how to enable 2mbps
Hello everybody.
I have two boards. I have been trying to build a communication between my boards for a time. I could not manage to have 2mbps data transfer rate.
Boards                    : nRF52832 DK(PCA10040) and nRF52840 Dongle(PCA10059)
SDK version           : 15.3.0
SoftDevice Version : 6.1.1
SoftDevices            : s132 for PCA10040 and s140 for PCA10059
Examples               : ble_app_uart and ble_app_uart_c
1-) How can I enable 2mbps data transfer rate ? I have tried various methods like sending PHY updating requests etc. But I guess I am doing something wrong. What is the correct way to do it?
2-) Let's say I managed to have 2mbps data transfer rate. How can I test it ? How to verify that I am having 2mbps data transfer rate ?
Sincerely.
  • Functions you wanted to check:
        ble_advertising_init_t init;
        init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
        init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
        init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
        init.config.ble_adv_primary_phy      = BLE_GAP_PHY_2MBPS;
        init.config.ble_adv_secondary_phy    = BLE_GAP_PHY_2MBPS;
        init.config.ble_adv_extended_enabled = true;
        printf("err_code: %d\r\n",err_code); nrf_delay_ms(500);
    I am still getting error_code:7
  • Hi, in order to activate 2Mbps phy, you coud get an ordinary 1 Mbps example. Then, after a ble connection is established, in the ble event handler 'on_connect' like event you just call something like this
    m_test_params.phys.tx_phys = BLE_GAP_PHY_2MBPS;
    m_test_params.phys.rx_phys = BLE_GAP_PHY_2MBPS;
    err_code = sd_ble_gap_phy_update(m_conn_handle, &m_test_params.phys);
    And the trick is done..
    You can add BLE_GAP_EVT_PHY_UPDATE (and not BLE_GAP_EVT_PHY_UPDATE_REQUEST in this case)
    in you ble_evt_handler so to get a confirmation about the phy modification, that has been initiated when calling sd_ble_gap_phy_update
    To sum up, about using 2Mbps phy, according to my tests now it could be achieved without using a special flag set during advertisement phase, but after the ble connection is established, I just call in the ble device sd_ble_gap_phy_update. So this command notifies the host that the device wants to change phy, if the host just agrees BLE_GAP_EVT_PHY_UPDATE is generated from the device ble stack. So that device knows if what has requested has gone ok.
    The Nordic Sniffer tool shows a change in the used phy
    Maybe there is another procedure, and a device can indeed advertise its 2M capabilities,
    then BLE_GAP_EVT_PHY_UPDATE_REQUEST is generated, to finish phy modification in this case (sd_ble_gap_phy_update is used to finish the procedure in this case).
    But I couldn't find an example of that.
    Hope that Nordic can provide a very simple explanation about this point.
  • Is this thread still relevant today for setting up a 2MBPS UART Peripheral?
