I've used the example in examples/peripheral/gpiote to count edges of a WATCHDOG pin from a different MCU:
static nrfx_timer_t m_timer = NRFX_TIMER_INSTANCE(4);
#define AMOUNT_OF_PULSES 0x1FFFFFFF
static void watchdog_timer_init()
ret_code_t err_code;
if (!nrfx_gpiote_is_init())
err_code = nrfx_gpiote_init();
nrfx_timer_config_t timer_cfg = {NRF_TIMER_FREQ_16MHz, NRF_TIMER_MODE_COUNTER, NRF_TIMER_BIT_WIDTH_32, NRFX_TIMER_DEFAULT_CONFIG_IRQ_PRIORITY, NULL};
nrfx_timer_init(&m_timer, &timer_cfg, NULL);
nrfx_timer_compare(&m_timer, NRF_TIMER_CC_CHANNEL0, AMOUNT_OF_PULSES, false);
nrfx_gpiote_in_config_t i_config = {NRF_GPIOTE_POLARITY_TOGGLE, NRF_GPIO_PIN_NOPULL, false, true};
APP_ERROR_CHECK(nrfx_gpiote_in_init(IN_WATCHDOG_PIN, &i_config, NULL));
nrfx_gpiote_in_event_enable(IN_WATCHDOG_PIN, true);
#warning "Hack to enable SHORTS"
m_timer.p_reg->SHORTS = TIMER_SHORTS_COMPARE0_CLEAR_Enabled << TIMER_SHORTS_COMPARE0_CLEAR_Pos;
if (err_code != NRF_ERROR_MODULE_ALREADY_INITIALIZED)
nrf_ppi_channel_t ppi_channel_input;
// Setup the GPIOTE input to trigger TASKS_COUNT
nrfx_ppi_channel_alloc(&ppi_channel_input);
nrfx_ppi_channel_assign(ppi_channel_input, nrfx_gpiote_in_event_addr_get(IN_WATCHDOG_PIN), nrfx_timer_task_address_get(&m_timer, NRF_TIMER_TASK_COUNT));
nrfx_ppi_channel_enable(ppi_channel_input);
nrfx_timer_enable(&m_timer);
After starting the timer I want to periodically get the current count value with:
toggle_count = nrfx_timer_capture_get(&m_timer, NRF_TIMER_CC_CHANNEL0);
NRF_LOG_INFO("COUNT %i", toggle_count);
return toggle_count;
But it always gives me a constant value. If I use a gpiote interrupt and increment a counter in the interrupt routine it runs fine which tells me that the pin
is working fine. But somehow the counter or PPI does not work as expected. So how can I make a counter count on a PIN toggle and get and reset the
count from within the main context.
Thanks in advance.
C.W.
