integrating the NUS_service into ble_beacon
hello,
I am trying to integrating ble_nus_init( ), inside ble_beacon_app, receiving through NUS_service and transmitting through beacon,
but program is stuck inside ble_advertising() initialization, because both are differently initialization method,
so my question is how to used ble_advertising_start( ) in ble_app_beacon application.
Thanks
  • You will have to either use the ble_advertising module (wrapper around the softdevice api) or the softdevice api directly. I don't have any other suggestion that to study the examples for either, and choose the one you want. If you support bonding then using the ble_advertising module is preferred due to whitelist etc, else you may use the softdevice api directly yes.
  • i used NUS_init() service  ble_uart_app  through NUS_handler through i collecting the data, tgis application i try to integrating inside ble_beacon_app program. through beacon i wanted to transmit as ibeacon format data, what ever the data receiving by NUS_handler inside NUS_initialization().
