nRF52840 Low power mode enable for peripheral example
I am working to replace my BM70 with nRF52 series. So it has to be quick and simple solution. So, I used nRF52840 USB dongle as my slave (Peripheral Example code).
It worked great. But now every some minutes device goes to Deep sleep which we can only wake up via RESET.
I want to put device in Low power mode when not connected to master. but still broadcast all the time. So, when Master is looking for that MAC address, I can connect to it.
Please refer me if there is any Documentation or Example code in community.
I am very new to this community, So if i am posting at wrong place please help me post at the right place.
Thanks
Jay
  • HI Jigar,
    Most of the examples in our SDK will advertise for 180seconds before entering System OFF. Which example code are you using? In the simplest case its just a matter of setting the advertisement interval to zero and in some other cases you will have to restart advertising when it times out, see https://devzone.nordicsemi.com/f/nordic-q-a/54071/continuous-advertising-issue-with-hid-app/218983#218983.
    Best regards
    Bjørn
  • Hello Bjorn,
    Thanks for reply.
    I am using \examples\ble_peripheral\ble_app_uart\pca10056\s140\ses as my base line. Yes it is 180S. According to my requirement I want to have SYSTEM ON instead of SYSTEM OFF as i can't reset it remotely. Second, How can I change that to SYSTEM ON. Aslo, I would like to advertise when timer or RTC times out just for my master to pick up. How can I achieve this? Any example code will be appreciated.
    Thanks
    Jay
  • Hello Bjorn,
    I have implemented your given example and unit is advertising all the time. But It consumes same current as all the time 2mA which is very high. I have few more Questions.
    1> How do I know its Slow Advertise mode?
    2> Is there a way to have nrf goes to sleep after 180 S and it advertise every 1 minutes for x seconds? and if times out goes back to sleep.
    3> How Do I achieve maximum power saving as my application is only using UART while connected. No other GPIO needed.
    Thanks
    Jay
  • Hi Jay,
    When you call ble_advertising_start you also need to state which advertisement mode you want to use.
     Yes, you can setup a application timer that starts advertising every minute and then stops advertising after x seconds. For the timeout you can just set the APP_ADV_DURATION in main.c
     The UART should be un-initialized when it is not in use. So before you put the nRF in sleep mode you should uninitialize the UART and when you wake up and need to use it you should reinitialize it.
    Best regards
    Bjørn
    Can I uninitialized UART if there is no Event? How? I tried many ways dis not work.
    Basically, what I want is
    1> My BLE is continuous in SYSTEM ON mode. When Master connects to it then Initialize UART. does it work and then goes back to Slow Advertise mode and un initialized UART.
    Is it possible?
    Can you please advise?
    Thanks
    Jay
