SAADC keeps printing same value (0 and previous value)
Hi Devzone
I tried to use saadc with 4channels. when I use this without fpu_fft, It prints correct value well.
But, when I insert the fpu_fft and run it, after a while, saadc prints 0 and fixed previous value.
I think the problem is busy CPU.
Is there any solution?
The whole code is below
 * Copyright (c) 2014 - 2019, Nordic Semiconductor ASA
 * All rights reserved.
 * @brief BLE LED Button Service central and client application main file.
 * This example can be a central for up to 8 peripherals.
 * The peripheral is called ble_app_blinky and can be found in the ble_peripheral
 * folder.
#include <stdbool.h>
#include <stdint.h>
#include <stdio.h>
#include <string.h>
#include "nordic_common.h"
#include "compiler_abstraction.h"
#include "nrf.h"
#include "app_error.h"
#include "app_uart.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "app_timer.h"
#include "bsp_btn_ble.h"
#include "ble.h"
#include "ble_hci.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "ble_db_discovery.h"
#include "app_util.h"
#include "ble_nus_c.h"
#include "ble_conn_state.h"
#include "nrf_ble_gatt.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_ble_scan.h"
#include "nrf_drv_ppi.h"
#include "nrf_drv_saadc.h"
#include "nrf_drv_timer.h"
#include "nrf_delay.h"
#include "nrf_twi.h"
#include "nrf_drv_twi.h"
#include "nrf_twi_mngr.h"
#include "nrf_twi_sensor.h"
#include "iis2dlpc.h"
#include "boards.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "bsp.h"
/*lint -save -e689 */ /* Apparent end of comment ignored */
#include "arm_const_structs.h"
/*lint -restore */
#define APP_BLE_CONN_CFG_TAG      1                                             /**< Tag that refers to the BLE stack configuration that is set with @ref sd_ble_cfg_set. The default tag is @ref APP_BLE_CONN_CFG_TAG. */
#define APP_BLE_OBSERVER_PRIO     3                                             /**< BLE observer priority of the application. There is no need to modify this value. */
#define UART_TX_BUF_SIZE        256                                             /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE        256                                             /**< UART RX buffer size. */
#define CENTRAL_SCANNING_LED      BSP_BOARD_LED_0
#define CENTRAL_CONNECTED_LED     BSP_BOARD_LED_1
#define LEDBUTTON_LED             BSP_BOARD_LED_2                               /**< LED to indicate a change of state of the Button characteristic on the peer. */
#define LEDBUTTON_BUTTON          BSP_BUTTON_0                                  /**< Button that writes to the LED characteristic of the peer. */
#define BUTTON_DETECTION_DELAY    APP_TIMER_TICKS(50)                           /**< Delay from a GPIOTE event until a button is reported as pushed (in number of timer ticks). */
#define NUS_SERVICE_UUID_TYPE   BLE_UUID_TYPE_VENDOR_BEGIN                      /**< UUID type for the Nordic UART Service (vendor specific). */
#define ECHOBACK_BLE_UART_DATA  0                                               /**< The flag whether central sends peripheral the received message again */
#define DIFF_SIZE 10                                                            /**< difference 0~2 arrays size. */
#define II_ADDR (0x33U >>1)                                                     /**< IIS2DLPC Sensor Adress. */
#define MAX_PENDING_TRANSACTIONS    4                                           /**< Maximum numbers of pending transactions. */
#define SAMPLES_IN_BUFFER 4                                                     /**< The number of analog sensors */
#define SAADC_SAMPLE_RATE 250                                                   /**< The sampling rate of saadc */
#define FLAME_PIN NRF_SAADC_INPUT_AIN0                                          /**< The hadware pin for flame detect sensor */
#define SOUND_PIN NRF_SAADC_INPUT_AIN1                                          /**< The hadware pin for mic sensor */
#define HUMID_PIN NRF_SAADC_INPUT_AIN2                                          /**< The hadware pin for soil-moisture sensor */
#define BAT_PIN NRF_SAADC_INPUT_VDD                                             /**< The hadware pin for battery(vdd) */
#define FLAME_CHANNEL 0                                                         /**< The saadc module channel of flame detect sensor */
#define SOUND_CHANNEL 1                                                         /**< The saadc module channel of mic sensor */
#define HUMID_CHANNEL 2                                                         /**< The saadc module channel of soil-moisture sensor */
#define BAT_CHANNEL 3                                                           /**< The saadc module channel of battery(vdd) */
#define ADC_REF_VOLTAGE_IN_MILLIVOLTS   600                                     /**< Reference voltage (in milli volts) used by ADC while doing conversion. */
#define ADC_PRE_SCALING_COMPENSATION    6                                       /**< The ADC is configured to use VDD with 1/3 prescaling as input. And hence the result of conversion is to be multiplied by 3 to get the actual value of the battery voltage.*/
#define DIODE_FWD_VOLT_DROP_MILLIVOLTS  270                                     /**< Typical forward voltage drop of the diode . */
#define ADC_RES_10BIT                   1024                                    /**< Maximum digital value for 10-bit ADC conversion. */
#define ADC_RESULT_IN_MILLI_VOLTS(ADC_VALUE)\
        ((((ADC_VALUE) * ADC_REF_VOLTAGE_IN_MILLIVOLTS) / ADC_RES_10BIT) * ADC_PRE_SCALING_COMPENSATION)    /**<  The mathematical expression for converting the value of saadc(vdd) as milli volts unit. */
#define GRAPH_WINDOW_HEIGHT              53                                     /**< Graph window height used in draw function. */
#define FPU_EXCEPTION_MASK               0x0000009F                             /**< FPU exception mask used to clear exceptions in FPSCR register. */
#define FPU_FPSCR_REG_STACK_OFF          0x40                                   /**< Offset of FPSCR register stacked during interrupt handling in FPU part stack. */
// We want to use 44100 Hz sampling rate to reach 22050Hz band. 128 (64 pairs) samples are used
// in FFT calculation with result contains 64 bins (22050Hz/64bins -> ~344,5Hz per bin).
