Adapting light switch example to nrf52840 dongle.
I have been trying to get the light switch server from the Mesh SDK examples running on a nrf52840 dongle.
The dongle does not show in the Mesh app when scanning for nodes.
All the onboard LEDs turn on, which from what I could find online means that an error has happened somewhere.
I have tested the server on a DK where it seems to run fine. I can connect to it from the Mesh app.
I have verified the dongle by running the blinky and ble_app_blinky example projects, These seem to work fine.
I have used the following links to guide me through the process:
https://devzone.nordicsemi.com/nordic/short-range-guides/b/getting-started/posts/nrf52840-dongle-programming-tutorial
https://devzone.nordicsemi.com/f/nordic-q-a/46656/problem-in-setting-nrf-52840-dongle-as-proxy-server-for-light-switch-example
So in short:
1) Changed the preprocessor definition to BOARD_PCA10059.
2) Added the code from Bjorn to simple_hal.c.
3) Build the project in segger.
4) Programmed the dongle with the resulting hex + a softdevice.
I am using:
Mesh SDK 3.2.0
nRF5 SDK 15.3.0
nRF Connect 3.3.0
nRF Mesh app 2.1.0
I have tried the following softdevices:
s140 6.0.0
s140 6.1.0
s140 6.1.1
Please do let me know if I need to provide any extra information.
    Following everything from the nRF52840 Dongle Tutorial should generally lead to a working application, so it is hard to tell what may be missing.
    The best way to figure out what happens is to connect the Dongle to a programmer, either using a 10 pin Tag Connect cable or soldering wires directly on the Dongle. Not having a debugger connected severely limits the debugging capabilities. From your description it sounds like you get an assert and end up in the fault handler. From a debug session you should easily get file and line number.
    By the way, have you tested the project that Bjørn provided in that other DevZone thread, on the Dongle?
    Terje
    I am pretty new at it but also trying to do the exact same thing, the only difference I see is that Bjorn used mesh SDK v3.1.0 which goes with nRF5 SDK 15.2.0 this might solve the problem. (The soft device would be 6.1.0)
     As I can see that you were able to compile the program and got the hex file, can u please guide me where did you  Change the preprocessor definition to BOARD_PCA10059?? and you simply Added the code from Bjorn to simple_hal.c or replaced it completely?
