MCP7940 drivers for nrf52840
We are working on external RTC MCP7940(i2c) interfaced with nrf52840. Please check if drivers of the same for nrf52/51 are available or any implementation of CLOCK using MCP7940 with NRF?
Regards
Vishal Aditya
Embedded Software Engineer
    I am trying to do init sequence but not able to START Clock Oscillator of MCP7940
    void init_MCP7940() {
    char registerValue = 0x00; // Holds the received register value
    char twelveHour = 0x00; // 0 = 24 Hour Clock Mode / 1 = 12 Hour Clock Mode
    char startClock = 0x01; // 0 = Start Oscillator / 1 = Stop Oscillator
    // Turn on/off: 12 hour vs. 24 hour clock
    err_code = nrf_drv_twi_tx(&m_twi,MCP7940_I2C, REG_RTCHOUR, 1);
    err_code = nrf_drv_twi_rx(&m_twi, MCP7940_I2C, registerValue, sizeof(MCP7940_I2C));
    if (twelveHour == 0x00) err_code = nrf_drv_twi_tx(&m_twi,MCP7940_I2C, REG_RTCHOUR, bitClear (registerValue, 6));
    if (twelveHour == 0x01) err_code = nrf_drv_twi_tx(&m_twi,MCP7940_I2C, REG_RTCHOUR, bitSet (registerValue, 6));
    // Turn on/off: Oscillator (starts the clock)
    err_code = nrf_drv_twi_rx(&m_twi, MCP7940_I2C, registerValue, 1);
    if (startClock == 0x00) err_code = nrf_drv_twi_tx(&m_twi,MCP7940_I2C, REG_RTCSEC, bitClear (registerValue, 7));
    if (startClock == 0x01) err_code = nrf_drv_twi_tx(&m_twi,MCP7940_I2C, REG_RTCSEC, bitSet (registerValue, 7));
  • Please attach a logic trace of the I2C lines when you run the init_MCP7940() function.
  • pls guide or let me know further which transactions traces required will update it
  • Are you calling the init_MCP7940() function at all? You seem to be writting to the same register (0xDE) over and over again. Does 0xDE correspond with REG_RTCHOUR or REG_RTCSEC?
  • Yes calling init_MCP7940()
    Below register maps:
    const uint8_t MCP7940_I2C = 0xDE;
    const uint8_t MCP7940_RTCSEC = 0x00; ///< Timekeeping, RTCSEC Register address
    const uint8_t MCP7940_RTCMIN = 0x01; ///< Timekeeping, RTCMIN Register address
    const uint8_t MCP7940_RTCHOUR = 0x02; ///< Timekeeping, RTCHOUR Register address
    const uint8_t MCP7940_RTCWKDAY = 0x03; ///< Timekeeping, RTCWKDAY Register address
    const uint8_t MCP7940_RTCDATE = 0x04; ///< Timekeeping, RTCDATE Register address
    const uint8_t MCP7940_RTCMTH = 0x05; ///< Timekeeping, RTCMTH Register address
    const uint8_t MCP7940_RTCYEAR = 0x06; ///< Timekeeping, RTCYEAR Register address
    const uint8_t MCP7940_CONTROL = 0x07; ///< Timekeeping, RTCCONTROL Register address
    const uint8_t MCP7940_OSCTRIM = 0x08; ///< Timekeeping, RTCOSCTRIM Register address
    const uint8_t MCP7940_ALM0SEC = 0x0A; ///< Alarm 0, ALM0SEC Register address
    const uint8_t MCP7940_ALM0MIN = 0x0B; ///< Alarm 0, ALM0MIN Register address
    const uint8_t MCP7940_ALM0HOUR = 0x0C; ///< Alarm 0, ALM0HOUR Register address
    const uint8_t MCP7940_ALM0WKDAY = 0x0D; ///< Alarm 0, ALM0WKDAY Register address
