nRF52840 BT Characteristic Notify only works when debugger is attached
nRF52840-DK
SDK: 15.3.0
s140
OS: Ubuntu
IDE: SES
Our application is has a notify characteristic that works when attached to the JLink debugger. I can get the notify update within nRF connect, but when the application is not attached to the debugger the notify does not get updated. The notify is attached to a switch that is configured with app_button.
The order I took:
  1. Target >> Connect J-Link
  2. Target >> Download Application
  3. Connect with BT using nRF Connect
    1. Turn on notify
    2. press switch several times
      1. Result: No value update occurs with characteristic notify on phone
  4. Target >> Attach Debugger
  5. Press Switch
    1. Result: Notify Value updates on phone
Note: additionally if loaded with the play button in SES, the notify works as expected.
One thought is that printf, or NRF_LOG_INFO is causing an issue, but that is a loose theory.
Has this behavior been seen before? I have found some posts that are similar, but not the exact same issue.
https://devzone.nordicsemi.com/f/nordic-q-a/35380/scanner-freezes-application-without-debugger-connected-on-sd-6-0-0
The solution suggested in the post works, switching SEGGER_RTT_CONFIG_DEFAULT_MODE from 2, to 1, Blocking to Trim. The notify works while attached to the debugger and not attached to the debugger.
Do you know why this behavior is the case? Is this expected?
     SEGGER_RTT_CONFIG_DEFAULT_MODE is configured for the RTT behavior if the buffer is full in sdk_config.h by setting it to the mode you want.
    The following modes are supported:
    SKIP - Do not block, output nothing.
    TRIM - Do not block, output as much as fits
    BLOCK - Wait until there is space in the buffer
    The default mode is SKIP.
    Could you also test with <nRF5_SDK>\examples\ble_peripheral\ble_app_uart? Do you see the same symptom? If not, could you compare the sdk_config.h to see the differences?
    -Amanda H.
  • My assumption is that without the debugger attached the RTT log is not emptied, therefore setting it to block will not work ever when not connected to the debugger to empty the RTT log.
    We also saw without the setting set to block we would end up dropping some logs (if we were printing a large amount of logs) This is not ideal, because the to prevent drops we block, but this breaks to code from working when not attached to a debugger. The fix would be to have multiple build and debug configurations, and that can be a hassle, then there are two builds to verify work properly.
    Our eventual work around will be to use UART, and printf. This will print out regardless of being attached or not, and to get the prints all you do is connect with putty.
    The advantages of RTT are unclear to me.
