how to enable 2mbps
Hello everybody.
I have two boards. I have been trying to build a communication between my boards for a time. I could not manage to have 2mbps data transfer rate.
Boards                    : nRF52832 DK(PCA10040) and nRF52840 Dongle(PCA10059)
SDK version           : 15.3.0
SoftDevice Version : 6.1.1
SoftDevices            : s132 for PCA10040 and s140 for PCA10059
Examples               : ble_app_uart and ble_app_uart_c
1-) How can I enable 2mbps data transfer rate ? I have tried various methods like sending PHY updating requests etc. But I guess I am doing something wrong. What is the correct way to do it?
2-) Let's say I managed to have 2mbps data transfer rate. How can I test it ? How to verify that I am having 2mbps data transfer rate ?
Sincerely.
  • Hi, thanks for the response.
    I have already added that code snippet into my code. As I said before, it causes FATAL_ERROR.
    static void advertising_start(void) {
      NRF_LOG_INFO("err_code: %d",err_code);
    It returns:
    <info> app: err_code: 7
    When I check the meaning of 7:
    #define NRF_ERROR_INVALID_PARAM               (NRF_ERROR_BASE_NUM + 7)  ///< Invalid Parameter
    It should not be hard that much to have 2 mbps transfer rate. I'm stuck here and I have to find a solution in 6 days.
  • Hi
    Can you upload the full advertising_init() and advertising_start() functions in your application so I can have a look?
    error code 7 does indeed mean that you have an invalid parameter somewhere, so one or more of your m_adv_params. are not set correctly. For example, what is your interval set to? This must be between 0x0020 and 0x4000 to be valid.
    Simon
  • Hi Mr.Simonr.
    I am using default SDK 15.3.0 examples. I have not changed anything from default _init() and _start() functions.
  • Sorry, I clicked "Verify Answer" button mistakenly. I do not want that the ticket be closed.
  • I decided to use the most current SDK (16.0.0). I wrote a function that works to test throughput. It works in peripheral side. Please tell me if I am doing something uncorrect.
    uint16_t data_point_to_transmit = 244;
    uint8_t data_to_transmit[244]   = {0};
    void throughput_test() {
      static int payload_per_second = 0;
      ret_code_t my_err_code = 0;
      ret_code_t err_code;
      if (isConnected)
        do
          err_code = ble_nus_data_send(&m_nus, data_to_transmit, &data_point_to_transmit, m_conn_handle);
          if(err_code != NRF_SUCCESS){
            printf("err_code: %d\r\n",err_code);
        } while ((err_code != NRF_ERROR_INVALID_STATE) && (err_code != NRF_ERROR_BUSY) && (err_code == NRF_SUCCESS));
        if (timer_flag == false)
          payload_per_second = payload_per_second + data_point_to_transmit;
          timer_flag         = false;
          printf("Throughput: %d KB - %d Bytes - %d bits per second\r\n",
              payload_per_second / 1024,
              payload_per_second,
              payload_per_second * 8);
    for (;;)
            throughput_test();
            idle_state_handle();
    I am getting an error (19). What is wrong with this ?
    Best regards.