#define FFT_TEST_SAMPLE_FREQ_HZ          44100.0f                               /**< Frequency of complex input samples. */
//#define FFT_TEST_SAMPLE_FREQ_HZ          42000.0f
#define FFT_TEST_COMP_SAMPLES_LEN        512                                    /**< Complex numbers input data array size. Correspond to FFT calculation this number must be power of two starting from 2^5 (2^4 pairs) with maximum value 2^13 (2^12 pairs). */
#define FFT_TEST_OUT_SAMPLES_LEN         (FFT_TEST_COMP_SAMPLES_LEN / 2)        /**< Output array size. */
#define SIGNALS_RESOLUTION               100.0f                                 /**< Sine wave frequency and noise amplitude resolution. To count resolution as decimal places in number use this formula: resolution = 1/SIGNALS_RESOLUTION. */
#define SINE_WAVE_FREQ_MAX               20000                                  /**< Maximum frequency of generated sine wave. */
#define NOISE_AMPLITUDE                  1                                      /**< Amplitude of generated noise added to signal. */
//#define ACCEL_FFT_PRINT
#define SOUND_FFT_PRINT
#ifdef ACCEL_FFT_PRINT
#define Y_PRINT
//#define TIMECHECK                                                               /**< The flag of checking execution time. */
#ifdef X_PRINT
#define OUTPUT_PORT x_output
#ifdef Y_PRINT
#define OUTPUT_PORT y_output
#ifdef Z_PRINT
#define OUTPUT_PORT z_output
#ifdef SOUND_FFT_PRINT
#define OUTPUT_PORT sound_output
NRF_BLE_GATT_DEF(m_gatt);                                                       /**< GATT module instance. */
BLE_NUS_C_ARRAY_DEF(m_ble_nus_c, NRF_SDH_BLE_TOTAL_LINK_COUNT);
BLE_DB_DISCOVERY_ARRAY_DEF(m_db_disc, NRF_SDH_BLE_TOTAL_LINK_COUNT);            /**< Database discovery module instances. */
NRF_BLE_SCAN_DEF(m_scan);                                                       /**< Scanning Module instance. */
NRF_TWI_MNGR_DEF(m_nrf_twi_mngr, MAX_PENDING_TRANSACTIONS, 0);                  /**< TWI transaction manager instance. */
NRF_TWI_SENSOR_DEF(m_nrf_twi_sensor, &m_nrf_twi_mngr, NRF_TWI_SENSOR_SEND_BUF_SIZE);                        /**< TWI sensor instance. */
static nrf_saadc_channel_config_t ch_config_flame = NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(FLAME_PIN);     /**< The saadc cnannel configuration of flame detect sensor. */
static nrf_saadc_channel_config_t ch_config_sound = NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(SOUND_PIN);     /**< The saadc cnannel configuration of mic sensor. */
static nrf_saadc_channel_config_t ch_config_humid = NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(HUMID_PIN);     /**< The saadc cnannel configuration of soil-moisture sensor. */
static nrf_saadc_channel_config_t ch_config_bat = NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(BAT_PIN);         /**< The saadc cnannel configuration of battery(vdd). */
static const nrf_drv_timer_t m_timer = NRF_DRV_TIMER_INSTANCE(3);               /**< The channel of used timer triver. */
static char const m_target_periph_name[] = "Nordic_Blinky";                     /**< Name of the device to try to connect to. This name is searched for in the scanning report data. */
static axis3bit16_t          data_raw_acceleration;                             /**< Load raw data from iis2dlpc sensor into this variable. */
static iis2dlpc_ctx_t        dev_ctx;                                           /**< Handle iis2dlpc sensor's read/write instance with this variable. */
static uint8_t               whoamI, rst;                                       /**< Validate iis2dlpc sensor address and status to use. */
static float acceleration_mg[3];                                                /**< Convert raw data to float(usable) data into this variable by using iis2dlpc sdk. */
static int current_value[3];                                                    /**< Current data to use dto62 private function. */
static int previous_value[3] = {0};                                             /**< Previous data to use dto62 private function. */
static char difference0[DIFF_SIZE];                                             /**< X-axis Difference between Previous data and Current data converted by dto62 private function. */
static char difference1[DIFF_SIZE];                                             /**< Y-axis Difference between Previous data and Current data converted by dto62 private function. */
static char difference2[DIFF_SIZE];                                             /**< Z-axis Difference between Previous data and Current data converted by dto62 private function. */
static char m_buffer[DIFF_SIZE*3];                                              /**< Buffer to print all the difference data. */
static float calib_offset[3];
static nrf_saadc_value_t m_buffer_pool[2][SAMPLES_IN_BUFFER];                                      /**< The storage of 4 values which are results of saadc. */
