Transmiting only slave address on TWI I2C
Hello
I am using a I2C sensor module and I need to tranmit only address to receive data back, but I dont know how.
    err_code = nrf_drv_twi_tx(&m_twi, MICS_VZ_89TE_ADDR,mics_data, sizeof(mics_data),true);
    err_code = nrf_drv_twi_tx(&m_twi, 0xE1,NULL,0,true);
     err_code = nrf_drv_twi_rx(&m_twi, MICS_VZ_89TE_ADDR,mics_data, 7);
Program crashes on line 4.
Thank you for your help.
  • HI mojoangeex,
    I do not think you can send only the address as message going out on the bus will need to contain the following:
    • Start condition
    • Stop condition
    • Read and write bits
    • ACK/NACK bits
    • Address of the Slave
    • Data frame
    Which SDK version are you using and which nRF device is it running on? Does nrf_drv_twi_tx( return an error code? If so, which? It could be that you have to point to an empty buffer rather than passing a NULL pointer.
    Best regards
    Bjørn
  • Hello
    I am running SDK 15.3 and nRF52832 DK.
    Code compiles sucessfully, but the program crashes at executing that line.
    <00> error> app: Fatal error
    00> warning> app: System reset
    I need to send message without data frame.
    On arduino there is an example:
     Wire.beginTransmission((uint8_t)_i2caddr);
        Wire.write((uint8_t)reg); //This send the command to get data
        Wire.write(0x0);
        Wire.write(0x0);
        Wire.write(0x0);
        Wire.write(0x0);
        Wire.write(0x0);
        Wire.endTransmission();
        Wire.beginTransmission(0xE1);
  • Fatal Error means that the nrf_drv_twi_tx has returned a non-zero error code and this is being caught by the APP_ERROR_CHECK call. Which return code is nrf_drv_twi_tx  returning? You should be able to see this when debugging the application. My guess it that its NRF_ERROR_INVALID_PARAM, i.e. 0x07. If that is the case then try passing an empty buffer instead of a NULL pointer.
  • Sorry for late response.
    Thank you for response.
         uint8_t dra[0] ={};
         err_code = nrf_drv_twi_tx(&m_twi, 0xE1,dra,1,false);
    Application does not crash with above code, but I2C device still does not work. I will investigate further and report when I solve it.
    Best regards.
