NRF52 DFU ERROR
I am setting up the DFU example based on NRF52832.
I tried with different version of SDKs (SDK13, SDK15 and SDK16) and all based on armgcc. All toolchains are the same version as it indicates in the Makefile.posix.
But all of them encounter a same problem in nrf_crypto_ecdsa_verify_hash .
I have done the following:
1. generate key: nrfutil keys generate own_test.key
2. generate public key: nrfutil keys display --key pk --format code own_test.key --out_file public_key.c
3. copy public key to bootloader:
4. git clone micro-ecc and build uECC with armgcc;
4. build bootloader;
5. erase whole device, program softdevice, bootloader;
Till here everything is fine and also DfuTarg showed up with "nRF Connect";
Then I generated a test application and generate dfu update zip file with cmd: nrfutil pkg generate --hw-version 52 --application-version 1 --application _build/nrf52832_xxaa.hex --sd-req 0x98 --key-file own_test.key dfu_update.zip
Then try to using dfu_update.zip for the dfu process. It always give the same error
err_code = nrf_crypto_ecdsa_verify_hash(sig_info_p256, &crypto_key_pk, &init_packet_hash, &crypto_sig);
nrf_crypto_ecdsa_verify_hash() returns NRF_DFU_RES_CODE_INVALID_OBJECT.
Then debug with gdb, this function called uECC_verify, the following are the public key:
(gdb) p/x *public_key@64
$4 = {0x5a, 0x9e, 0x44, 0xf, 0x27, 0x89, 0x9, 0x3d, 0x61, 0x87, 0x4c, 0xe, 0x95, 0x60, 0x0, 0xb6, 0x39, 0xc, 0xbf, 0x34, 0x57, 0xbc, 0x63, 0x40, 0x2b, 0x2e, 0x60, 0xb2,
0xfd, 0x87, 0xe0, 0xbe, 0x2c, 0x15, 0x15, 0x52, 0x2c, 0x90, 0xd4, 0x4c, 0xf1, 0xd6, 0x12, 0x9b, 0xf5, 0xb5, 0x87, 0x52, 0x4, 0x2e, 0xca, 0x8e, 0x7f, 0x7a, 0x53, 0x47,
0x95, 0x3c, 0x3b, 0x97, 0x3d, 0xf9, 0xf3, 0xe9}
Compare with generate open key:
/** @brief Public key used to verify DFU images */
__ALIGN(4) const uint8_t pk[64] =
0x5a, 0x9e, 0x44, 0x0f, 0x27, 0x89, 0x09, 0x3d, 0x61, 0x87, 0x4c, 0x0e, 0x95, 0x60, 0x00, 0xb6, 0x39, 0x0c, 0xbf, 0x34, 0x57, 0xbc, 0x63, 0x40, 0x2b, 0x2e, 0x60, 0xb2, 0xfd, 0x87, 0xe0, 0xbe, 0x2c, 0x15, 0x15, 0x52, 0x2c, 0x90, 0xd4, 0x4c, 0xf1, 0xd6, 0x12, 0x9b, 0xf5, 0xb5, 0x87, 0x52, 0x04, 0x2e, 0xca, 0x8e, 0x7f, 0x7a, 0x53, 0x47, 0x95, 0x3c, 0x3b, 0x97, 0x3d, 0xf9, 0xf3, 0xe9
That means the public key is right file.
Get all ecc parameters out and create a bare project with nrf52832. The uECC_verify is not right.
        uint8_t public[64] = {0x5a, 0x9e, 0x44, 0xf, 0x27, 0x89, 0x9, 0x3d, 0x61, 0x87, 0x4c, 0xe, 0x95,
                              0x7a, 0x53, 0x47, 0x95, 0x3c, 0x3b, 0x97, 0x3d, 0xf9, 0xf3, 0xe9};
        uint8_t hash[32] = {0x11, 0xa4, 0xc9, 0x1b, 0xdd, 0x12, 0x8b, 0x97, 0xdf, 0x27, 0xb2, 0xcc,
                            0x38, 0x92, 0x53, 0xe2, 0xdd, 0x69, 0xd4, 0x7c, 0xcb, 0xde, 0x96, 0x78,
                            0x92, 0x43, 0xc, 0x35, 0xab, 0x7e, 0x66, 0xe8};
        uint8_t sig[64] = {0xb9, 0xa, 0x63, 0xd3, 0xd6, 0xd0, 0x1f, 0x77, 0x85, 0xf0, 0x53, 0xb4, 0xa0,
                           0x25, 0x1e, 0xb0, 0x84, 0xfb, 0x48, 0x2d, 0xa0, 0x8e, 0x78, 0xca, 0x18, 0x3,
                           0xd6, 0x35, 0xd5, 0xba, 0xf3, 0xfe, 0xa8, 0xd7, 0x76, 0xf1, 0x6c, 0xba, 0x76,
                           0xd4, 0x5d, 0x75, 0x1b, 0x2, 0xf, 0x35, 0x8a, 0x13, 0x53, 0xe1, 0x3a, 0x34, 0x5d,
                           0xb, 0x46, 0x43, 0xee, 0x4b, 0xb8, 0x5e, 0x8d, 0x4d, 0x5f, 0x63};
        const struct uECC_Curve_t * curve;
        curve = uECC_secp256r1();
        int re = uECC_verify(public, hash, sizeof(hash), sig, curve);
        if (!re) {
                PRINTF("uECC_verify() failed %d\n", re);
                return 1;
        } else {
                PRINTF("uECC_verify() ok\n");
But the public key matches with public_key.c and signature are also matched with cmd:
nrfutil pkg display dfu_update.zip
|- Image count: 1
|- Image #0:
   |- Type: application
   |- Image file: nrf52832_xxaa.bin
   |- Init packet file: nrf52832_xxaa.dat
      |- op_code: INIT
      |- signature_type: ECDSA_P256_SHA256
      |- signature (little-endian): b'b90a63d3d6d01f7785f053b4a0251eb084fb482da08e78ca1803d635d5baf3fea8d776f16cba76d45d751b020f358a1353e13a345d0b4643ee4bb85e8d4d5f63'
      |- fw_version: 0x00000001 (1)
      |- hw_version 0x00000034 (52)
      |- sd_req: 0x98
      |- type: APPLICATION
      |- sd_size: 0
      |- bl_size: 0
      |- app_size: 46952
      |- hash_type: SHA256
      |- hash (little-endian): b'e52511d2c57fb1aa9f3bd1177bed871ac5f2d3a5037c51cbfff07b3f75fe1fd2'
      |- boot_validation_type: ['VALIDATE_GENERATED_CRC']
      |- boot_validation_signature (little-endian): [b'']
      |- is_debug: False
So basically it means the hash is wrong. But what are the possibilities for this?
cool^^looc