static nrf_ppi_channel_t     m_ppi_channel;                                     /**< The ppi instance for interconnecting timer and saadc. */
static uint16_t m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - OPCODE_LENGTH - HANDLE_LENGTH;          /**< The maximum length of ble data. */
static uint8_t m_ble_nus_c_count;                                               /**< The instance of present connected count of ble devices. */
static uint16_t accel_counter = 0;                                       /**< The counter used for counting the excution counts of iss2dlpc. */
static uint16_t sound_counter = 0;                                       /**< The counter used for checking excution time. */
static uint32_t  m_ifft_flag             = 0;                            /**< Flag that selects forward (0) or inverse (1) transform. */
static uint32_t  m_do_bit_reverse        = 1;                            /**< Flag that enables (1) or disables (0) bit reversal of output. */
//static float32_t m_fft_input_f32[FFT_TEST_COMP_SAMPLES_LEN];             /**< FFT input array. Time domain. */
//static float32_t m_fft_output_f32[FFT_TEST_OUT_SAMPLES_LEN];             /**< FFT output data. Frequency domain. */
#ifdef TIMECHECK
static uint16_t counter = 0;                                             /**< The counter used for checking excution time. */
static uint32_t start;                                                          /**< The time recorded when program starts. */
static uint32_t stop;                                                           /**< The time recorded when program terminates. */
static uint32_t elapsed;                                                        /**< The execution time. */
typedef struct
    float32_t   x_input[FFT_TEST_COMP_SAMPLES_LEN];
    float32_t   y_input[FFT_TEST_COMP_SAMPLES_LEN];
    float32_t   z_input[FFT_TEST_COMP_SAMPLES_LEN];
    float32_t   sound_input[FFT_TEST_COMP_SAMPLES_LEN];
} m_fft_input_f32;
typedef struct
    float32_t   x_output[FFT_TEST_OUT_SAMPLES_LEN];
    float32_t   y_output[FFT_TEST_OUT_SAMPLES_LEN];
    float32_t   z_output[FFT_TEST_OUT_SAMPLES_LEN];
    float32_t   sound_output[FFT_TEST_OUT_SAMPLES_LEN];
} m_fft_output_f32;
static m_fft_input_f32 fft_input;
static m_fft_output_f32 fft_output;
static ble_uuid_t const m_nus_uuid =                                            /**< Universally unique service identifiers. */
    .uuid = BLE_UUID_DEVICE_INFORMATION_SERVICE,
    .type = BLE_UUID_TYPE_BLE
/**@brief Function for handling asserts in the SoftDevice.
 * @details This function is called in case of an assert in the SoftDevice.
 * @warning This handler is only an example and is not meant for the final product. You need to analyze
 *          how your product is supposed to react in case of an assert.
 * @param[in] line_num     Line number of the failing assert call.
 * @param[in] p_file_name  File name of the failing assert call.
    app_error_handler(0xDEADBEEF, line_num, p_file_name);
/**@brief Function for initializing the LEDs.
 * @details Initializes all LEDs used by the application.
static void leds_init(void)
static void scan_evt_handler(scan_evt_t const * p_scan_evt)
    ret_code_t err_code;
    switch(p_scan_evt->scan_evt_id)
        case NRF_BLE_SCAN_EVT_CONNECTING_ERROR:
            err_code = p_scan_evt->params.connecting_err.err_code;
        } break;
/**@brief Function for initializing the scanning and setting the filters. */
static void scan_init(void)
    nrf_ble_scan_init_t init_scan;
    memset(&init_scan, 0, sizeof(init_scan));
    init_scan.connect_if_match = true;
    init_scan.conn_cfg_tag     = APP_BLE_CONN_CFG_TAG;
    err_code = nrf_ble_scan_init(&m_scan, &init_scan, scan_evt_handler);
    err_code = nrf_ble_scan_filter_set(&m_scan, SCAN_UUID_FILTER, &m_nus_uuid);
    err_code = nrf_ble_scan_filters_enable(&m_scan, NRF_BLE_SCAN_UUID_FILTER, false);
/**@brief Function for starting scanning. */
static void scan_start(void)
    ret_code_t ret;
    sd_ble_gap_scan_stop();
    NRF_LOG_INFO("Start scanning for device name %s.", (uint32_t)m_target_periph_name);
    ret = nrf_ble_scan_start(&m_scan);
    APP_ERROR_CHECK(ret);
    // Turn on the LED to signal scanning.
    bsp_board_led_on(CENTRAL_SCANNING_LED);
static void ble_nus_chars_received_uart_print(uint8_t * p_data, uint16_t data_len)
    ret_code_t ret_val;
    NRF_LOG_DEBUG("Receiving data.");
    NRF_LOG_HEXDUMP_DEBUG(p_data, data_len);
    for (uint32_t i = 0; i < data_len; i++)
        do
            ret_val = app_uart_put(p_data[i]);
            if ((ret_val != NRF_SUCCESS) && (ret_val != NRF_ERROR_BUSY))
                NRF_LOG_ERROR("app_uart_put failed for index 0x%04x.", i);
                APP_ERROR_CHECK(ret_val);
        } while (ret_val == NRF_ERROR_BUSY);
    if (p_data[data_len-1] == '\r')
        while (app_uart_put('\n') == NRF_ERROR_BUSY);
    *It can be used later, so it wasn't removed.
