How to set timer delay for each of data for sending from nrf52840 to android apps ?
I have followed this tutorial from this link but cannot get it work.
  do
                         int i;
                       char buf[42];
                        for (i = 0; i < 3; i++) {
                      snprintf(buf,42, "A%dBBCCDDEEAABBCCDDEEAABBCCDDEEAABBCCDDXX", i);
                      // puts string into buffer
                       printf("%s\n", buf); // outputs so you can see it
                       APP_TIMER_DEF(buf);
   app_timer_create(&buf,APP_TIMER_MODE_REPEATED, uart_event_handle);
    app_timer_start(buf, APP_TIMER_TICKS(1000), NULL);
                           uint16_t length2 = sizeof(buf);
                           err_code = ble_nus_data_send(&m_nus,buf, &length2, m_conn_handle);
                    } while (err_code == NRF_ERROR_RESOURCES);
I have 3 loop. For the first loop of sending data it will have a delay about 1s and until 2 finish. But there is no delay and it does not work.
    The timer setup you use is something you haven't found in your link, right?
    I don't know what you expect, but I suspect that you expect the app_timer_create() and app_timer_start() to delay your application for 1 sec. Unfortunately it does not. Besides, you should check the return values from the functions that return values, such as app_timer_create() and app_timer_start. You will see that these will probably not return NRF_SUCCESS, at least not the second time.
    If you want to send a notification every 1000ms, you can trigger this from the interrupt handler in the timer, which looks like the uart_event_handle. You should create a separate event handler, not share it with the uart_event_handle.
    The point of the APP_TIMER_MODE_REPEATED is that it will reset once you get the timeout event, so you should only start it once.
    Look at how the app_timer is used in the ble_app_hrs example. It uses this timer to send a new battery status notification on every timeout.
    1. Thanks bro for helping. Yes I cannot find the timer in the link. I will try to use the example.
  •  nrf_delay_ms();  Using this function solve all my problem. It sequence is in order.Both sending & receiving data get complete data.
