SEGGER Embedded Studio multiple instances on OSx Catalina
Hello everyone,
I already posted this on the Segger Forum, but rarely I get answers there, so I hope someone have a solution to this hellish problem!
I have been happily using SES for a few years now to work on Nordic devices (NRF52). So far I worked in a Linux environment, and I used to open a few projects at the same time to copy code fragments or to compare source codes in case of problems.
I recently switched an a MAC running OSx Catalina, and I am not able to open more than a single project....whenever I have an open project, if I try to open a new one, the latter is opened in the existing windows so there is no way for me to have 2 (or more) projects side by side.
I already tried activating the proper option in the SES options (Tools-->Options-->Environment--> Allow Multiple SEGGER....), as suggested in other threads (or as I did in Linux), but this does not seem to have any effect. I tried to put the option both to YES or NO (to check if there was maybe a mistake there), but still I can open only a single project.
This is pretty annoying especially when I have to check for project settings, included files, source code and so on, so it would be great if someone can suggest me a possible solution to this issue.
These are the details of the SES version I am running
SEGGER Embedded Studio for ARM
Release 4.30a Build 2019110506.40491
macOS x64
Thanks for the help!
Lorenzo
  • Hi again.
    I talked to SEGGER about this. They are aware of the issue and are working on a fix.
    From what I understood this issue was introduced in Catalina due to some access right management.
    The only current workaround is to either run different versions of SES or open a new instance of SES using "open -n".
    Joakim
  • Hi again.
    Joakim
  • Ok, thanks for the help. I will accept the answer of Nguyen as working solution, which for the time being is an acceptable compromise and works fine.