    const uint8_t MCP7940_ALM0DATE = 0x0E; ///< Alarm 0, ALM0DATE Register address
    const uint8_t MCP7940_ALM0MTH = 0x0F; ///< Alarm 0, ALM0MTH Register address
    const uint8_t MCP7940_ALM1SEC = 0x11; ///< Alarm 1, ALM1SEC Register address
    const uint8_t MCP7940_ALM1MIN = 0x12; ///< Alarm 1, ALM1MIN Register address
    const uint8_t MCP7940_ALM1HOUR = 0x13; ///< Alarm 1, ALM1HOUR Register address
    const uint8_t MCP7940_ALM1WKDAY = 0x14; ///< Alarm 1, ALM1WKDAY Register address
    const uint8_t MCP7940_ALM1DATE = 0x15; ///< Alarm 1, ALM1DATE Register address
    const uint8_t MCP7940_ALM1MTH = 0x16; ///< Alarm 1, ALM1MONTH Register address
    const uint8_t MCP7940_PWRDNMIN = 0x18; ///< Power-Fail, PWRDNMIN Register address
    const uint8_t MCP7940_PWRDNHOUR = 0x19; ///< Power-Fail, PWRDNHOUR Register address
    const uint8_t MCP7940_PWRDNDATE = 0x1A; ///< Power-Fail, PWDNDATE Register address
    const uint8_t MCP7940_PWRDNMTH = 0x1B; ///< Power-Fail, PWRDNMTH Register address
    const uint8_t MCP7940_PWRUPMIN = 0x1C; ///< Power-Fail, PWRUPMIN Register address
    const uint8_t MCP7940_PWRUPHOUR = 0x1D; ///< Power-Fail, PWRUPHOUR Register address
    const uint8_t MCP7940_PWRUPDATE = 0x1E; ///< Power-Fail, PWRUPDATE Register address
    const uint8_t MCP7940_PWRUPMTH = 0x1F; ///< Power-Fail, PWRUPMTH Register address
    const uint8_t MCP7940_RAM_ADDRESS = 0x20; ///< NVRAM - Start address for SRAM
    const uint8_t MCP7940_ST = 7; ///< MCP7940 register bits. RTCSEC reg
    const uint8_t MCP7940_12_24 = 6; ///< RTCHOUR, PWRDNHOUR & PWRUPHOUR
    const uint8_t MCP7940_AM_PM = 5; ///< RTCHOUR, PWRDNHOUR & PWRUPHOUR
    const uint8_t MCP7940_OSCRUN = 5; ///< RTCWKDAY register
    const uint8_t MCP7940_PWRFAIL = 4; ///< RTCWKDAY register
    const uint8_t MCP7940_VBATEN = 3; ///< RTCWKDAY register
    const uint8_t MCP7940_LPYR = 5; ///< RTCMTH register
    const uint8_t MCP7940_OUT = 7; ///< CONTROL register
    const uint8_t MCP7940_SQWEN = 6; ///< CONTROL register
    const uint8_t MCP7940_ALM1EN = 5; ///< CONTROL register
    const uint8_t MCP7940_ALM0EN = 4; ///< CONTROL register
    const uint8_t MCP7940_EXTOSC = 3; ///< CONTROL register
    const uint8_t MCP7940_CRSTRIM = 2; ///< CONTROL register
    const uint8_t MCP7940_SQWFS1 = 1; ///< CONTROL register
    const uint8_t MCP7940_SQWFS0 = 0; ///< CONTROL register
    const uint8_t MCP7940_SIGN = 7; ///< OSCTRIM register
    const uint8_t MCP7940_ALMPOL = 7; ///< ALM0WKDAY register
    const uint8_t MCP7940_ALM0IF = 3; ///< ALM0WKDAY register
    const uint8_t MCP7940_ALM1IF = 3; ///< ALM1WKDAY register
    const uint32_t SECONDS_PER_DAY = 86400; ///< 60 secs * 60 mins * 24 hours
    const uint32_t SECONDS_FROM_1970_TO_2000 = 946684800; ///< Seconds between year 1970 and 2000
    Please let me know if any traces required at any line with break-point? Also, I can send the drivers again with a private link to your INBOX it is required?
