Unable to activate iBASIS SIM (I Think)
I just received the Thingy 91 this morning. I've inserted the SIM have verified it on the nRF Connect for Cloud.
I cannot proceed to the next step, as the led continues to pulse blue - so I assume not connected to the network.
I am in the UK, South West London (SW15 6BF).
I assume there is no coverage here??
What are my options? If I need a different SIM, what am I looking for?
Thanks
  • Hello ,
     The Thingy:91 is shipped with LTE-M activated on the modem. According to GSMA Deployment Map, only NB-IoT is available in the UK.
     Please try downloading the Thingy:91 Firmware pack from the download page. This file includes several pre-compiled versions of the Asset Tracker, with different network modes i.e. NB-IoT or LTE-M.
    Package Contents:
    │   CONTENTS.txt                                This file
    │   mfwnrf9160101.zip                           Modem firmware, updated through nRF Connect for Desktop Programmer app
    ├───images_dfu                                  Application images, updated over USB
    │       thingy91_at_client_v0.2.3.bin           Firmware for direct modem communication
    │       thingy91_ltem_v0.2.2.bin                Asset tracker firmware for nRF9160, LTE-M network mode
    │       thingy91_nbiot_legacy_pco_v0.2.2.bin    Asset tracker firmware for nRF9160, NB-IoT network mode, legacy PCO
    │       thingy91_nbiot_v0.2.2.bin               Asset tracker firmware for nRF9160, NB-IoT network mode
    └───images_hex                                  Application images, updated over SWD (JLINK probe / development kit)
            thingy91_at_client_v0.2.3.hex           Firmware for direct modem communication
            thingy91_ltem_v0.2.2.hex                Asset tracker firmware for nRF9160, LTE-M network mode
            thingy91_nbiot_legacy_pco_v0.2.2.hex    Asset tracker firmware for nRF9160, NB-IoT network mode, legacy PCO
            thingy91_nbiot_v0.2.2.hex               Asset tracker firmware for nRF9160, NB-IoT network mode
            thingy91_nrf52_usb_v0.2.2.hex           USB-UART serial bridge firmware for nRF52840
    Please try to program your Thingy:91 with thingy91_nbiot_v0.2.2.hex.
    Øyvind
  • Ok, so I have made some progress, but am unable to upload the .hex file - I expect I am failing to understand something. I'm on a Windows 10 PC.
    When I switch on the thingy:91 while holding in the main button, I get *two* com ports appearing (actually this happens when the main button is NOT pressed too). In my case COM29 and COM30. Not sure which port I should use, but neither of them works...
    This is what I see when I run mcumgr ..
    C:\Users\patmo>mcumgr --conntype=serial --connstring=COM29 image upload C:\Users\patmo\Downloads\thingy91_fw_v0.2.3\images_hex\thingy91_nbiot_v0.2.2.hex
     0 B / 939.08 KiB [-------------------------------------------------------------------------------------------]   0.00%Error: NMP timeout
    C:\Users\patmo>mcumgr --conntype=serial --connstring=COM30 image upload C:\Users\patmo\Downloads\thingy91_fw_v0.2.3\images_hex\thingy91_nbiot_v0.2.2.hex
     0 / 961622 [-------------------------------------------------------------------------------------------------]   0.00%Error: 3
  • First, is the Thingy:91 straight out of the box?
    Can you please try running the command from C:\Users\patmo\Downloads\thingy91_fw_v0.2.3\images_hex\. This to ensure that the path is not the issue.
    E.g. C:\Users\patmo\Downloads\thingy91_fw_v0.2.3\images_hex\>mcumgr --conntype=serial --connstring=COM29 image upload thingy91_nbiot_v0.2.2.hex
    Getting two COM ports is correct, one is for the board controller and the other for nRF9160. However, only one is correct.
  • I oversaw one detail from your last post. You're trying to load the wrong image. If you have a jlink programmer, then you can use the .hex files to update. mcumgr uses the .bin files from images_bin.
