with custom 128bit uuid custom uuid shows in advertising packet, but dfu service always shows base uuid
we use custom 128bit uuid service and dfu,bas services
when setting uuid as custom 128 bit uuid in advertising_init function, it's base uuid is always based on dfu.
what is the proper way to set advertising packet's base uuid?
here are some our code pieces.in main.c
static ble_uuid_t m_adv_uuids[] = {{BLE_CUSTOM_UUID,BLE_UUID_TYPE_VENDOR_BEGIN}};
in services_init() function
// add bas service
// add hid service
// add dfu service
// add custom 128 bit uuid's service
in advertising_init() function
init.srdata,uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0])
init,srdata.uuids_complete.p_uuids = m_adv_uuids
in custom.h
#define BLE_CUSTOM_UUID 0x8F23
the custom_uuid's base uuid is 175f8f23-a570-49bd-9627-815a6a27de2a
when the adding dfu service in services_init function is removed, then we can get the custom uuid in advertising packet,
but with dfu service we get wrong uuid which is based on dfu services' base uuid
  • I believe that the \SDKversion\examples\ble_peripheral\ble_app_blinky show this?
    I think the real problem here is that you are not using the correct uuid_type, because when you add vendor specific 128-bit base UUID's you need to be calling e.g. something like:
    err_code = sd_ble_uuid_vs_add(&base_uuid, &p_lbs->uuid_type);
    The uuid_type value will increment +1 for each call, and it will start at BLE_UUID_TYPE_VENDOR_BEGIN. However in your case the first is already used by DFU, so I expect in your case you must use:
    static ble_uuid_t m_adv_uuids[] = {{BLE_CUSTOM_UUID,BLE_UUID_TYPE_VENDOR_BEGIN+1}};
    and/or better something like
    static ble_uuid_t m_adv_uuids[] = {{BLE_CUSTOM_UUID,p_lbs->uuid_type}};
