DFU Update of NRF52840
I need some help updating NRF52840.
This is my first project and I have a working application which uses Softdevice 140. I would like to update it with usb-serial in the field.
4. I generated my update file with following command:
nrfutil pkg generate --hw-version 52 --key-file C:\vault\priv.pem --sd-id 0xb6 --softdevice files\s140_nrf52_6.1.1_softdevice.hex --sd-req 0x00 --application-version 0xFF --application App_s140.hex files\dfu_update.zip
5. Using this command line in order to update:
nrfutil dfu usb-serial -pkg files\dfu_update.zip -p COM20
If I erease the chip and only upload the bootloader and try to update it succeeds. If i try the update again I get following error:
Extended Error 0x07: The array of supported SoftDevices for the update does not contain the FWID of the current SoftDevice.
I think this is because SD 6.1.1 is already on the target on seconds update. How do I configure the update.zip to accept none softdevice or 6.1.1 on the target?
Can anyone help me point in the right direction?
Thanks, Andreas
  • Try setting --sd-req to 0xB6 (s140_nrf52_6.1.0).
    Simon
  • Thanks for the reply.
    If I do this the update succeeds if softdevice is already on the target but fails if if the target is blank. I want an update file where both ways (blank target and target with SD 6.1.1) is working.
  • As you suggested, I made the update file with following command:
    nrfutil pkg generate --hw-version 52 --key-file C:\vault\priv.pem --sd-id 0xb6 --softdevice files\s140_nrf52_6.1.1_softdevice.hex --application-version 0xFF --application \s140\ses\Output\Debug\Exe\App_s140.hex --sd-req "0x00,0xb6" files\dfu_update_s140.zip
    But it does still not work:
      File "C:\Users\Andreas\AppData\Roaming\Python\Scripts\nrfutil-script.py", line 11, in <module>
        load_entry_point('nrfutil==5.2.0', 'console_scripts', 'nrfutil')()
      File "C:\Users\Andreas\AppData\Roaming\Python\Python27\site-packages\click\core.py", line 764, in __call__
        return self.main(*args, **kwargs)
      File "C:\Users\Andreas\AppData\Roaming\Python\Python27\site-packages\click\core.py", line 717, in main
        rv = self.invoke(ctx)
      File "C:\Users\Andreas\AppData\Roaming\Python\Python27\site-packages\click\core.py", line 1137, in invoke
        return _process_result(sub_ctx.command.invoke(sub_ctx))
      File "C:\Users\Andreas\AppData\Roaming\Python\Python27\site-packages\click\core.py", line 956, in invoke
        return ctx.invoke(self.callback, **ctx.params)
      File "C:\Users\Andreas\AppData\Roaming\Python\Python27\site-packages\click\core.py", line 555, in invoke
        return callback(*args, **kwargs)
      File "C:\Users\Andreas\AppData\Roaming\Python\Python27\site-packages\nordicsemi\__main__.py", line 1001, in usb_serial
        timeout)
      File "C:\Users\Andreas\AppData\Roaming\Python\Python27\site-packages\nordicsemi\__main__.py", line 956, in do_serial
        dfu.dfu_send_images()
      File "C:\Users\Andreas\AppData\Roaming\Python\Python27\site-packages\nordicsemi\dfu\dfu.py", line 121, in dfu_send_images
        self._dfu_send_image(self.manifest.softdevice)
      File "C:\Users\Andreas\AppData\Roaming\Python\Python27\site-packages\nordicsemi\dfu\dfu.py", line 97, in _dfu_send_image
        self.dfu_transport.send_init_packet(data)
      File "C:\Users\Andreas\AppData\Roaming\Python\Python27\site-packages\nordicsemi\dfu\dfu_transport_serial.py", line 256, in send_init_packet
        self.__execute()
      File "C:\Users\Andreas\AppData\Roaming\Python\Python27\site-packages\nordicsemi\dfu\dfu_transport_serial.py", line 421, in __execute
        self.__get_response(DfuTransportSerial.OP_CODE['Execute'])
      File "C:\Users\Andreas\AppData\Roaming\Python\Python27\site-packages\nordicsemi\dfu\dfu_transport_serial.py", line 502, in __get_response
        raise NordicSemiException('Extended Error 0x{:02X}: {}'.format(resp[3], data))
    pc_ble_driver_py.exceptions.NordicSemiException: Extended Error 0x07: The array of supported SoftDevices for the update does not contain the FWID of the current SoftDevice.
    I first made an update with ereased target, that worked. After that I entered bootloader (with pin at startup) and tried a second update that failed.
  • I tested this myself, and I couldn't figure out how to do it using the same command.
    Is there a reason you have to use the same packet (generated with the same command) two times in a row?
    Couldn't you just use the following command on the first update:
    nrfutil pkg generate --hw-version 52 --key-file priv.pem --sd-id 0xb6 --softdevice s140_nrf52_6.1.1_softdevice.hex --sd-req 0x00 --application-version 0xFF --application ble_application1.hex dfu_update1.zip
    Then, on the second update, you use this command:
    nrfutil pkg generate --hw-version 52 --key-file priv.pem --sd-req 0xB6 --application-version 0xFF --application BLE_application2.hex dfu_update2.zip
    Could you tell me your end goal? Then it is easier to find a solution to your problem.
    However, if you need to use the same command (dfu packet) for both updates, I can look into it. I can ask the developers how to go about this.
    Simon
