_app_utils.c,   70, Device UUID : 5353A3AB-89C1-4F66-B261-427FA6ACB866
<t:    1125039>, main.c,  151, Successfully provisioned
<t:    1125044>, main.c,  162, Node Address: 0x0102
provisioner output:
<t:     828781>, provisioner_helper.c,  303, Scanning For Unprovisioned Devices
<t:     828818>, main.c,  109, Flash write complete
<t:     829891>, provisioner_helper.c,  138, UUID : ABA35353C189664FB261427FA6ACB866
<t:     829894>, provisioner_helper.c,  142, ^RSSI: -66
<t:     829896>, provisioner_helper.c,  147, ^URI Hash: 74F97940
<t:     829901>, provisioner_helper.c,  153, URI hash matched. Provisioning ...
<t:     837008>, provisioner_helper.c,  274, Provisioning link established
<t:     915600>, provisioner_helper.c,  269, Static authentication data provided
<t:    1054423>, provisioner_helper.c,  207, Provisioning completed received
<t:    1054426>, provisioner_helper.c,  212, Adding device address, and device keys
<t:    1054431>, provisioner_helper.c,  229, Addr: 0x0102 addr_handle: 1 netkey_handle: 0 devkey_handle: 3
<t:    1058004>, provisioner_helper.c,  166, Local provisioning link closed: prov_state: 2  remaining retries: 2
<t:    1058008>, main.c,  298, Provisioning successful
<t:    1058011>, provisioner_helper.c,  196, Provisioning complete. Node addr: 0x0102 elements: 1
<t:    1058015>, node_setup.c,  699, Configuring Node: 0x0102
<t:    1058018>, node_setup.c,  592, Config client setup: devkey_handle:3 addr_handle:1
<t:    1058022>, node_setup.c,  325, SERVER about to be configured
<t:    1058024>, node_setup.c,  354, Getting composition data
<t:    1058035>, node_setup.c,  356, status in NODE_SETUP_CONFIG_COMPOSITION_GET is: 0
<t:    1058038>, node_setup.c,  358, exiting NODE_SETUP_CONFIG_COMPOSITION_GET
<t:    1058074>, main.c,  109, Flash write complete
<t:    1058108>, main.c,  109, Flash write complete
<t:    1140794>, main.c,  329, Node 0x0100 alive with 0 active fault(s), RSSI: -63
<t:    1143383>, main.c,  329, Node 0x0100 alive with 0 active fault(s), RSSI: -58
<t:    1468648>, main.c,  329, Node 0x0100 alive with 0 active fault(s), RSSI: -64
<t:    1471110>, main.c,  329, Node 0x0100 alive with 0 active fault(s), RSSI: -64
<t:    1796645>, main.c,  329, Node 0x0100 alive with 0 active fault(s), RSSI: -59
<t:    1799119>, main.c,  329, Node 0x0100 alive with 0 active fault(s), RSSI: -59
<t:    2124352>, main.c,  329, Node 0x0100 alive with 0 active fault(s), RSSI: -61
<t:    2126786>, main.c,  329, Node 0x0100 alive with 0 active fault(s), RSSI: -61
<t:    2451865>, main.c,  329, Node 0x0100 alive with 0 active fault(s), RSSI: -65
<t:    2454435>, main.c,  329, Node 0x0100 alive with 0 active fault(s), RSSI: -65
<t:    2779514>, main.c,  329, Node 0x0100 alive with 0 active fault(s), RSSI: -61
<t:    2782278>, main.c,  329, Node 0x0100 alive with 0 active fault(s), RSSI: -61
<t:    3024114>, main.c,  350, Config client event
<t:    3024116>, node_setup.c,  640, Acknowledged message status not received
<t:    3024119>, node_setup.c,  644, Retry ...
The node_setup.c is modified to support the simple_on_off server/client, by only using one address, instead of the ODD EVEN method. But i doubt that matters, since the error already happens at NODE_SETUP_CONFIG_COMPOSITION_GET
node_setup.c:
/* Copyright (c) 2010 - 2019, Nordic Semiconductor ASA
 * All rights reserved.
