Hi I had a question to setup the MCP2515 driver in the zephyr project.
We have a custom board for the decawave DWM1001 module, which uses a nRF52832 chip. They have a device tree file in the zephyr project for this module, so I started with that device tree and configured it for our setup, which is
NRF52832 | MCP25625 |
P0.14 | SPI_CS |
P0.22 | SPI_MISO |
P0.31 | SPI_MOSI |
P0.30 | SPI_SCK |
P0.27 | CAN_RESET |
P0.03 | CAN_INT |
. The devicetree file looks as follows
/dts-v1/; #include <nordic/nrf52832_qfaa.dtsi> / { model = "nRF52832 Sevendof"; compatible = "decawave,dwm1001", "nordic,nrf52832-qfaa", "nordic,nrf52832"; chosen { zephyr,console = &uart0; zephyr,shell-uart = &uart0; zephyr,uart-mcumgr = &uart0; zephyr,bt-mon-uart = &uart0; zephyr,bt-c2h-uart = &uart0; zephyr,sram = &sram0; zephyr,flash = &flash0; zephyr,code-partition = &slot0_partition; }; leds { compatible = "gpio-leds"; led0_red: led_0 { gpios = <&gpio0 2 GPIO_INT_ACTIVE_LOW>; label = "Red LED 0"; }; can_reset_pin: can_reset { gpios = <&gpio0 27 GPIO_INT_ACTIVE_LOW>; label = "CAN Reset Pin"; }; }; /* These aliases are provided for compatibility with samples */ aliases { led0 = &led0_red; led0-red = &led0_red; canreset = &can_reset_pin; }; }; &adc { status = "okay"; }; &gpiote { status = "okay"; }; &gpio0 { status = "okay"; }; &uart0 { status = "okay"; compatible = "nordic,nrf-uart"; current-speed = <115200>; tx-pin = <5>; rx-pin = <11>; }; &i2c0 { compatible = "nordic,nrf-twi"; status = "okay"; sda-pin = <29>; scl-pin = <28>; }; &spi1 { compatible = "nordic,nrf-spi"; status = "okay"; sck-pin = <30>; mosi-pin = <31>; miso-pin = <22>; cs-gpios = <&gpio0 14 0>; mcp2515@0 { compatible = "microchip,mcp2515"; spi-max-frequency = <1000000>; int-gpios = <&gpio0 3 0>; /* D2 */ status = "okay"; label = "CAN_1"; reg = <0x0>; osc-freq = <16000000>; bus-speed = <125000>; sjw = <1>; prop-seg = <2>; phase-seg1 = <7>; phase-seg2 = <6>; #address-cells = <1>; #size-cells = <0>; }; }; &spi2 { compatible = "nordic,nrf-spi"; status = "okay"; sck-pin = <16>; mosi-pin = <20>; miso-pin = <18>; cs-gpios = <&gpio0 17 0>; }; &flash0 { /* * For more information, see: * http://docs.zephyrproject.org/latest/guides/dts/index.html#flash-partitions */ partitions { compatible = "fixed-partitions"; #address-cells = <1>; #size-cells = <1>; boot_partition: partition@0 { label = "mcuboot"; reg = <0x00000000 0xc000>; }; slot0_partition: partition@c000 { label = "image-0"; reg = <0x0000C000 0x32000>; }; slot1_partition: partition@3e000 { label = "image-1"; reg = <0x0003E000 0x32000>; }; scratch_partition: partition@70000 { label = "image-scratch"; reg = <0x00070000 0xa000>; }; storage_partition: partition@7a000 { label = "storage"; reg = <0x0007a000 0x00006000>; }; }; };. The project file looks as follows
CONFIG_GPIO=y CONFIG_SERIAL=n CONFIG_PRINTK=y CONFIG_RTT_CONSOLE=y # Alternate conf file required for building the CAN sample for the # MCP2515 stand alone CAN controller CONFIG_CAN=y CONFIG_CAN_INIT_PRIORITY=80 CONFIG_CAN_MCP2515_MAX_FILTER=5. The main project file I am using is the can example from zephyr. I only added the pull up for the CAN_RESET GPIO, which I can confirm works. I am not seeing any messages on the SPI pins, which make me suspect that the overlay is incorrect. I just added the mcp into the spi setup in the overlay, from a shield example, I am not to sure if it is correct and what sjw, prop-seg, phase-seg1 and phase-seg2 mean. Any help or pointers are appreciated. The program stops with debug messages "CAN: Device driver not found.".
