No "Execute Command" after "Calculate CRC Response
I'm implementing the device side of the DFU-protocol (v16) (Control Point & Packet) using the nFR Connect Mobile as DFU Controller.
In the app I select Application as file type, then my .bin-file and as init packet I select the blinky_s110_v7_1_0_ext_init.dat (16 B just as a dummy file to test with).
My problem is that everything works fine up to the point where the controller recieves the "Calculate CRC" response.
After this nothing happens - I expect to get the "Execute Command."
The log from nRF Connect Mobile is as below where the last line is the response from my device sending the response to the "Calculate CRC Request".
Any ideas?
V    10:57:30.766    [DFU] DFU service started
V    10:57:30.766    [DFU] Opening file...
I    10:57:31.076    [DFU] Firmware file opened successfully
V    10:57:31.077    [DFU] Connecting to DFU target...
D    10:57:31.078    [DFU] gatt = device.connectGatt(autoConnect = false)
I    10:57:31.111    [DFU] Connected to 24:0A:C4:10:03:3E
D    10:57:31.113    [DFU] wait(1600)
V    10:57:32.713    [DFU] Discovering services...
D    10:57:32.713    [DFU] gatt.discoverServices()
I    10:57:32.738    [DFU] Services discovered
V    10:57:32.742    [DFU] Reading Service Changed CCCD value...
D    10:57:32.743    [DFU] gatt.readDescriptor(00002902-0000-1000-8000-00805f9b34fb)
I    10:57:32.788    [DFU] Read Response received from descr.00002a05-0000-1000-8000-00805f9b34fb, value (0x): 00-00
V    10:57:32.789    [DFU] Enabling indications for 00002a05-0000-1000-8000-00805f9b34fb
D    10:57:32.789    [DFU] gatt.setCharacteristicNotification(00002a05-0000-1000-8000-00805f9b34fb, true)
D    10:57:32.791    [DFU] gatt.writeDescriptor(00002902-0000-1000-8000-00805f9b34fb, value=0x02-00)
I    10:57:32.846    [DFU] Data written to descr.00002a05-0000-1000-8000-00805f9b34fb, value (0x): 02-00
V    10:57:32.846    [DFU] Indications enabled for 00002a05-0000-1000-8000-00805f9b34fb
A    10:57:32.846    [DFU] Service Changed indications enabled
D    10:57:32.869    [DFU] wait(1000)
V    10:57:33.854    [DFU] Requesting new MTU...
D    10:57:33.854    [DFU] gatt.requestMtu(517)
I    10:57:33.957    [DFU] MTU changed to: 517
V    10:57:33.958    [DFU] Enabling notifications for 8ec90001-f315-4f60-9fb8-838830daea50
D    10:57:33.958    [DFU] gatt.setCharacteristicNotification(8ec90001-f315-4f60-9fb8-838830daea50, true)
D    10:57:33.961    [DFU] gatt.writeDescriptor(00002902-0000-1000-8000-00805f9b34fb, value=0x01-00)
I    10:57:34.104    [DFU] Data written to descr.8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 01-00
V    10:57:34.105    [DFU] Notifications enabled for 8ec90001-f315-4f60-9fb8-838830daea50
A    10:57:34.105    [DFU] Notifications enabled
D    10:57:34.105    [DFU] wait(1000)
V    10:57:35.106    [DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
D    10:57:35.106    [DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
I    10:57:35.185    [DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-06-01-14-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
I    10:57:35.186    [DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-06-01-14-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
A    10:57:35.187    [DFU] Command object info received (Max size = 20, Offset = 0, CRC = 00000000)
V    10:57:35.187    [DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
D    10:57:35.187    [DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
I    10:57:35.277    [DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-02-01-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
I    10:57:35.278    [DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-02-01-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
A    10:57:35.278    [DFU] Packet Receipt Notif disabled (Op Code = 2, Value = 0)
V    10:57:35.278    [DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
D    10:57:35.278    [DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
I    10:57:35.366    [DFU] Notification received from 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-01-01-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
I    10:57:35.367    [DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-01-01-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
A    10:57:35.367    [DFU] Command object created
V    10:57:35.372    [DFU] Writing to characteristic 8ec90002-f315-4f60-9fb8-838830daea50
D    10:57:35.372    [DFU] gatt.writeCharacteristic(8ec90002-f315-4f60-9fb8-838830daea50)
I    10:57:35.376    [DFU] Data written to 8ec90002-f315-4f60-9fb8-838830daea50, value (0x): FF-FF-FF-FF-FF-FF-FF-FF-02-00-4F-00-5A-00-B2-63
A    10:57:35.377    [DFU] Command object sent (CRC = 61066AB5)
V    10:57:35.377    [DFU] Writing to characteristic 8ec90001-f315-4f60-9fb8-838830daea50
D    10:57:35.377    [DFU] gatt.writeCharacteristic(8ec90001-f315-4f60-9fb8-838830daea50)
I    10:57:35.516    [DFU] Data written to 8ec90001-f315-4f60-9fb8-838830daea50, value (0x): 60-03-01-10-00-00-00-B5-6A-06-61