 * list of conditions and the following disclaimer.
#include <stdint.h>
#include <stdbool.h>
#include <string.h>
#include <stdarg.h>
#include "nrf_mesh_utils.h"
#include "device_state_manager.h"
#include "timer_scheduler.h"
#include "config_client.h"
#include "config_server.h"
#include "access_config.h"
#include "generic_level_server.h"
#include "generic_level_client.h"
#include "generic_onoff_server.h"
#include "generic_onoff_client.h"
#include "health_common.h"
#include "provisioner_helper.h"
#include "node_setup.h"
#include "example_common.h"
#include "example_network_config.h"
#include "light_switch_example_common.h"
#include "mesh_app_utils.h"
#include "log.h"
#include "nrf_mesh_assert.h"
/* USER_NOTE: Add more steps here is you want to customize the nodes further. */
/* Node setup steps */
typedef enum
    NODE_SETUP_IDLE,
    NODE_SETUP_CONFIG_COMPOSITION_GET,
    NODE_SETUP_CONFIG_NETWORK_TRANSMIT,
    NODE_SETUP_CONFIG_APPKEY_ADD,
    NODE_SETUP_CONFIG_APPKEY_BIND_HEALTH,
    NODE_SETUP_CONFIG_APPKEY_BIND_ONOFF_SERVER,
    NODE_SETUP_CONFIG_APPKEY_BIND_ONOFF_CLIENT,
    NODE_SETUP_CONFIG_PUBLICATION_HEALTH,
    NODE_SETUP_CONFIG_PUBLICATION_ONOFF_SERVER,
    NODE_SETUP_CONFIG_PUBLICATION_ONOFF_CLIENT1,
    NODE_SETUP_CONFIG_PUBLICATION_ONOFF_CLIENT2,
    NODE_SETUP_CONFIG_SUBSCRIPTION_ONOFF_SERVER,
    NODE_SETUP_DONE,
} config_steps_t;
/* Structure to hold the composition data */
typedef struct
    uint16_t    len;
    struct
        uint8_t page_number;
        uint8_t data[NRF_MESH_SEG_PAYLOAD_SIZE_MAX];
    }composition;
} composition_data_t;
/* Expected status structure, used for setup state machine */
typedef struct
    uint8_t  num_statuses;
    uint16_t expected_opcode;
    const access_status_t  * p_statuses;
} expected_status_list_t;
typedef struct
    uint8_t count;
    timer_event_t timer;
} client_send_retry_t;
typedef enum
    STATUS_CHECK_PASS,
    STATUS_CHECK_FAIL,
    STATUS_CHECK_UNEXPECTED_OPCODE
} status_check_t;
/* USER_NOTE:
You can define one or more such configuration steps for a given node in your network. The choice
of the steps can be done in @ref setup_select_steps() function.
/* Sequence of steps for the client nodes */
static const config_steps_t client_config_steps[] =
    //NODE_SETUP_CONFIG_APPKEY_BIND_ONOFF_CLIENT,
    //NODE_SETUP_CONFIG_PUBLICATION_ONOFF_CLIENT2,
    NODE_SETUP_DONE
/* Sequence of steps for the server nodes */
static const config_steps_t server_config_steps[] =
    NODE_SETUP_DONE
static uint16_t m_current_node_addr;
static uint16_t m_retry_count;
static client_send_retry_t m_send_timer;
static const uint8_t * mp_appkey;
static uint16_t m_appkey_idx;
static uint16_t m_netkey_idx;
static access_model_id_t m_client_model_id;
static access_model_id_t m_server_model_id;
static const config_steps_t m_idle_step = NODE_SETUP_IDLE;
static const config_steps_t * mp_config_step = &m_idle_step;
static node_setup_successful_cb_t m_node_setup_success_cb;
static node_setup_failed_cb_t m_node_setup_failed_cb;
static expected_status_list_t m_expected_status_list;
/* Forward declaration */
static void config_step_execute(void);
static void node_setup_state_clear(void)
    timer_sch_abort(&m_send_timer.timer);
static void node_setup_succeed(void)
    node_setup_state_clear();
    m_node_setup_success_cb();
static void node_setup_fail(void)
    m_node_setup_failed_cb();
/* Set expected status opcode and acceptable value of status codes */
static void expected_status_set(uint32_t opcode, uint32_t n, const access_status_t * p_list)
    if (n > 0)
        NRF_MESH_ASSERT(p_list != NULL);
    m_expected_status_list.expected_opcode = opcode;
    m_expected_status_list.num_statuses = n;
    m_expected_status_list.p_statuses = p_list;
static void config_step_retry_schedule(void)
    NRF_MESH_ASSERT_DEBUG(m_send_timer.count > 0);
    m_send_timer.count--;
    timestamp_t next_timeout = timer_now() + MS_TO_US(CLIENT_BUSY_SEND_RETRY_DELAY_MS);
    timer_sch_reschedule(&m_send_timer.timer, next_timeout);
/* Callback for the timer event */
static void client_send_timer_cb(timestamp_t timestamp, void * p_context)
    /* retry the last step */
    config_step_execute();
 *  When config client status message is received, this function checks for the expected opcode, and
 *  status values. It is required by the node setup state machine.
