Hi.
I have issue measure ADC value from battery.
setup is NRF52832, SDK 15.3.0, S332, using ANT+, BLE, GPIOTE, PPI, RTC, APPTIMER, LOW_PWM
my goal is measure periodically voltage using saadc.
process is timer interrupt --- ppi --- saadc.
I got value just one sampling. it was normal.
what I want is values of several times measured is averaged.
So I use burst and oversampling.
1. I saw document and if set oversampling is 8x means that sampled as fast as 2^8 and averaged the values? is it right?
2. 8x oversampling value is average of 256 sampled value?
3.
under below is code about saadc.
void battery_init()
ret_code_t err_code;
voltage = 0;
count = 0;
battery_cutoff_state = false;
err_code = nrf_drv_saadc_init(&saadc_config, user_battery_saadc_handler);
if(!calibration_onoff_state)
calibration_onoff_state = true;
Calibration_init(); // excute before channal init
err_code = nrf_drv_saadc_channel_init(BATTERY_SAADC_CHANNEL, &channel_config);
err_code = nrf_drv_saadc_buffer_convert(battery_adc_buffer[0], BATTERY_ADC_BUFFER_SIZE);
err_code = nrf_drv_saadc_buffer_convert(battery_adc_buffer[1], BATTERY_ADC_BUFFER_SIZE);
battery_sample_event_init();
static void battery_sample_event_init()
uint32_t timer_compare_event_addr = rtc_get_battery_event_addr();
uint32_t saadc_sample_task_addr = nrf_drv_saadc_sample_task_get();
timer_compare_event_addr,
saadc_sample_task_addr);
err_code = nrf_drv_ppi_channel_enable(m_ppi_channel);
NRF_LOG_INFO("SAADC PPI Init Done\n");
static void user_battery_saadc_handler(nrf_drv_saadc_evt_t const * p_event)
nrf_saadc_value_t *value = p_event->data.done.p_buffer; // nrf_saadc_value_t = uint16_t
switch(p_event->type)
case NRF_DRV_SAADC_EVT_CALIBRATEDONE :
NRF_LOG_INFO("SAADC Calibration Done");
CaliState = false;
case NRF_DRV_SAADC_EVT_DONE :
rtc_battery_timer_stop();
err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, BATTERY_ADC_BUFFER_SIZE);
NRF_LOG_INFO("*****ADC VALUE");
NRF_LOG_INFO("------ %d -----",p_event->data.done.p_buffer[0]);
NRF_LOG_INFO("*****");
void battery_config_value_init()
memset(&saadc_config, 0 , sizeof(saadc_config));
saadc_config.resolution = (nrf_saadc_resolution_t)NRFX_SAADC_CONFIG_RESOLUTION;
saadc_config.oversample = (nrf_saadc_oversample_t)NRFX_SAADC_CONFIG_OVERSAMPLE;
saadc_config.interrupt_priority = NRFX_SAADC_CONFIG_IRQ_PRIORITY;
saadc_config.low_power_mode = NRFX_SAADC_CONFIG_LP_MODE;
memset(&channel_config, 0 , sizeof(channel_config));
channel_config.resistor_p = NRF_SAADC_RESISTOR_DISABLED;
channel_config.resistor_n = NRF_SAADC_RESISTOR_DISABLED;
channel_config.gain = NRF_SAADC_GAIN1_6;
channel_config.reference = NRF_SAADC_REFERENCE_INTERNAL;
channel_config.acq_time = NRF_SAADC_ACQTIME_10US;
channel_config.mode = NRF_SAADC_MODE_SINGLE_ENDED;
channel_config.burst = NRF_SAADC_BURST_ENABLED;
channel_config.pin_p = (nrf_saadc_input_t)(NRF_SAADC_INPUT_AIN0);
channel_config.pin_n = NRF_SAADC_INPUT_DISABLED;
cal_value_set();
setting value is
resolution is 10bit
oversample is 8x
low power mode
burst enable
acqtime is 10us
input gpio is AIN0
buffer size 1
timer is 5s.
after first nrf_drv_saadc_sample_task_get() , NRF_DRV_SAADC_EVT_DONE is not triggerd.
after second nrf_drv_saadc_sample_task_get(), NRF_DRV_SAADC_EVT_DONE is triggered but value is strange. always minus value. number is random.
third times. the value is normal. it is what i want.
My opinion, it is related to double buffer? and not enough fulfilled?
if I add nrf_drv_saadc_sample func after saadc_buffer_convert in battery_init, it start second.
please give me advice
Thank you.