    if (ECHOBACK_BLE_UART_DATA)
        // Send data back to the peripheral.
        do
            for (uint32_t i = 0; i < NRF_SDH_BLE_CENTRAL_LINK_COUNT; i++)
                ret_val = ble_nus_c_string_send(&m_ble_nus_c, p_data, data_len);
                    NRF_LOG_ERROR("Failed sending NUS message. Error 0x%x. ", ret_val);
 * @details This function receives a single character from the app_uart module and appends it to
 *          a string. The string is sent over BLE when the last character received is a
 *          'new line' '\n' (hex 0x0A) or if the string reaches the maximum data length.
    static uint16_t index = 0;
    uint32_t ret_val;
    switch (p_event->evt_type)
        /**@snippet [Handling data from UART] */
        case APP_UART_DATA_READY:
            index++;
            if ((data_array[index - 1] == '\n') || (index >= (m_ble_nus_max_data_len)))
                do
                    ret_val = ble_nus_c_string_send(&m_ble_nus_c, data_array, index);
                    if ( (ret_val != NRF_ERROR_INVALID_STATE) && (ret_val != NRF_ERROR_RESOURCES) )
                } while (ret_val == NRF_ERROR_RESOURCES);
                index = 0;
            NRF_LOG_ERROR("Communication error occurred while handling UART.");
        case APP_UART_FIFO_ERROR:
            NRF_LOG_ERROR("Error occurred in FIFO module used by UART.");
/**@brief Callback handling Nordic UART Service (NUS) client events.
 * @details This function is called to notify the application of NUS client events.
 * @param[in]   p_ble_nus_c   NUS client handle. This identifies the NUS client.
 * @param[in]   p_ble_nus_evt Pointer to the NUS client event.
/**@snippet [Handling events from the ble_nus_c module] */
static void ble_nus_c_evt_handler(ble_nus_c_t * p_ble_nus_c, ble_nus_c_evt_t const * p_ble_nus_evt)
    switch (p_ble_nus_evt->evt_type)
        case BLE_NUS_C_EVT_DISCOVERY_COMPLETE:
            NRF_LOG_INFO("Discovery complete.");
            err_code = ble_nus_c_tx_notif_enable(p_ble_nus_c);
            NRF_LOG_INFO("Connected to device with Nordic UART Service.");
            if(err_code != NRF_ERROR_BUSY)
        case BLE_NUS_C_EVT_NUS_TX_EVT:
            printf(p_ble_nus_evt->p_data);
        case BLE_NUS_C_EVT_DISCONNECTED:
            NRF_LOG_INFO("Disconnected.");
            scan_start();
 * @brief Function for handling shutdown events.
 * @param[in]   event       Shutdown type.
static bool shutdown_handler(nrf_pwr_mgmt_evt_t event)
    switch (event)
        case NRF_PWR_MGMT_EVT_PREPARE_WAKEUP:
            // Prepare wakeup buttons.
    return true;
NRF_PWR_MGMT_HANDLER_REGISTER(shutdown_handler, APP_SHUTDOWN_HANDLER_PRIORITY);
/**@brief Function for initializing nRF uart service that will be used by ble.
static void nus_c_init(void)
    ble_nus_c_init_t init;
    init.evt_handler = ble_nus_c_evt_handler;
    for (m_ble_nus_c_count = 0; m_ble_nus_c_count < NRF_SDH_BLE_TOTAL_LINK_COUNT; m_ble_nus_c_count++)
        err_code = ble_nus_c_init(&m_ble_nus_c[m_ble_nus_c_count], &init);
    // For readability.
    ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
        // Upon connection, check which peripheral is connected, initiate DB
        // discovery, update LEDs status, and resume scanning, if necessary.
        case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("Connection 0x%x established, starting DB discovery.",
                         p_gap_evt->conn_handle);
            APP_ERROR_CHECK_BOOL(p_gap_evt->conn_handle < NRF_SDH_BLE_CENTRAL_LINK_COUNT);
            err_code = ble_nus_c_handles_assign(&m_ble_nus_c[p_gap_evt->conn_handle], p_gap_evt->conn_handle, NULL);
            err_code = ble_db_discovery_start(&m_db_disc[p_gap_evt->conn_handle],
            if (err_code != NRF_ERROR_BUSY)
            // Update LEDs status and check whether it is needed to look for more
            // peripherals to connect to.
            bsp_board_led_on(CENTRAL_CONNECTED_LED);
            if (ble_conn_state_central_conn_count() == NRF_SDH_BLE_CENTRAL_LINK_COUNT)
                bsp_board_led_off(CENTRAL_SCANNING_LED);
                // Resume scanning.
                scan_start();
        } break; // BLE_GAP_EVT_CONNECTED
        // Upon disconnection, reset the connection handle of the peer that disconnected, update
        // the LEDs status and start scanning again.
            NRF_LOG_INFO("LBS central link 0x%x disconnected (reason: 0x%x)",
                         p_gap_evt->params.disconnected.reason);
            if (ble_conn_state_central_conn_count() == 0)
                // Turn off the LED that indicates the connection.
                bsp_board_led_off(CENTRAL_CONNECTED_LED);
            // Start scanning.
            scan_start();
            // Turn on the LED for indicating scanning.
