Data displaying incomplete in termite from nrf52840 and nrftoolbox uart using ble_uart example
  int i;
                            char buf[42];
                        for (i = 0; i < 20; i++) {
                      snprintf(buf,42, "A%dBBCCDDEEAABBCCDDEEAABBCCDDEEAABBCCDDXX", i);
                       // puts string into buffer
                       printf("%s\n", buf);
                       // outputs so you can see it
                           uint16_t length2 = sizeof(buf);
                           err_code = ble_nus_data_send(&m_nus,buf, &length2, m_conn_handle);
A%dBBCCDDEEAABBCCDDEEAABBCCDDEEAABBCCDDXX = 40bytes
1) In Termite:
Data is complete and in sequence when until 6 only.
A0BBCCDDEEAABBCCDDEEAABBCCDDEEAABBCCDDXX
A1BBCCDDEEAABBCCDDEEAABBCCDDEEAABBCCDDXX
A2BBCCDDEEAABBCCDDEEAABBCCDDEEAABBCCDDXX
A3BBCCDDEEAABBCCDDEEAABBCCDDEEAABBCCDDXX
A4BBCCDDEEAABBCCDDEEAABBCCDDEEAABBCCDDXX
A5BBCCDDEEAABBCCDDEEAABBCCDDEEAABBCCDDXX
A6BBCCDDEEA
Data only displaying until A6BBCCDDEEA even though I tried to loop until 20. Why ??
2) In uart apps Android, I managed to receive the data incomplete like above but until 6 only. When it is above 6, the sequence is not in order and some data not received . Last data received in apps is A19BBCCDDEEAABBCCDDEEAABBCCDDEEAABBCCDDXX . How can I get the data loop for 19 if termite is not displaying it ?
  • Hi!
    Which SDK version are you using? And where in the ble_app_uart example are you adding your code?
    I will try to recreate your error at my office to see what the problem is.
    Heidi
  • Hi Heidi,
    I am using SDK_16.0.0_98a08e2. In the ble_uar_app i put the code in the uart_event_handle. This is the example code of the function
        static uint8_t index = 0;
        uint32_t       err_code;
        switch (p_event->evt_type)
            case APP_UART_DATA_READY:
                index++;
                if ((data_array[index - 1] == '\n') ||
                    (data_array[index - 1] == '\r') ||
                    (index >= m_ble_nus_max_data_len))
                    if (index > 1)
                        do
                        } while (err_code == NRF_ERROR_RESOURCES);
                          //null
                    if(index==1){
                        do
                              int i;
                           char buf[42];
                            for (i = 0; i < 3; i++) {
                           printf("%s\n", buf); // outputs so you can see it
                    index = 0;
            case APP_UART_FIFO_ERROR:
  • Unfortunately, I can't reproduce your issue. Could you just .zip your whole working directory and send it?
  • This is the link of the project in gdrive. You can test it. The sequence is not in order .drive.google.com/.../view
