I have added 'sys_evt_dispatch' to the stack, but the callback function is still not called
Are you registering the callback through softdevice_sys_evt_handler_set() in ble_stack_init() as the other examples do it? In that case, please try to \ describe how you verify that the callback is not invoked on SD SoC events.
Hello, thank you for your reply. I used J_link online debugging. It's part of my code
static void fs_evt_handler(fs_evt_t const * const evt, fs_ret_t result)
if( (evt->id == FS_EVT_STORE) && (result == FS_SUCCESS) )
store_flag = 0;
else if( (evt->id == FS_EVT_ERASE) && (result == FS_SUCCESS) )
erase_flag = 0;
else if (result != NRF_SUCCESS)
printf("flash ERASE or STORE error\r\n");
FS_REGISTER_CFG(fs_config_t fs_config) =
.callback = fs_evt_handler,
.num_pages = 1,
.priority = 0xFE
void m_flash_write(uint32_t const * const m_datas)
fs_ret_t ret;
erase_flag=1;
ret = fs_erase(&fs_config, address_of_page(0), 1,NULL);
if (ret != FS_SUCCESS)
// NRF_LOG_INFO("fs_erase error\r\n");
printf("fs_erase error\r\n");
printf("err_code is:%d\r\n",ret);
//printf("fs_erase FS_SUCCESS\r\n");
//NRF_LOG_INFO("fs_erase FS_SUCCESS\r\n");
fs_flag=1;
while(erase_flag == 1)
{ power_manage(); }
if( fs_flag==1)
store_flag=1;
fs_flag=0;
ret = fs_store(&fs_config, fs_config.p_start_addr, m_datas,16,NULL);
// NRF_LOG_INFO("fs_store error\r\n");
//printf("fs_store error\r\n");
printf("err code is:%d\r\n",ret);
//NRF_LOG_INFO("fs_store FS_SUCCESS\r\n");
//printf("fs_store FS_SUCCESS\r\n");
while(store_flag == 1) { power_manage(); }
static void sys_evt_dispatch(uint32_t sys_evt)
fs_sys_event_handler(sys_evt);
uint32_t err_code;
nrf_clock_lf_cfg_t clock_lf_cfg = NRF_CLOCK_LFCLKSRC;
// Initialize the SoftDevice handler module.
SOFTDEVICE_HANDLER_INIT(&clock_lf_cfg, NULL);
ble_enable_params_t ble_enable_params;
err_code = softdevice_enable_get_default_config(CENTRAL_LINK_COUNT,
PERIPHERAL_LINK_COUNT,
&ble_enable_params);
//Check the ram settings against the used number of links
CHECK_RAM_START_ADDR(CENTRAL_LINK_COUNT,PERIPHERAL_LINK_COUNT);
// Enable BLE stack.
#if (NRF_SD_BLE_API_VERSION == 3)
ble_enable_params.gatt_enable_params.att_mtu = NRF_BLE_MAX_MTU_SIZE;
err_code = softdevice_enable(&ble_enable_params);
// Register with the SoftDevice handler module for BLE events.
err_code = softdevice_ble_evt_handler_set(ble_evt_dispatch);
err_code = softdevice_sys_evt_handler_set(sys_evt_dispatch);
}Hi,
Looks like you have registered the handler correctly. But the while loop you have at the end of m_flash_write() will become blocking if you're calling it from an interrupt with equal or higher priority than the Softdevice system events. Could that maybe explain the problem, or are you using m_flash_write() only in main context (not in an interrupt)? I suggest testing without the while loop if you're unsure.
Thanks for your reply. I called it in the serial interrupt event, and now I changed it to the main loop. A flag is given in the serial port interrupt. The main loop detects the flag call m_flash_write().However, there is still no callback for the softdevice system events.Do I need to change the priority of the function?
If you're using the debugger to debug the application, can you halt the CPU after the flash write to make sure the program is not stuck in a loop somewhere? Also, maybe place a breakpoint in sys_evt_dispatch() to confirm it's not being reached.
It should not be necessary to change the interrupt priorities.