        } break;
        case BLE_GAP_EVT_TIMEOUT:
            // Timeout for scanning is not specified, so only the connection requests can time out.
            if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
                scan_start();
                NRF_LOG_DEBUG("Connection request timed out.");
        } break;
        case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
            NRF_LOG_DEBUG("BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST.");
            // Accept parameters requested by peer.
            err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
                                        &p_gap_evt->params.conn_param_update_request.conn_params);
        } break;
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
        case BLE_GATTC_EVT_TIMEOUT:
            // Disconnect on GATT client timeout event.
            NRF_LOG_DEBUG("GATT client timeout.");
        } break;
        case BLE_GATTS_EVT_TIMEOUT:
            // Disconnect on GATT server timeout event.
            NRF_LOG_DEBUG("GATT server timeout.");
        } break;
            // No implementation needed.
 * @details Initializes the SoftDevice and the BLE event interrupts.
    uint32_t ram_start = 0;
    // Enable BLE stack.
/**@brief Function for handling database discovery events.
 * @details This function is a callback function to handle events from the database discovery module.
 *          Depending on the UUIDs that are discovered, this function forwards the events
 *          to their respective services.
 * @param[in] p_event  Pointer to the database discovery event.
static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
    ble_nus_c_on_db_disc_evt(&m_ble_nus_c[p_evt->conn_handle], p_evt);
/** @brief Database discovery initialization.
static void db_discovery_init(void)
    ret_code_t err_code = ble_db_discovery_init(db_disc_handler);
 * @details This function handles any pending log operations, then sleeps until the next event occurs.
        nrf_pwr_mgmt_run();
/** @brief Function for initializing the log module.
static void log_init(void)
/** @brief Function for initializing the timer.
static void timer_init(void)
/**@brief Application main function.
void timer_handler(nrf_timer_event_t event_type, void * p_context)
/**@brief Function for initializing the GATT module.
void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
    if (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED)
        NRF_LOG_INFO("ATT MTU exchange completed.");
        m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
        NRF_LOG_INFO("Ble NUS max data length set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
/**@brief Function for initializing the GATT library. */
void gatt_init(void)
    err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
    err_code = nrf_ble_gatt_att_mtu_central_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
/**@snippet [Handling the data received over UART] */
/**@brief  Function for initializing the UART module.
static void uart_init(void)
        .rx_pin_no    = RX_PIN_NUMBER,
        .tx_pin_no    = TX_PIN_NUMBER,
        .use_parity   = false,
        .baud_rate    = UART_BAUDRATE_BAUDRATE_Baud115200
                       UART_RX_BUF_SIZE,
                       UART_TX_BUF_SIZE,
                       uart_event_handle,
                       APP_IRQ_PRIORITY_LOWEST,
                       err_code);
/**@snippet [UART Initialization] */
/**@brief Function for initializing the sampling event of saadc(Successive approximation analog-to-digital converter)
    timer_cfg.frequency = NRF_TIMER_FREQ_31250Hz;
    /* setup m_timer for compare event every 400ms */
    uint32_t ticks = nrf_drv_timer_ms_to_ticks(&m_timer, SAADC_SAMPLE_RATE);
                                   NRF_TIMER_CC_CHANNEL2,
                                   ticks,
                                   NRF_TIMER_SHORT_COMPARE2_CLEAR_MASK,
                                   false);
    uint32_t timer_compare_event_addr = nrf_drv_timer_compare_event_address_get(&m_timer,
        NRF_TIMER_CC_CHANNEL2);
                                          timer_compare_event_addr,
                                          saadc_sample_task_addr);
/**@brief Function for enabling sampling event of saadc
/**@brief Function for handling the event of saadc sampling result
 * @param[in]   event   Event generated by analog-to-digital convert.
        nrf_saadc_value_t bat_result;
        uint16_t          batt_lvl_in_milli_volts;
        uint8_t           percentage_batt_lvl;
        char saadc_temp[30];
        static uint8_t nus_temp2[30];
        err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAMPLES_IN_BUFFER);
        bat_result = p_event->data.done.p_buffer[BAT_CHANNEL];
        batt_lvl_in_milli_volts = ADC_RESULT_IN_MILLI_VOLTS(bat_result) +
                                  DIODE_FWD_VOLT_DROP_MILLIVOLTS;
        percentage_batt_lvl = battery_level_in_percent(batt_lvl_in_milli_volts);
//        sprintf(saadc_temp, "master : %d %d %d %d", p_event->data.done.p_buffer[FLAME_CHANNEL], p_event->data.done.p_buffer[SOUND_CHANNEL], p_event->data.done.p_buffer[HUMID_CHANNEL], percentage_batt_lvl);