static status_check_t check_expected_status(uint16_t rx_opcode, const config_msg_t * p_msg)
    uint8_t status = 0xFF;
    if (rx_opcode != m_expected_status_list.expected_opcode)
        __LOG(LOG_SRC_APP, LOG_LEVEL_ERROR, "Unexpected opcode: exp 0x%04x  rx 0x%04x\n",
              m_expected_status_list.expected_opcode, rx_opcode);
        return STATUS_CHECK_UNEXPECTED_OPCODE;
    switch (rx_opcode)
        /* These messages do not have a STATUS field. */
        case CONFIG_OPCODE_COMPOSITION_DATA_STATUS:
        case CONFIG_OPCODE_NETWORK_TRANSMIT_STATUS:
        case CONFIG_OPCODE_MODEL_APP_STATUS:
            status = p_msg->app_status.status;
        case CONFIG_OPCODE_MODEL_PUBLICATION_STATUS:
            status = p_msg->publication_status.status;
        case CONFIG_OPCODE_MODEL_SUBSCRIPTION_STATUS:
            status = p_msg->subscription_status.status;
        case CONFIG_OPCODE_APPKEY_STATUS:
            status = p_msg->appkey_status.status;
            /** USER_TO_CONFIGURE: Resolve additional required statuses in above switch case */
            __LOG(LOG_SRC_APP, LOG_LEVEL_ERROR, "Handle additional statuses here");
            ERROR_CHECK(NRF_ERROR_NOT_FOUND);
    if (m_expected_status_list.num_statuses == 0)
        return STATUS_CHECK_PASS;
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "opcode status field: %d \n", status);
    for (uint32_t i = 0; i < m_expected_status_list.num_statuses; i++)
        if (status == m_expected_status_list.p_statuses[i])
    return STATUS_CHECK_FAIL;
/* Application-specific functions for combining some commonly used structure assignments */
static void client_pub_state_set(config_publication_state_t *p_pubstate, uint16_t element_addr,
                                     uint16_t publish_addr)
    p_pubstate->element_address = element_addr;
    p_pubstate->publish_address.type = nrf_mesh_address_type_get(publish_addr);
    p_pubstate->publish_address.value = publish_addr;
    p_pubstate->appkey_index = m_appkey_idx;
    p_pubstate->frendship_credential_flag = false;
    p_pubstate->publish_ttl = (SERVER_NODE_COUNT > NRF_MESH_TTL_MAX ? NRF_MESH_TTL_MAX : SERVER_NODE_COUNT);
    p_pubstate->publish_period.step_num = 0;
    p_pubstate->publish_period.step_res = ACCESS_PUBLISH_RESOLUTION_100MS;
    p_pubstate->retransmit_count = 1;
    p_pubstate->retransmit_interval = 0;
    p_pubstate->model_id.company_id = m_client_model_id.company_id;
    p_pubstate->model_id.model_id = m_client_model_id.model_id;
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Set: on/off client: 0x%04x  pub addr: 0x%04x\n",
            p_pubstate->element_address, p_pubstate->publish_address.value);
/* Node setup functionality related static functions */
/* USER_NOTE:
You can code any suitable logic here to select the configuration steps for a given
 * Selects the configuration steps for the node.
