MCP7940 drivers for nrf52840
We are working on external RTC MCP7940(i2c) interfaced with nrf52840. Please check if drivers of the same for nrf52/51 are available or any implementation of CLOCK using MCP7940 with NRF?
Regards
Vishal Aditya
Embedded Software Engineer
  • The traces still show that the slave, i.e. MCP7940 is not ACKing the read. Can you enable the analog sampling in addition to the digital sampling of the salea? That way we can see if the MCP7940 is attempting to pull eh the SDA line high or not. Also how large is sample_data?
    What does the trace from the Arduino look like? Does it try to read the same address as the one in the trace below? Have you compared the traces?
  • Sampling for 5secs:
    Please check the traces of MCP_Breakout with Arduino:
    With Arduino, MCP Works properly able to do i2c, SET & GET DATETIME
    Arduino Code:
    #include <Wire.h>
    void setup()
      Wire.begin();
      Serial.begin(115200);
      while (!Serial);             // Leonardo: wait for serial monitor
      Serial.println("\nI2C Scanner");
    void loop()
      byte error, address;
      int nDevices;
      Serial.println("Scanning...");
      nDevices = 0;
      //for(address = 1; address < 127; address++ )
      while(1)
    //SENDING 0x6F in decimal as per arduino Wire library
        Wire.beginTransmission(111);
        error = Wire.endTransmission();
        if (error == 0)
          Serial.print("I2C device found at address 0x");
          if (address<16)
            Serial.print("0");
          Serial.print(address,HEX);
          Serial.println("  !");
          nDevices++;
        else if (error==4)
          Serial.print("Unknown error at address 0x");
          if (address<16)
            Serial.print("0");
          Serial.println(address,HEX);
      if (nDevices == 0)
        Serial.println("No I2C devices found\n");
        Serial.println("done\n");
      //delay(5000);           // wait 5 seconds for next scan
    Please reply for a possible way of the solution!
  • With the Arduino you are writting to a device with address 0x6F, not reading from it. So if you want to do exactly the same with the nRF52840, then you need to replace nrf_drv_twi_rx with nrf_drv_twi_tx.
  • Please check the traces after code updates:
        twi_init();
    //    for (address = 1; address <= TWI_ADDRESSES; address++)
    				while(1)
    					//	nrf_gpio_pin_write(RED_LED,1);
            err_code = nrf_drv_twi_tx(&m_twi, 0x6F, &sample_data, sizeof(sample_data),1);
            if (err_code == NRF_SUCCESS)
                detected_device = true;
                NRF_LOG_INFO("TWI device detected at address 0x%x.\r\n", address);
    						//nrf_gpio_pin_write(RED_LED,0);
            NRF_LOG_FLUSH();
        if (!detected_device)
            NRF_LOG_INFO("No device was found.\r\n");
            NRF_LOG_FLUSH();
  • All write transactions are now followed by an ACK, which means that the MCP7940 is responding correctly. You could now try to send the I2C transaction that returns the time from the MCP7940.