//        printf("%s\n", saadc_temp);
//        printf("%d\n",p_event->data.done.p_buffer[FLAME_CHANNEL]);
        sound_counter++;
        fft_generate_sound_samples(&fft_input,
                             p_event->data.done.p_buffer[SOUND_CHANNEL]);
        if(sound_counter == FFT_TEST_OUT_SAMPLES_LEN)
            fft_process(&fft_input,
            &arm_cfft_sR_f32_len256,
            &fft_output,
            FFT_TEST_OUT_SAMPLES_LEN);
            sound_counter = 0;
//            draw_fft_data(&fft_output, FFT_TEST_OUT_SAMPLES_LEN, GRAPH_WINDOW_HEIGHT);
            nrf_delay_ms(1000);
/**@brief Function for initializing the saadc
void saadc_init(void)
    nrf_drv_saadc_config_t saadc_config = NRF_DRV_SAADC_DEFAULT_CONFIG;
    saadc_config.resolution = NRF_SAADC_RESOLUTION_12BIT;
    ch_config_flame.gain = NRF_SAADC_GAIN1_4;
    ch_config_flame.reference = NRF_SAADC_REFERENCE_VDD4;
    ch_config_sound.gain = NRF_SAADC_GAIN1_4;
    ch_config_sound.reference = NRF_SAADC_REFERENCE_VDD4;
    ch_config_humid.gain = NRF_SAADC_GAIN1_4;
    ch_config_humid.reference = NRF_SAADC_REFERENCE_VDD4;
    ch_config_bat.gain = NRF_SAADC_GAIN1_4;
    err_code = nrf_drv_saadc_init(&saadc_config, saadc_callback);
    err_code = nrf_drv_saadc_channel_init(FLAME_CHANNEL, &ch_config_flame);
    err_code = nrf_drv_saadc_channel_init(SOUND_CHANNEL, &ch_config_sound);
    err_code = nrf_drv_saadc_channel_init(HUMID_CHANNEL, &ch_config_humid);
    err_code = nrf_drv_saadc_channel_init(BAT_CHANNEL, &ch_config_bat);
    err_code = nrfx_saadc_buffer_convert(m_buffer_pool[0], SAMPLES_IN_BUFFER);
    err_code = nrfx_saadc_buffer_convert(m_buffer_pool[1], SAMPLES_IN_BUFFER);
void fft_generate_sound_samples(m_fft_input_f32 * p_input,
                                 int16_t  input_data)
      p_input->sound_input[sound_counter*2] = (float)input_data*0.0001;
      printf("%lf\n", p_input->sound_input[sound_counter*2]);
      p_input->sound_input[sound_counter*2 + 1] = 0;
static void fft_generate_samples(m_fft_input_f32 * p_input,
                                 float*   input_data)
        // Real part.
      p_input->x_input[accel_counter*2] = input_data[0]-calib_offset[0];
      p_input->y_input[accel_counter*2] = input_data[1]-calib_offset[1];
      p_input->z_input[accel_counter*2] = input_data[2]-calib_offset[2];
//      printf("%lf\n", p_input[accel_counter*2]);
        // Img part.
      p_input->x_input[accel_counter*2 + 1] = 0;
      p_input->y_input[accel_counter*2 + 1] = 0;
      p_input->z_input[accel_counter*2 + 1] = 0;
 * @brief Function for processing generated sine wave samples.
 * @param[in] p_input        Pointer to input data array with complex number samples in time domain.
 * @param[in] p_input_struct Pointer to cfft instance structure describing input data.
 * @param[out] p_output      Pointer to processed data (bins) array in frequency domain.
 * @param[in] output_size    Processed data array size.
void fft_process(m_fft_input_f32 *                   p_input,
                        const arm_cfft_instance_f32 * p_input_struct,
                        m_fft_output_f32 *                   p_output,
                        uint16_t                      output_size)
    // Use CFFT module to process the data.
    arm_cfft_f32(p_input_struct, p_input->x_input, m_ifft_flag, m_do_bit_reverse);
    // Calculate the magnitude at each bin using Complex Magnitude Module function.
    arm_cmplx_mag_f32(p_input->x_input, p_output->x_output, output_size);
    arm_cfft_f32(p_input_struct, p_input->y_input, m_ifft_flag, m_do_bit_reverse);
    arm_cmplx_mag_f32(p_input->y_input, p_output->y_output, output_size);
    arm_cfft_f32(p_input_struct, p_input->z_input, m_ifft_flag, m_do_bit_reverse);
    arm_cmplx_mag_f32(p_input->z_input, p_output->z_output, output_size);
    arm_cfft_f32(p_input_struct, p_input->sound_input, m_ifft_flag, m_do_bit_reverse);
    arm_cmplx_mag_f32(p_input->sound_input, p_output->sound_output, output_size);
#ifdef FPU_INTERRUPT_MODE
 * @brief FPU Interrupt handler. Clearing exception flag at the stack.
 * Function clears exception flag in FPSCR register and at the stack. During interrupt handler
 * execution FPU registers might be copied to the stack (see lazy stacking option) and
 * it is necessary to clear data at the stack which will be recovered in the return from
 * interrupt handling.
void FPU_IRQHandler(void)
    // Prepare pointer to stack address with pushed FPSCR register.
    uint32_t * fpscr = (uint32_t * )(FPU->FPCAR + FPU_FPSCR_REG_STACK_OFF);
    // Execute FPU instruction to activate lazy stacking.
    (void)__get_FPSCR();
    // Clear flags in stacked FPSCR register.
    *fpscr = *fpscr & ~(FPU_EXCEPTION_MASK);
 * @brief Function for drawing line with given width.
 * @param[in] line_width Line width.
static void draw_line(uint16_t line_width)
    uint32_t i;
    char     line[(int)(line_width/2) + 1];
    for (i = 0; i < (int)(line_width/2); i++)
        line[i] = '-';
    line[(int)(line_width/2)] = 0;
    NRF_LOG_RAW_INFO("%s\r\n", nrf_log_push(line));
 * @brief Function for drawing line and processed data informations.
 * @param[in] input_sine_freq Input sine wave frequency.