 * In this example, first device is always a light-switch Client. Subsequent devices are servers
 * First two servers will act as unicast devices and other servers will be subscribed to the
 * ODD or EVEN groups.
 * @param[in]  addr    Address of the device being configured.
static void setup_select_steps(uint16_t addr)
    if (addr == UNPROV_START_ADDRESS)
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "CLIENT about to be configured\n");
        mp_config_step = client_config_steps;
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "SERVER about to be configured\n");
        mp_config_step = server_config_steps;
/** Step execution function for the configuration state machine. */
    uint32_t status = NRF_ERROR_INVALID_STATE;
    static uint16_t model_element_addr = 0;
    /* This example configures the provisioned nodes in the following way
     * Node 0: Client node (Switch)
     * Node 1,2,3 ...: Server nodes (Lights)
     * Group Even: All nodes with even address
     * Group Odd: All nodes with odd address
    /* Customize configuration steps for client vs. server nodes.
     * For client nodes: Skip, usual publication and subscription
    switch (*mp_config_step)
        /* Read the composition data from the node: */
        case NODE_SETUP_CONFIG_COMPOSITION_GET:
            __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Getting composition data\n");
            status = config_client_composition_data_get(0x00);
            __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "status in NODE_SETUP_CONFIG_COMPOSITION_GET is: %d \n",status);
             expected_status_set(CONFIG_OPCODE_COMPOSITION_DATA_STATUS, 0, NULL);
             __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "exiting NODE_SETUP_CONFIG_COMPOSITION_GET \n" );
        case NODE_SETUP_CONFIG_NETWORK_TRANSMIT:
            __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Updating network transmit: count: %d steps: %d\n",
                  NETWORK_TRANSMIT_COUNT, NETWORK_TRANSMIT_INTERVAL_STEPS);
            status = config_client_network_transmit_set(NETWORK_TRANSMIT_COUNT, NETWORK_TRANSMIT_INTERVAL_STEPS);
            expected_status_set(CONFIG_OPCODE_NETWORK_TRANSMIT_STATUS, 0 , NULL);
        /* Add the application key to the node: */
        case NODE_SETUP_CONFIG_APPKEY_ADD:
            __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Adding appkey\n");
            status = config_client_appkey_add(m_netkey_idx, m_appkey_idx, mp_appkey);
            static const access_status_t exp_status[] = {ACCESS_STATUS_SUCCESS, ACCESS_STATUS_KEY_INDEX_ALREADY_STORED};
            expected_status_set(CONFIG_OPCODE_APPKEY_STATUS, ARRAY_SIZE(exp_status), exp_status);
        /* Bind the health server to the application key: */
        case NODE_SETUP_CONFIG_APPKEY_BIND_HEALTH:
            __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "App key bind: Health server\n");
            access_model_id_t model_id;
            model_id.company_id = ACCESS_COMPANY_ID_NONE;
            model_id.model_id = HEALTH_SERVER_MODEL_ID;
            uint16_t element_address = m_current_node_addr;
            status = config_client_model_app_bind(element_address, m_appkey_idx, model_id);
            static const access_status_t exp_status[] = {ACCESS_STATUS_SUCCESS};
            expected_status_set(CONFIG_OPCODE_MODEL_APP_STATUS, ARRAY_SIZE(exp_status), exp_status);
        /* Bind the On/Off server to the application key: */
        case NODE_SETUP_CONFIG_APPKEY_BIND_ONOFF_SERVER:
            __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "App key bind: 0x%04x server\n", m_server_model_id.model_id);
            model_id.company_id = m_server_model_id.company_id;
            model_id.model_id = m_server_model_id.model_id;
        /* Bind the On/Off client to the application key: */
        case NODE_SETUP_CONFIG_APPKEY_BIND_ONOFF_CLIENT:
            if (model_element_addr == 0)
                model_element_addr = m_current_node_addr + 1;
