We are working on external RTC MCP7940(i2c) interfaced with nrf52840. Please check if drivers of the same for nrf52/51 are available or any implementation of CLOCK using MCP7940 with NRF?
Regards
Vishal Aditya
Embedded Software Engineer
Regards
Vishal Aditya
Yes getting 0x80
Below is the attached Arduino init sequence:
Wire.begin(); // Start I2C as master device Wire.setClock(i2cSpeed); // Set the I2C bus speed Wire.beginTransmission(MCP7940_ADDRESS); // Address the MCP7940M uint8_t errorCode = Wire.endTransmission(); // See if there's a device present if (errorCode == 0) // If we have a MCP7940M { clearRegisterBit(MCP7940_RTCHOUR, MCP7940_12_24); // Use 24 hour clock setRegisterBit(MCP7940_CONTROL, MCP7940_ALMPOL); // assert alarm low, default high _CrystalStatus = readRegisterBit(MCP7940_RTCSEC, MCP7940_ST); // Status bit from register _OscillatorStatus = readRegisterBit(MCP7940_RTCWKDAY, MCP7940_OSCRUN); // Oscillator state from register }MCP7940.h
Great, then you are good to go. You should be able to reuse the snippet I provided to configure the MCP7940. My suggestion would be to capture a trace of the Arduino Init sequence to see which values that are written to which register and then just copy paste the code snippet I provided and change the REG_RTCSEC register value and the 0x80 to match what you're seeing in the trace.