 * @param[in] is_noisy        Flag if data is noisy.
 * @param[in] chart_width     Drawing chart height.
static void draw_fft_header(float32_t input_sine_freq, bool is_noisy)
    NRF_LOG_RAW_INFO("Input: sine %uHz, noise: %s.\r\n", (uint16_t)input_sine_freq,
           (uint32_t)((is_noisy == true) ? "yes" : "no"));
 * @brief Function for drawing ASCII data processed by FFT function.
 * @param[in] p_input_data Pointer to FFT data array.
 * @param[in] data_size    FFT array size.
 * @param[in] chart_height Drawing chart height.
void draw_fft_data(m_fft_output_f32 * p_input_data, uint16_t data_size, uint16_t chart_height)
    uint32_t  graph_y, graph_x;
    float32_t curr_drawing_val;
    float32_t curr_percent;
    float32_t max_value;
    uint32_t  max_val_index;
    char      tmp_str[data_size + 1];
    // Search FFT max value in input array.
    arm_max_f32(p_input_data->OUTPUT_PORT, data_size, &max_value, &max_val_index);
    // Draw graph. Put space if number is less than currently processed, put '|' character otherwise.
    for (graph_y = chart_height; graph_y > 0; graph_y--)
        curr_percent = ((graph_y - 1) / (chart_height * 1.f));
        curr_drawing_val = max_value * curr_percent;
        for (graph_x = 0; graph_x < (int)(data_size/2); graph_x++)
            if (p_input_data->OUTPUT_PORT[graph_x] > curr_drawing_val)
                tmp_str[graph_x] = '|';
            } else
                tmp_str[graph_x] = ' ';
        tmp_str[data_size] = 0;
        NRF_LOG_RAW_INFO("%s\r\n", NRF_LOG_PUSH(tmp_str));
        NRF_LOG_FLUSH();
    draw_line(data_size);
/**@brief Function for TWI (with transaction manager and twi_sensor) initialization.
static void twi_init(void)
    uint32_t err_code;
    const nrf_drv_twi_config_t ii_config = {
       .scl                = ARDUINO_SCL_PIN,
       .sda                = ARDUINO_SDA_PIN,
       .frequency          = NRF_DRV_TWI_FREQ_400K,
       .interrupt_priority = APP_IRQ_PRIORITY_HIGHEST,
       .clear_bus_init     = false
    err_code = nrf_twi_mngr_init(&m_nrf_twi_mngr, &ii_config);
    err_code = nrf_twi_sensor_init(&m_nrf_twi_sensor);
/**@brief Function for TWI Reset (with transaction manager and twi_sensor) reset.
static void twi_reset(void)
    uint32_t err_code;
       .clear_bus_init     = true
    nrf_twi_mngr_uninit(&m_nrf_twi_mngr);
/**@brief Function for converting decimal to 62 numtype notation.
char* dto62(int decimal)
static char hexabindecimal[20] = {0, };
static char minus_hexabindecimal[20];
int position = 0;
int minus_flag = 0;
    while (1)
        if(decimal<0)
            minus_flag=1;
            decimal=decimal*-1;
        int mod = decimal % 62;
        if (mod < 10)
            hexabindecimal[position] = 48 + mod;
        else if(mod < 36)
            hexabindecimal[position] = 65 + (mod - 10);
            hexabindecimal[position] = 97 + (mod - 36);
        decimal = decimal / 62;
        position++;
        if (decimal == 0)    break;
    reverseString(hexabindecimal);
    if(minus_flag==1)
        sprintf(minus_hexabindecimal,"-%s",hexabindecimal);
        return minus_hexabindecimal;
    return hexabindecimal;
/**@brief Function for connection with the iis2dlpc_read_reg function and nrf52840 SDK.
 * @param[out] return Should be 0.
int32_t platform_read(void *handle, uint8_t reg, uint8_t *bufp, uint16_t len)
    nrf_twi_sensor_reg_read(&m_nrf_twi_sensor, II_ADDR, reg, NULL, bufp, len);
    nrf_delay_us(500);
    NRF_LOG_FLUSH();
    return 0;
/**@brief Function for connection with the iis2dlpc_write_reg function and nrf52840 SDK.
int32_t platform_write(void *handle, uint8_t reg, uint8_t *bufp, uint16_t len)
    nrf_twi_sensor_reg_write(&m_nrf_twi_sensor, II_ADDR, reg, bufp, len);
    nrf_delay_us(500);
    NRF_LOG_FLUSH();
    return 0;
/**@brief Function for initializing iis2dlpc sensor.
 * @details This function sets states of the iis2dlpc sensor and can affect
 *          the sensitivity of the sensor.