            __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "App key bind: 0x%04x client on element 0x%04x\n", m_client_model_id.model_id, model_element_addr);
            uint16_t element_address = model_element_addr;
            if (status == NRF_SUCCESS)
                model_element_addr++;
        /* Configure the publication parameters for the Health server: */
        case NODE_SETUP_CONFIG_PUBLICATION_HEALTH:
            config_publication_state_t pubstate = {0};
            pubstate.element_address = m_current_node_addr;
            pubstate.publish_address.type = NRF_MESH_ADDRESS_TYPE_UNICAST;
            pubstate.publish_address.value = PROVISIONER_ADDRESS;
            pubstate.appkey_index = m_appkey_idx;
            pubstate.frendship_credential_flag = false;
            pubstate.publish_ttl = (SERVER_NODE_COUNT > NRF_MESH_TTL_MAX ? NRF_MESH_TTL_MAX : SERVER_NODE_COUNT);
            pubstate.publish_period.step_num = 1;
            pubstate.publish_period.step_res = ACCESS_PUBLISH_RESOLUTION_10S;
            pubstate.retransmit_count = 1;
            pubstate.retransmit_interval = 0;
            pubstate.model_id.company_id = ACCESS_COMPANY_ID_NONE;
            pubstate.model_id.model_id = HEALTH_SERVER_MODEL_ID;
            __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Setting publication address for the health server to 0x%04x\n", pubstate.publish_address.value);
            status = config_client_model_publication_set(&pubstate);
            expected_status_set(CONFIG_OPCODE_MODEL_PUBLICATION_STATUS, ARRAY_SIZE(exp_status), exp_status);
        /* Configure the publication parameters for the On/Off servers to publish to the
        corresponding On/Off clients (ODD servers: Client on Element 1 and EVEN servers: Client on
        element 2, of the client example). This demonstrates the state change publication due to local
        event on the server. */
        case NODE_SETUP_CONFIG_PUBLICATION_ONOFF_SERVER:
            if ((m_current_node_addr % 2) == 0)
                pubstate.publish_address.value = UNPROV_START_ADDRESS + ELEMENT_IDX_ONOFF_CLIENT2;
                pubstate.publish_address.value = UNPROV_START_ADDRESS + ELEMENT_IDX_ONOFF_CLIENT1;
            pubstate.publish_period.step_num = 0;
            pubstate.publish_period.step_res = ACCESS_PUBLISH_RESOLUTION_100MS;
            pubstate.model_id.company_id = m_server_model_id.company_id;
            pubstate.model_id.model_id = m_server_model_id.model_id;
            __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Set: 0x%04x server pub addr: 0x%04x\n", m_server_model_id.model_id, pubstate.publish_address.value);
        /* Configure subscription address for the On/Off server */
        case NODE_SETUP_CONFIG_SUBSCRIPTION_ONOFF_SERVER:
            __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Adding subscription\n");
            nrf_mesh_address_t address = {NRF_MESH_ADDRESS_TYPE_INVALID, 0, NULL};
            address.type = NRF_MESH_ADDRESS_TYPE_GROUP;
            if (m_current_node_addr % 0x02)
                address.value  = GROUP_ADDRESS_ODD;
                address.value  = GROUP_ADDRESS_EVEN;
            status = config_client_model_subscription_add(element_address, address, model_id);
            expected_status_set(CONFIG_OPCODE_MODEL_SUBSCRIPTION_STATUS, ARRAY_SIZE(exp_status), exp_status);
        case NODE_SETUP_CONFIG_PUBLICATION_ONOFF_CLIENT1:
            client_pub_state_set(&pubstate,
                                 m_current_node_addr + ELEMENT_IDX_ONOFF_CLIENT1,
                                 GROUP_ADDRESS_ODD);
        case NODE_SETUP_CONFIG_PUBLICATION_ONOFF_CLIENT2:
                                 m_current_node_addr + ELEMENT_IDX_ONOFF_CLIENT2,
                                 GROUP_ADDRESS_EVEN);
    if (status != NRF_SUCCESS)
        config_client_pending_msg_cancel();
        if (m_send_timer.count > 0)
            config_step_retry_schedule();
            node_setup_fail();
 * This function retrieves the device key for the given address, and configures the tx and rx paths
 * of the config client model.
