Now that nrfutil has been ported to Python 3, I've been trying to get a DFU controller set up on a Raspberry Pi 3A running Raspbian Lite. I've built and installed the pc-ble-driver v4.1.1 as well as the Python bindings v0.13.0. I have been able to successfully use the examples that came with pc-ble-driver-py, such as the heart rate monitor, with no issues, so I know the drivers and bindings are installed correctly. An nRF52832 devkit is connected via USB (which on the Pi corresponds to the port /dev/ttyACM0) to the Pi and is running the 1M connectivity firmware. The drivers, python bindings, and connectivity firmware are all compiled for softdevice v5.1.0.
I also built and installed v6.0.0a1 of nrfutil, and set up a DFU target using another nRF52832 devkit running what is essentially a copy of the SDK15.3, softdevice s132 v6 secure bootloader. The only changes I made to that bootloader code were to add some print statements for debugging purposes, and set the MTU to 247. I checked using the nRF Connect Android app, and the DFU target device is indeed advertising correctly and is DFU-able from the app. However, when I attempt to DFU the target from the Pi instead I get this error message:
> nrfutil dfu ble -pkg /home/pi/Pylon/embedivet_firmware_package.zip -p /dev/ttyACM0 -ic NRF52 -n "DfuTarg" -mtu 247
File "/usr/local/bin/nrfutil", line 11, in <module>
load_entry_point('nrfutil==6.0.0a1', 'console_scripts', 'nrfutil')()
File "/usr/lib/python3/dist-packages/click/core.py", line 764, in __call__
return self.main(*args, **kwargs)
File "/usr/lib/python3/dist-packages/click/core.py", line 717, in main
rv = self.invoke(ctx)
File "/usr/lib/python3/dist-packages/click/core.py", line 1137, in invoke
return _process_result(sub_ctx.command.invoke(sub_ctx))
File "/usr/lib/python3/dist-packages/click/core.py", line 956, in invoke
return ctx.invoke(self.callback, **ctx.params)
File "/usr/lib/python3/dist-packages/click/core.py", line 555, in invoke
return callback(*args, **kwargs)
File "/home/pi/.local/lib/python3.7/site-packages/nrfutil-6.0.0a1-py3.7.egg/nordicsemi/__main__.py", line 1145, in ble
dfu.dfu_send_images()
File "/home/pi/.local/lib/python3.7/site-packages/nrfutil-6.0.0a1-py3.7.egg/nordicsemi/dfu/dfu.py", line 127, in dfu_send_images
self._dfu_send_image(self.manifest.application)
File "/home/pi/.local/lib/python3.7/site-packages/nrfutil-6.0.0a1-py3.7.egg/nordicsemi/dfu/dfu.py", line 100, in _dfu_send_image
self.dfu_transport.send_firmware(data)
File "/home/pi/.local/lib/python3.7/site-packages/nrfutil-6.0.0a1-py3.7.egg/nordicsemi/dfu/dfu_transport_ble.py", line 555, in send_firmware
try_to_recover()
File "/home/pi/.local/lib/python3.7/site-packages/nrfutil-6.0.0a1-py3.7.egg/nordicsemi/dfu/dfu_transport_ble.py", line 543, in try_to_recover
offset = response['offset'])
File "/home/pi/.local/lib/python3.7/site-packages/nrfutil-6.0.0a1-py3.7.egg/nordicsemi/dfu/dfu_transport_ble.py", line 632, in __stream_data
self.dfu_adapter.write_data_point(list(to_transmit))
File "/home/pi/.local/lib/python3.7/site-packages/nrfutil-6.0.0a1-py3.7.egg/nordicsemi/dfu/dfu_transport_ble.py", line 340, in write_data_point
self.adapter.write_cmd(self.conn_handle, DFUAdapter.DP_UUID, data)
File "/home/pi/.local/lib/python3.7/site-packages/pc_ble_driver_py/ble_adapter.py", line 494, in write_cmd
raise e
File "/home/pi/.local/lib/python3.7/site-packages/pc_ble_driver_py/ble_adapter.py", line 482, in write_cmd
response = self.driver.ble_gattc_write(conn_handle, write_params)
File "/home/pi/.local/lib/python3.7/site-packages/pc_ble_driver_py/ble_driver.py", line 107, in wrapper
error_code=err_code,
pc_ble_driver_py.exceptions.NordicSemiException: Failed to ble_gattc_write. Error code: NRF_ERROR_RESOURCES
Looking through other posts here on DevZone, this error is supposed to be solved by either increasing the MTU size (which is already at its maximum of 247), or by waiting until the packet queue is free. While I could certainly implement the latter in my own code, I'm hesitant about modifying someone else's code unless necessary. Thus, I first wanted to ask if there are any other possible reasons why ble_gattc_write might throw this error or any other possible fixes before I started tinkering.
Lexi
