Unable to compile for nrf9160_pca20035 (Thingy:91)
I have been at this for a few days now, I have had a number of compilation errors that I have had to work through and find solutions for, but I am stumped on this current error.
First a bit about my system and the development environment:
Arch Linux 5.3.10-arch-1 (System up to date)
Latest Master Zephyr SDK also install in a separate directory.
Latest Master NCS but with the Joakimtoe NRF Fork (This fork solved a whole host of problems for me, but last update was 11 months ago?)
West v0.6.3
Ninja v1.9.0
Cmake v3.15.5
GCC Arm v7 2018-Q2
ZEPHYR_TOOLCHAIN_VARIANT=gnuarmemb
ZEPHYR_SDK_INSTALL_DIR=$HOME/zephyrsdk
GNUARMEMB_TOOLCHAIN_PATH='~/.gnuarmemb'
source zephyr-env.sh using the NCS Zephyr Directory
The sample that I am trying to compile is the lte_ble_gateway sample found in the nrf9160 folder of NCS. After changing into the nrf directory I run the command:
west build -p -b nrf9160_pca20035 samples/nrf9160/lte_ble_gateway
The build successfully compiles 136 of 167 of the objects before stopping with a message of:
ERROR: command exited with status 1: /usr/bin/cmake --build /home/rex/.nRFConnectSDK/nrf/build
Where should I begin? There looks to be a number of "Warnings" that are being thrown surrounding nrf_cloud_transport.c
  • *Got the NS version to compile just fine. Loaded the HCI_UART sample to the nrf52849. and the lte_ble sample to the nrf9160. Does the thingy have a serial communication protocol over usb? Or is this connection only for Link Monitor?
    I cannot seem to find any supporting documentation around the Thingy:91 and an emulator such as Putty. I hope to dervive the hostname, and peer into the workings of the files so I can understand what is going on. The readme is written for the nrf9160 DK, so I am shooting in the dark without an emulator at the moment.
     By flashing hci_uart to the nRF52840 on the thingy:91 board, you're then dropping the USB-UART bridge that were previously loaded onto the nRF52840.
    This is the original project that is running on the nRF52840: https://github.com/NordicPlayground/fw-nrfconnect-nrf/tree/master/samples/usb/usb_uart_bridge
    We unfortunately do not have a sample that combines usb_uart_bridge + hci_uart.
    You can enable RTT logging on the nRF91 side, by setting this in your prj.conf:
    CONFIG_USE_SEGGER_RTT=y
    You should then be able to read the log output via segger rtt viewer.
    Håkon
  • We unfortunately do not have a sample that combines usb_uart_bridge + hci_uart.
    Does this mean that we will not be able to utilize the lte_ble_gateway sample on the Thingy:91? I am utilizing the Thingy:91 and the Thingy:52 in a global asset tracking proof of concept for the smart energy sector. The hope is that I can transmit sensor data from a BLE device such as the Thingy:52, to a "Gateway," such as the Thingy:91 to be aggregated in the cloud. What are my options here if I cannot utilize this sample?
    Thank you, I will give this a try!
    Kindest Regards,
    Arch
    This means that we do not have a project that also handles USB->UART, while also handling hci_uart towards the nRF9160.
    If you want to use the lte_ble_gateway + hci_uart on the thingy:91, there are a couple of gotcha's right now. These are shown (with fixes) here:
    https://devzone.nordicsemi.com/f/nordic-q-a/52689/nrf9160-lte-sensor-gateway-on-thingy-91
    Printing out debug info can still be done over RTT, but getting out the UART debug prints isn't in place when running lte_ble_gateway + hci_uart on the thingy:91.
    Håkon