static void setup_config_client(uint16_t target_addr)
    dsm_handle_t        addr_handle = DSM_HANDLE_INVALID;
    dsm_handle_t        devkey_handle = DSM_HANDLE_INVALID;
    nrf_mesh_address_t  addr;
    addr.type  = NRF_MESH_ADDRESS_TYPE_UNICAST;
    addr.value = target_addr;
    /* Provisioner helper has stored address and device keys already. Retrieve them. */
    ERROR_CHECK(dsm_address_handle_get(&addr, &addr_handle));
    ERROR_CHECK(dsm_devkey_handle_get(addr.value, &devkey_handle));
    /* Configure client to communicate with server at the given address */
    ERROR_CHECK(config_client_server_bind(devkey_handle));
    ERROR_CHECK(config_client_server_set(devkey_handle, addr_handle));
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Config client setup: devkey_handle:%d addr_handle:%d\n", devkey_handle, addr_handle);
static void config_client_msg_handle(const config_client_event_t * p_event,
                                     uint16_t length)
    if (*mp_config_step == NODE_SETUP_IDLE || *mp_config_step == NODE_SETUP_DONE)
        __LOG(LOG_SRC_APP, LOG_LEVEL_WARN, "Got unexpected config client message in state %u\n", *mp_config_step);
        return;
        status_check_t status = check_expected_status(p_event->opcode, p_event->p_msg);
        if (status == STATUS_CHECK_PASS)
            mp_config_step++;
            m_send_timer.count = CLIENT_BUSY_SEND_RETRY_LIMIT;
            if (*mp_config_step == NODE_SETUP_DONE)
                node_setup_succeed();
        else if (status == STATUS_CHECK_FAIL)
            node_setup_fail();
/* Public functions */
 * Proccess the config client model events, and advances the node setup state machine to the next
 * state, if expected status message is received.
void node_setup_config_client_event_process(config_client_event_type_t event_type,
                                        uint16_t length)
    if (event_type == CONFIG_CLIENT_EVENT_TYPE_TIMEOUT)
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Acknowledged message status not received \n");
        if (m_retry_count > 0)
            __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Retry ...\n");
            m_retry_count--;
            node_setup_fail();
    else if (event_type == CONFIG_CLIENT_EVENT_TYPE_MSG)
        NRF_MESH_ASSERT_DEBUG(p_event != NULL);
        config_client_msg_handle(p_event, length);
 * Begins the node setup process.
void node_setup_start(uint16_t address, uint8_t  retry_cnt, const uint8_t * p_appkey,
                      uint16_t appkey_idx, uint16_t netkey_idx, const char * p_client_uri)
    if (*mp_config_step != NODE_SETUP_IDLE)
        __LOG(LOG_SRC_APP, LOG_LEVEL_ERROR, "Cannot start. Node setup procedure is in progress.\n");
        return;
    m_current_node_addr = address;
    m_retry_count = retry_cnt;
    m_send_timer.timer.cb = client_send_timer_cb;
    mp_appkey = p_appkey;
    m_appkey_idx = appkey_idx;
    m_netkey_idx = netkey_idx;
    /* The filter match will decide, which model pairs to pick up */
    if (strcmp(p_client_uri, EX_URI_LS_CLIENT) == 0 || strcmp(p_client_uri, EX_URI_ENOCEAN) == 0)
        m_client_model_id.model_id = GENERIC_ONOFF_CLIENT_MODEL_ID;
        m_server_model_id.model_id = GENERIC_ONOFF_SERVER_MODEL_ID;
    else if (strcmp(p_client_uri, EX_URI_DM_CLIENT) == 0)
        m_client_model_id.model_id = GENERIC_LEVEL_CLIENT_MODEL_ID;
        m_server_model_id.model_id = GENERIC_LEVEL_SERVER_MODEL_ID;
        __LOG(LOG_SRC_APP, LOG_LEVEL_ERROR, "Invalid client URI identifier.\n");
        NRF_MESH_ASSERT(false);
    m_client_model_id.company_id = ACCESS_COMPANY_ID_NORDIC;
    m_server_model_id.company_id = ACCESS_COMPANY_ID_NORDIC;
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Configuring Node: 0x%04X\n", m_current_node_addr);
    setup_config_client(m_current_node_addr);
    setup_select_steps(m_current_node_addr);
void node_setup_cb_set(node_setup_successful_cb_t config_success_cb,
                       node_setup_failed_cb_t config_failed_cb)
    NRF_MESH_ASSERT(config_success_cb != NULL);
    NRF_MESH_ASSERT(config_failed_cb != NULL);
    m_node_setup_success_cb = config_success_cb;
    m_node_setup_failed_cb = config_failed_cb;
I expect the mistake to be in the server implementation, since it is the one NOT acknowledging the configuration, but i really can't tell.
