Dear,
I am using THINGY:91
I am trying to read the data from BME680 sensor:
1. config: ( i used conf file from asset_tracking)
# Sensors CONFIG_SENSOR=n CONFIG_BATTERY_MONITOR=y CONFIG_ACCEL_USE_EXTERNAL=y CONFIG_ACCEL_DEV_NAME="ADXL362" CONFIG_ADXL362=n CONFIG_ADXL362_TRIGGER_OWN_THREAD=n CONFIG_ADXL362_ABS_REF_MODE=1 CONFIG_ADXL362_ACTIVITY_THRESHOLD=800 CONFIG_ADXL362_INACTIVITY_THRESHOLD=800 CONFIG_ADXL362_INTERRUPT_MODE=1 CONFIG_ENV_USE_EXTERNAL=y CONFIG_ENV_DEV_NAME="BME680" CONFIG_ENVIRONMENT_DATA_SEND_INTERVAL=10 CONFIG_USE_BME680_BSEC=n CONFIG_BME680=y CONFIG_SPI_NRFX_SPIM_MISO_NO_PULL=y
and, get the temperature:
env_sensor_data_t env_data_m; if (env_sensors_get_temperature(&env_data_m, NULL) == 0) { sprintf(tmp_tmp,"%.1f",env_data_m.value); printk("fTemp: %s \r\n",tmp_tmp); }
It works, but I found a funny thing:
(USB cable is connecting from THINGY:91 to my laptop to adapt outputs, and it will charge for the battery)
1. The temperatures when the THINGY:91 has and does NOT have the battery are a total difference
with battery | without battery
31 (C) >< 24 (C)
The battery is 59(%) and of course, it is charging
I tried to move the THINGY:91 far away from the battery, the same result.
I tried to remove the connect THINGY and laptop ( STOP charging for battery), the value of temperatures will send to my webserver : 24 (C) ( after 10mn stable)
I am confusing: the temperature is measured on the battery or of the environment?
Thanks.,
BR,
Hoang Nguyen
