Modification to UART Central example creates issues.
We made a small replacement on the event handler of the ble_central/ble_app_uart_c application, just to do a loopback to test the UART module.
Here is how the hanlder looks now:
/**@brief   Function for handling app_uart events.
* @details This function receives a single character from the app_uart module and appends it to
*          a string. The string is sent over BLE when the last character received is a
*          'new line' '\n' (hex 0x0A) or if the string reaches the maximum data length.
    static uint16_t index = 0;
    uint32_t ret_val;
    switch (p_event->evt_type)
        /**@snippet [Handling data from UART] */
        case APP_UART_DATA_READY:
            UNUSED_VARIABLE(app_uart_get(&data_array[0]));
            ret_val = app_uart_put(data_array[0]);
            NRF_LOG_INFO("Received and returned byte %d with result code %d", data_array[0], ret_val);
            index++;
            if ((data_array[index - 1] == '\n') ||
                (data_array[index - 1] == '\r') ||
                (index >= (m_ble_nus_max_data_len)))
                do
                    ret_val = ble_nus_c_string_send(&m_ble_nus_c, data_array, index);
                    if ( (ret_val != NRF_ERROR_INVALID_STATE) && (ret_val != NRF_ERROR_RESOURCES) )
                        APP_ERROR_CHECK(ret_val);
                } while (ret_val == NRF_ERROR_RESOURCES);
                index = 0;
            NRF_LOG_ERROR("Communication error occurred while handling UART.");
       case APP_UART_FIFO_ERROR:
            NRF_LOG_ERROR("Error occurred in FIFO module used by UART.");
We are not getting any answer on the serial  port,  We should receive the same bytes  sent.
What are we doing wrong?
Thanks
Jay
