examples/thread + eero border router possible stability issues
Hi. I'm using 2x nRF52840 DK's + eero pro.
I've been noticing some stability/longevity issues with examples/thread/freertos_coap_server in nRF5SDKforThreadandZigbeev3209fade31.zip
Test setup -
  • flash both dev kits with unmodified examples/thread/freertos_coap_server
  • Join the eero-thread network
    • 1 dev kit worked with a eui64 based QR code and the eero thread commissioning part of the android app
    • 1 dev kit needed me to set the network key, pan id, network name and channel before joining. The QR code didn't seem to work.
    • I was impressed that this even worked at all :)
  • ping each device from the other device
  • reboot both dev kits
  • ping each device from PC console every 1 second with 16 bytes
    • using 2 shells
Test results -
  • Pings start timing out anywhere from 0-6000 pings
  • CLI via USB/serial console is unresponsive
  • reboot recovers it
  • the eero seamlessly bridges the LAN/WAN with the thread devices
Questions -
  • The eero openthread server seems like a black box so far, could this be a thread stack version mismatch issues?
  • Are any of the nordic SDK examples/thread more stable than others?
  • Has anyone done any long term burn in / stress / stability tests? I searched the forums and didn't see much about this.
    I don't have any experience with the eero hardware. From what I can see in their homepage it's kind of a gateway with Thread support? Is it acting as a thread border router perhaps?
    If it's using Thread 1.1 border router then it should be compatible with our SDK in theory.
    Can you explain a bit more about the topology of the network and how and where are you sending the pings?
    Do you use openthread command ping <ipaddr> to send ping from one DK to the other one?
    Have you done any modifications to the example? Have you tried to debug the code to see where in the code the application hangs when the CLI window turns unresponsive?
    Marjeris
  • Thanks Marjeris
    The SDK example is not modified.
    I have not yet tried running this from a debugger. My GDB skills are rusty
    The Eero is acting as a border router. There is not much documentation. If you think the issue is with the Eero, I'm happy to try a rasberry pi.
    The network topology is
    NRF52840 (2x devkits) <> eero pro <> Windows PC
    The eero pro is providing an ipv6 bridge from windows to the thread network.
    • The thread subnet is fd3e:492c:8250:2
    • The LAN subnet is    fd3e:492c:8250:1
    NRF52 on COM3 -
    NRF52 on COM5 -
    Windows IP -
    I am able to ping from each devkit with the openthread command.
    ping from com3 to com5
    ping from com5 to com3
    Failure mode 1 - I set the interval to 5 seconds, number of pings to 65535 on each, and neither has made it past 6000
    Faulire mode 2 - sending the pings from the windows PC to the 2x NRF dev kits. Same interval and number of pings, neither makes it past 6000
    Sorry for the late reply. Have you tried to do send the same amount of pings using our border router solution using raspberry pi? Are you able to provide the results then?
    For debugging you could for example use SES debugger instead of GDB. We provide a free license for SES IDE when working with Nordic products.
    Marjeris