 main.c (server)
#include <stdint.h>
#include <string.h>
/* HAL */
#include "boards.h"
#include "simple_hal.h"
#include "app_timer.h"
/* Core */
#include "nrf_mesh_config_core.h"
#include "nrf_mesh_gatt.h"
#include "nrf_mesh_configure.h"
#include "nrf_mesh.h"
#include "mesh_stack.h"
#include "proxy.h"
/* Provisioning and configuration */
#include "mesh_provisionee.h"
/* Models */
#include "C:\nRF_work\nrf5SDKforMeshv320src\models\vendor\simple_on_off\include\simple_on_off_server.h"
//#include "C:\Users\RAbbas\OneDrive - Emerson\Documents\repos\mesh test\model\server_models\s_model.h"
/* Logging and RTT */
#include "log.h"
#include "rtt_input.h"
/* Example specific includes */
#include "app_config.h"
#include "nrf_mesh_config_examples.h"
//#include "app_onoff.h"
#include "ble_softdevice_support.h"
//#define ONOFF_SERVER_0_LED          (BSP_LED_0)
//#define APP_ONOFF_ELEMENT_INDEX     (0)
#define ON_OFF_MODEL_ELEMENT_INDEX      (0)
static bool m_device_provisioned= 0;
//probably bad practice, but this is model value
static uint8_t value_of_on_off_model=0;
static bool app_on_off_model_server_set_cb(const simple_on_off_server_t * p_server, uint8_t value);
static bool app_on_off_model_server_get_cb(const simple_on_off_server_t * p_server, uint8_t * p_present_value);
//  Generic OnOff server structure definition and initialization
APP_TEST_MODEL_SERVER_DEF(m_test_model_server_0,
                     app_test_model_server_set_cb,
                     app_test_model_server_get_cb)
const simple_on_off_server_t m_on_off_model_server_0 =
        .set_cb = app_on_off_model_server_set_cb,
        .get_cb = app_on_off_model_server_get_cb
// Callback for updating the hardware state
//static void app_onoff_server_set_cb(const app_onoff_server_t * p_server, bool onoff)
   //  Resolve the server instance here if required, this example uses only 1 instance.
