Hello! I'm using nRF52832 with ms5803-14BA.
And I want to get this sensor's raw data form prom.
and my code is here
#include <stdio.h>
#include "boards.h"
#include "app_error.h"
#include "nrf_drv_twi.h"
#include "nrf_delay.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define TWI_INSTANCE_ID 0
#define MPU_ADDR 0x0c
#define MPU_REG_ZOUT_H 0x3F
#define MPU_PWR_MNGM1 0x6B
#define MPU_REG_WHO_AM_I 0x75
#define NORMAL_MODE 1
static volatile bool m_xfer_done = false;
static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID);
static uint8_t m_sample[16];
static uint8_t raw;
static int16_t accel_x;
static int16_t accel_y;
static int16_t accel_z;
static int i = 0;
static int a = 0;
void set_mode(void)
ret_code_t err_code;
uint8_t reg[1] = {0x1E};
err_code = nrf_drv_twi_tx(&m_twi, 0x76, reg, sizeof(reg), false);
while (m_xfer_done == false);
__STATIC_INLINE void data_handler(uint8_t m_sample[])
uint16_t coef_a = (m_sample[0]<<8) | m_sample[1];
uint16_t coef_b = (m_sample[2]<<8) | m_sample[3];
uint16_t coef_c = (m_sample[4]<<8) | m_sample[5];
uint16_t coef_d = (m_sample[6]<<8) | m_sample[7];
uint16_t coef_e = (m_sample[8]<<8) | m_sample[9];
uint16_t coef_f = (m_sample[10]<<8) | m_sample[11];
uint16_t coef_g = (m_sample[12]<<8) | m_sample[13];
uint16_t coef_h = (m_sample[14]<<8) | m_sample[15];
NRF_LOG_INFO("%d", coef_a);
NRF_LOG_INFO("%d", coef_b);
NRF_LOG_INFO("%d", coef_c);
NRF_LOG_INFO("%d", coef_d);
NRF_LOG_INFO("%d", coef_e);
NRF_LOG_INFO("%d", coef_f);
NRF_LOG_INFO("%d", coef_g);
NRF_LOG_INFO("%d", coef_h);
void twi_handler(nrf_drv_twi_evt_t const * p_event, void * p_context)
switch (p_event->type)
case NRF_DRV_TWI_EVT_DONE:
if (p_event->xfer_desc.type == NRF_DRV_TWI_XFER_RX)
// nrf_delay_ms(50);
data_handler(m_sample);
m_xfer_done = true;
void twi_init (void)
const nrf_drv_twi_config_t twi_mpu9250_config = {
.scl = ARDUINO_SCL_PIN,
.sda = ARDUINO_SDA_PIN,
.frequency = NRF_DRV_TWI_FREQ_400K,
.interrupt_priority = APP_IRQ_PRIORITY_HIGH,
.clear_bus_init = false
err_code = nrf_drv_twi_init(&m_twi, &twi_mpu9250_config, twi_handler, NULL);
nrf_drv_twi_enable(&m_twi);
static void read_sensor_data()
uint8_t reg[1] = {0xA0};
ret_code_t err_code = nrf_drv_twi_tx(&m_twi, 0x76, reg, 1, false);
//nrf_delay_ms(150);
err_code = nrf_drv_twi_rx(&m_twi, 0x76, m_sample, sizeof(m_sample));
NRF_LOG_INFO("\r\nTWI sensor example started.");
NRF_LOG_INFO("check to flush")
NRF_LOG_FLUSH();
NRF_LOG_INFO("return flash")
twi_init();
NRF_LOG_INFO("init check")
set_mode();
int sample = 0;
while (true)
nrf_delay_ms(250);
NRF_LOG_INFO("\r\n sample number : %d", ++sample);
do
__WFE();
}while (m_xfer_done == false);
read_sensor_data();
NRF_LOG_FLUSH();
I don't know why the resultant value is 65535(which is 16bit saturation)
HELP ME ㅠㅠ
