TWI read with 32 bits register address return all zeros
Hi all,
Using the nrf52832 TWI, I am trying to interract with a sensor through I2C.
On the same board, I am successfully able to exchange data with an accelerometer (8bit register adress) using I2C, but when I am trying to exchange with the other devices which uses 32 bits adress, the TWI_perform only returns 0 on the ret_buffer. Though on the oscilloscope I can see that the device is responding normally to my request.
Here's my function :
uint32_t igo_hal_i2c_buf_read(uint8_t i2c_id, uint8_t* buf, uint32_t len, uint8_t* ret_buf)
   nrf_twi_mngr_transfer_t transfers[2];
   transfers[0].p_data = buf;
   transfers[0].length = 4;
   transfers[0].operation = NRF_TWI_MNGR_WRITE_OP(i2c_id);
   transfers[0].flags = NRF_TWI_MNGR_NO_STOP;
   transfers[1].p_data = ret_buf;
   transfers[1].length = len;
   transfers[1].operation = NRF_TWI_MNGR_READ_OP(i2c_id);
   transfers[1].flags = 0;
   twi_perform(&g_twi_bus_config[CONFIG_WWR_TWI_BUS], transfers, ARRAY_SIZE(transfers))
Please note that twi_perform does return NRF_SUCCESS!
Do you have any idea why the ret_buffer is always NULL while the I2C exchange is ok as I can decode it on my oscilloscope?
Thanks in advance!
Sylvain
    • What value is the parameters that you pass to twi_perform?
    • Where do you call the function from? For example, Is it called multiple times in a loop? And are you calling it from interrupt context?
    regards
    Jared
  • Hi Jared,
    Here's the parameters I use
    - i2c_id : is my i2c_slave address
    - buf => uint8_t buf[4] = {0x12,0x34,0x56,0x78}
    - len = 4
    - ret_buf => uint8_t ret_buf[4] = {0,0,0,0}
    - CONFIG_WWR_TWI_BUS = 0 as I use the primary TWI Bus
    /**@brief Configuration of TWI buses. */
    const nrf_drv_twi_config_t g_twi_bus_config[] = {
    .frequency = (nrf_twi_frequency_t)26738688,//100k
    .interrupt_priority = TWI_DEFAULT_CONFIG_IRQ_PRIORITY,
    .clear_bus_init = TWI_DEFAULT_CONFIG_CLR_BUS_INIT,
    .hold_bus_uninit = CONFIG_TWI0_UP_IN_SYSOFF_STATE,
    .scl = mysclpin,
    .sda = mysdapin,
    I call the function during when I initializes all my components/sensors so it is not called in an interrupt callback, it is also not called multiples times
    As I was saying, on a hardware point of view it seems to work fine, the only thing is that ret_buff does not return as it should.
    Thanks for the support,
    Sylvain
  • Hi Sylvain,
    It isn't apparent from the code or your description what the cause of the issue is. I suggest using the debugger and setting a breakpoint in transaction_end_signal() in nrf_twi_mngr.c and see what the p_user_data points to when you receive data.
    regards
    Jared
  • Hi Jared,
    I have p_user_data = 0x00000001 when transaction_end_signal() is called and it switches to 0x00000000 when exiting transaction_end_signal()
    Sylvain
  • Hi Jared,
    It works now,I really don't know what I was doing wrong but it's ok now, thanks anyway for the support.
    Sylvain
