Unable to activate iBASIS SIM (I Think)
I just received the Thingy 91 this morning. I've inserted the SIM have verified it on the nRF Connect for Cloud.
I cannot proceed to the next step, as the led continues to pulse blue - so I assume not connected to the network.
I am in the UK, South West London (SW15 6BF).
I assume there is no coverage here??
What are my options? If I need a different SIM, what am I looking for?
Thanks
  • Well, much to my surprise (and delight) I seem to have found a combination of things (SIM, Location, Firmware) which has brought the thingy91 to life here in South West London, and I can see data appearing in the nrf cloud dashboard!
    But now have questions about the data!
    1) I am not getting GPS at all .. I just see "Waiting for GPS Data". The device is outside and has been for >30 mins. It has a clear view of the sky. Anything else I need to do? Or does it not work right now. There is no GPS data showing up in the datastream in the terminal window,
    2) Air Pressure is showing up at a constant 99.9 for every reading. Presumably not correct?
    3) I can see something in the terminal ..
    Received":{
    "appId":
    "AIR_QUAL"
    "data":
    "25.1"
    "messageType":
    "DATA"
    what is that? It's not showing in the dashboard and is not selectable as a pane to show.
    Pat
  • Sounds promising. What SIM card did you use and where did you get it?
    Thanks
  • Did you remember to press the button and hold it for 10 secs?
  • Hi Pat!
    patmolloy13 said:
    he team tell me that we need to alter PLMN via the AT+COPS command, and also change the APN via the AT+CGDCONT command.
    What team is this? is this information from the network provider?
    Not know the specifics from your vendor, the settings that you issue looks correct.
    That's good to hear. Can you provide full output from the LTE Link Monitor, please? This so that I can see any indication of why the data is not correct.
    Regarding GPS signal, are you outside in the open as stated in User Guide:
    Note: GPS signals do not usually penetrate ceilings or other structures. For best GPS performance, Nordic Thingy:91Tm should be used outside in an open space, far from sources of interference and other structures that may block the signals.
  • Hi. It's a SIM card from Vodafone, but it was given to us for testing purposes in our IoT team .. I am not sure how you would get hold of one for real!
