S132 vs S140
Is there any difference between S132 and S140 ble gatt handles.?
  • Hi Siv,
    if you are referring to the GATT service that our SoftDevices automatically add to the GATT table, then it should be identical if the BLE stack configuration is identical, i.e. you add the Service Changed Characteristic.
    The GATT handles of any BLE services/characteristics/descriptors added by the application will be determined by the order they are added.
    Beste regards
    Bjørn
  • Hi bjorn,
     have added 4 characteristics in a single service in nrf52832 DK board which act as a peripheral device and nrf52840DK as a central device to discover the same services.After establishing connection data base discovery is finding all but while sending data only any two characteristics data is coming and remaining is missing.
    If reset the peripheral device then at that time it is receiving all the characteristics data,is there any reason for that why it is missing some handles while sending data?
     Ok, so the nRF52840 discovers all four characteristics, but once you enable notifications on these characteristics you're only getting notifications from two out of four characteristics? Is this correct?
    So resetting the device so that the nRF52840 Central reconnects to the nRF52832 and performs a new service discovery solves the issue? Is the NRF52832 peripheral bonded with the NRF52840 central?
  • Ok, so the nRF52840 discovers all four characteristics, but once you enable notifications on these characteristics you're only getting notifications from two out of four characteristics? Is this correct?
    YES..
    YES..
  • Ok, have you verified that the nRF52840 is writting to the correct handles, i.e. CCCD of the characteristics. Have you tried printing the  handles that are received during service discovery and then comparing these with the handles used to write to the CCCDs?
    You could also verify this by doing a on-air trace of the communication between teh nRF52832 and the NRF52840 using the nRF Sniffer, see https://www.nordicsemi.com/Software-and-Tools/Development-Tools/nRF-Sniffer-for-Bluetooth-LE.
    So the nRF52832 is bonded with the nRF52840`?