    //__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Setting GPIO value: %d\n", onoff)
    value_of_on_off_model=value;
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "exiting set_cb, value is: %d \n", value_of_on_off_model);
    //hal_led_pin_set(ONOFF_SERVER_0_LED, onoff);
    return true;
//m Callback for reading the hardware state
//static void app_onoff_server_get_cb(const app_onoff_server_t * p_server, bool * p_present_onoff)
    *p_present_value=value_of_on_off_model;
    //*p_present_onoff = hal_led_pin_get(ONOFF_SERVER_0_LED);
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "exiting get_cb, value is: %d \n", value_of_on_off_model);
    return true;
static void app_model_init(void)
    /* Instantiate onoff server on element index APP_ONOFF_ELEMENT_INDEX */
    //ERROR_CHECK(app_onoff_init(&m_onoff_server_0, APP_ONOFF_ELEMENT_INDEX));
    ERROR_CHECK(simple_on_off_server_init(&m_on_off_model_server_0, ON_OFF_MODEL_ELEMENT_INDEX));
    //__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "App OnOff Model Handle: %d\n", m_onoff_server_0.server.model_handle);
static void node_reset(void)
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "----- Node reset  -----\n");
    hal_led_blink_ms(LEDS_MASK, LED_BLINK_INTERVAL_MS, LED_BLINK_CNT_RESET);
    /* This function may return if there are ongoing flash operations. */
    mesh_stack_device_reset();
static void config_server_evt_cb(const config_server_evt_t * p_evt)
    if (p_evt->type == CONFIG_SERVER_EVT_NODE_RESET)
        node_reset();
static void app_rtt_input_handler(int key)
    if (key >= '0' && key <= '4')
        uint32_t button_number = key - '0';
        button_event_handler(button_number);
static void device_identification_start_cb(uint8_t attention_duration_s)
    hal_led_mask_set(LEDS_MASK, false);
    hal_led_blink_ms(BSP_LED_2_MASK  | BSP_LED_3_MASK,
                     LED_BLINK_ATTENTION_INTERVAL_MS,
                     LED_BLINK_ATTENTION_COUNT(attention_duration_s));
static void provisioning_aborted_cb(void)
    hal_led_blink_stop();
static void provisioning_complete_cb(void)
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Successfully provisioned\n");
#if MESH_FEATURE_GATT_ENABLED
    /* Restores the application parameters after switching from the Provisioning
     * service to the Proxy  */
    gap_params_init();
    conn_params_init();
    dsm_local_unicast_address_t node_address;
    dsm_local_unicast_addresses_get(&node_address);
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Node Address: 0x%04x \n", node_address.address_start);
    hal_led_mask_set(LEDS_MASK, LED_MASK_STATE_OFF);
    hal_led_blink_ms(LEDS_MASK, LED_BLINK_INTERVAL_MS, LED_BLINK_CNT_PROV);
static void models_init_cb(void)
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Initializing and adding models\n");
    app_model_init();
static void mesh_init(void)
    mesh_stack_init_params_t init_params =
        .core.irq_priority       = NRF_MESH_IRQ_PRIORITY_LOWEST,
        .core.lfclksrc           = DEV_BOARD_LF_CLK_CFG,
        .core.p_uuid             = NULL,
        .models.models_init_cb   = models_init_cb,
        .models.config_server_cb = config_server_evt_cb
    ERROR_CHECK(mesh_stack_init(&init_params, &m_device_provisioned));
static void initialize(void)
    __LOG_INIT(LOG_SRC_APP | LOG_SRC_FRIEND, LOG_LEVEL_DBG1, LOG_CALLBACK_DEFAULT);
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "----- BLE Mesh Light Switch Server Demo -----\n");
    ERROR_CHECK(app_timer_init());
    hal_leds_init();
#if BUTTON_BOARD
   // ERROR_CHECK(hal_buttons_init(button_event_handler));
    ble_stack_init();
    gap_params_init();
    conn_params_init();
    mesh_init();
static void start(void)
  //  rtt_input_enable(app_rtt_input_handler, RTT_INPUT_POLL_PERIOD_MS);
    if (!m_device_provisioned)
        static const uint8_t static_auth_data[NRF_MESH_KEY_SIZE] = STATIC_AUTH_DATA;
        mesh_provisionee_start_params_t prov_start_params =
            .p_static_data    = static_auth_data,
            .prov_complete_cb = provisioning_complete_cb,
            .prov_device_identification_start_cb = device_identification_start_cb,
            .prov_device_identification_stop_cb = NULL,
            .prov_abort_cb = provisioning_aborted_cb,
            .p_device_uri = EX_URI_LS_SERVER
        ERROR_CHECK(mesh_provisionee_prov_start(&prov_start_params));
    mesh_app_uuid_print(nrf_mesh_configure_device_uuid_get());
    ERROR_CHECK(mesh_stack_start());
    hal_led_blink_ms(LEDS_MASK, LED_BLINK_INTERVAL_MS, LED_BLINK_CNT_START);
    initialize();
    start();
    for (;;)
        (void)sd_app_evt_wait();