 *          If you failed to get device ID, you can push reset button to solve the issue easily
 void platform_init(void)
    twi_init();
    dev_ctx.write_reg = platform_write;
    dev_ctx.read_reg = platform_read;
    dev_ctx.handle = NULL;
    iis2dlpc_device_id_get(&dev_ctx, &whoamI);
    while(whoamI != IIS2DLPC_ID)
        printf("\r\ndevice_id_get failed\r\n");
        twi_reset();
    iis2dlpc_reset_set(&dev_ctx, PROPERTY_ENABLE);
    do {
        iis2dlpc_reset_get(&dev_ctx, &rst);
    } while (rst);
    iis2dlpc_block_data_update_set(&dev_ctx, PROPERTY_ENABLE);
    iis2dlpc_full_scale_set(&dev_ctx, IIS2DLPC_16g);
    iis2dlpc_filter_path_set(&dev_ctx, IIS2DLPC_LPF_ON_OUT);
    iis2dlpc_filter_bandwidth_set(&dev_ctx, IIS2DLPC_ODR_DIV_20);
    iis2dlpc_power_mode_set(&dev_ctx, IIS2DLPC_HIGH_PERFORMANCE_LOW_NOISE);
    iis2dlpc_data_rate_set(&dev_ctx, IIS2DLPC_XL_ODR_1k6Hz);
    printf("\r\nall settings are completed\r\n");
void fft_calibration(void)
    static float sum_buffer[3];
    for(int calib_count = 0; calib_count < 255; calib_count++)
        uint8_t reg;
        iis2dlpc_flag_data_ready_get(&dev_ctx, &reg);
        if(reg)
            memset(data_raw_acceleration.u8bit, 0x00, 3 * sizeof(int16_t));
            iis2dlpc_acceleration_raw_get(&dev_ctx, data_raw_acceleration.u8bit);
            for(int i = 0; i < 3; i++)
                sum_buffer[i] += iis2dlpc_from_fs2_to_mg(data_raw_acceleration.i16bit[i]);
                nrf_delay_us(10);
        else  calib_count--;
    for(int j = 0; j < 3; j++)
        calib_offset[j] = sum_buffer[j]/256;
/**@brief Function for activating main function of iis2dlpc sensor.
 * @details This function takes raw data from the sensor register and transmits it to the MCU,
 *          converts the data into readable and outputs it.
 *          If the state of the sensor is not ready to get new raw data, initialize all the
 *          variables' value in this function every time. (except with current/previous_value)
 * @param[out] return can be anything.
int iirun(void)
    uint8_t reg;
    if(reg)
        acceleration_mg[0] = iis2dlpc_from_fs2_to_mg(data_raw_acceleration.i16bit[0]);
        acceleration_mg[1] = iis2dlpc_from_fs2_to_mg(data_raw_acceleration.i16bit[1]);
        acceleration_mg[2] = iis2dlpc_from_fs2_to_mg(data_raw_acceleration.i16bit[2]);
        current_value[0] = acceleration_mg[0];
        current_value[1] = acceleration_mg[1];
        current_value[2] = acceleration_mg[2];
        memcpy(difference0,dto62(current_value[0]-previous_value[0]),sizeof(dto62(current_value[0]-previous_value[0])));
        memcpy(difference1,dto62(current_value[1]-previous_value[1]),sizeof(dto62(current_value[1]-previous_value[1])));
        memcpy(difference2,dto62(current_value[2]-previous_value[2]),sizeof(dto62(current_value[2]-previous_value[2])));
        memset(m_buffer, 0, sizeof(difference0)+sizeof(difference1)+sizeof(difference2)+3);
        sprintf(m_buffer, "%s %s %s", difference0, difference1, difference2);
        accel_counter++;
        fft_generate_samples(&fft_input,
                             acceleration_mg);
        if(accel_counter == FFT_TEST_OUT_SAMPLES_LEN)
            &fft_output,
            accel_counter = 0;
            nrf_delay_ms(1000);
        NRF_LOG_FLUSH();
//        printf("               %s\n\r",m_buffer);
        memcpy(previous_value,current_value,sizeof(current_value));
        memset(m_buffer, 0x00, DIFF_SIZE*3);
        memset(difference0, 0x00, DIFF_SIZE);
        memset(difference1, 0x00, DIFF_SIZE);
        memset(difference2, 0x00, DIFF_SIZE);
    return 0;
#ifdef TIMECHECK
void time_check(void)
    if(counter == 1023)
        stop=DWT->CYCCNT;
        elapsed=stop-start;
        printf("%d\n", elapsed);
        counter = 0;
        start = DWT->CYCCNT;
    counter++;
    bool noise = false;
    float32_t sine_freq;
    // Enable FPU interrupt
    NVIC_SetPriority(FPU_IRQn, APP_IRQ_PRIORITY_LOWEST);
    NVIC_ClearPendingIRQ(FPU_IRQn);
    NVIC_EnableIRQ(FPU_IRQn);
    // Initialize.
    log_init();
    timer_init();
    uart_init();
    leds_init();
    power_management_init();
    ble_stack_init();
    gatt_init();
    db_discovery_init();
    platform_init();
    saadc_init();
    saadc_sampling_event_init();
    nus_c_init();
    ble_conn_state_init();
    scan_init();
    // Start execution.
    NRF_LOG_INFO("Multilink example started.");
//    scan_start();
    fft_calibration();
    // cycle counter setup
    #ifdef TIMECHECK
    CoreDebug->DEMCR |= 0x1000000;
    DWT->CYCCNT = 0;
    DWT->CTRL |= 0x1;
    for (;;)
        iirun();
        nrf_delay_us(10);
        idle_state_handle();
#ifndef FPU_INTERRUPT_MODE
        /* Clear FPSCR register and clear pending FPU interrupts. This code is base on
         * nRF5x_release_notes.txt in documentation folder. It is necessary part of code when
         * application using power saving mode and after handling FPU errors in polling mode.
        __set_FPSCR(__get_FPSCR() & ~(FPU_EXCEPTION_MASK));
        (void) __get_FPSCR();
Baek
