Bonding with FDS and DFU sometimes fail
Hi
I am using nRF52DK, SDK 15.0, SD 6.0.0, multiperipheral based example with secure bootloader, FDS (7 FDS_VIRTUAL_PAGES). Uploading new software works (not tested thorougly).
Project building with SES, then flashing with a script:
SET family= NRF52
SET application= C:\repo\pikflometr\multiperipheral\pca10040\s132\ses\Output\Release\Exe\ble_app_multiperipheral_pca10040_s132.hex
SET application-version= 1
SET soft_device= C:\repo\pikflometr\lib\wszystkoCzegoPotrzebujesz\s132_nrf52_6.0.0_softdevice.hex
SET bootloader= C:\repo\pikflometr\secure_bootloader\pca10040_ble\ses\Output\Release\Exe\secure_bootloader_ble_s132_pca10040.hex
SET bootloader-version= 1
SET bl-settings-version= 1
SET settings= settings_1.hex
SET dfu_client= dfu_client_1.hex
SET nrfutil_location= C:\repo\pikflometr\lib
cd %nrfutil_location%
nrfjprog.exe --family %family% --program %soft_device% --chiperase --verify
nrfutil settings generate --family %family% --application %application% --application-version %application-version% --bootloader-version %bootloader-version% --bl-settings-version %bl-settings-version% %settings%
mergehex -m %application% %settings% -o %dfu_client%
nrfjprog.exe --family %family% --program %dfu_client% --verify
nrfjprog.exe --reset --family %family% --program %bootloader% --verify
then F5 to begin debugging with SES.
Sometimes (maybe 15% of times) when I try to pair (using master Androd device) I get:
<error> app: ERROR 2 [NRF_ERROR_SOFTDEVICE_NOT_ENABLED] at C:\repo\pikflometr\multiperipheral\main.c:1808 PC at: 0x00033AA7
which is from PM_EVT_ERROR_UNEXPECTED case
static void pm_evt_handler(pm_evt_t const * p_evt)
    ret_code_t err_code;
    switch(p_evt->evt_id)
        case PM_EVT_ERROR_UNEXPECTED:
        NRF_LOG_RAW_INFO("PM_EVT_ERROR_UNEXPECTED \n");
            // Assert.
            APP_ERROR_CHECK(p_evt->params.error_unexpected.error);
It tells me that NRF_ERROR_SOFTDEVICE_NOT_ENABLED  which is silly because I have already connected with an advertising device, so BLE stack is up and running.
After some digging I have found out that peer_data_delete_process() calls send_unexpected_error()
So it looks like sometimes the FDS module does not initialize.
I added some logs and here is what I got after booting:
FAILING CASE:
<info> app: __________________start
<info> app: ~~ ZMIANA NAZWY (na v1) W: gap_params_init
<info> app: Setting vector table to bootloader: 0x00078000
<info> app: Setting vector table to main app: 0x00026000
<info> app: zostaje domyslny adv_name
<error> app: bzdurne wartosci ts:0, cnt:0
<info> app: nie ma w ogole pomiarow offline, bo secret_word to: 26DB1 wobec 0xAAAAAAAA
<info> app: epoch 0
<info> app: battery_meas handler rusza
<info> app: reset_reason: 0x00000004.
WORKING CASE:
.......fds..FDS_EVT_INIT
.......fds..FDS_EVT_WRITE
.......fds..FDS_EVT_UPDATE
.......fds..FDS_EVT_DEL_RECORD
<info> app: epoch 0
<info> app: reset_reason: 0x00000001.
So all the difference is the FDS event logs don't appear occassionaly.
The logs that makes difference between failing and working case are in peer_data_storage.c:
static void fds_evt_handler(fds_evt_t const * const p_fds_evt)
    pm_evt_t pds_evt =
        .peer_id = file_id_to_peer_id(p_fds_evt->write.file_id)
    switch (p_fds_evt->id)
        case FDS_EVT_INIT:
            NRF_LOG_RAW_INFO(".......fds..FDS_EVT_INIT\n");
        case FDS_EVT_WRITE:
            NRF_LOG_RAW_INFO(".......fds..FDS_EVT_WRITE\n");
        case FDS_EVT_UPDATE:
            NRF_LOG_RAW_INFO(".......fds..FDS_EVT_UPDATE\n");
        case FDS_EVT_DEL_RECORD:
            NRF_LOG_RAW_INFO(".......fds..FDS_EVT_DEL_RECORD\n");
Furthermore I have added those logs to observe the state of flash memory:
     NRF_LOG_INFO("pages_available %d open_records %d valid_records %d",
                   stat.pages_available,stat.open_records,stat.valid_records);
     NRF_LOG_INFO("dirty_records %d words_reserved %d words_used %d",
                  stat.dirty_records,stat.words_reserved,stat.words_used);
     NRF_LOG_INFO("largest_contig %d freeable_words %d corruption %d",
                  stat.largest_contig,stat.freeable_words,stat.corruption);
And here is the output (called after booting before trying to pair):
FAILING CASE:
<info> app: pages_available 0 open_records 0 valid_records 0
<info> app: dirty_records 0 words_reserved 0 words_used 0
<info> app: largest_contig 0 freeable_words 0 corruption 0
WORKING CASE:
<info> app: pages_available 7 open_records 0 valid_records 0
<info> app: dirty_records 0 words_reserved 0 words_used 12
<info> app: largest_contig 1022 freeable_words 0 corruption 0
What more info do you need to guide me to solve this?
Thanks
    I agree that it looks to be a problem with the FDS initialization. Have you tried to reserve the 7 flash pages in the bootloader so the can't get overwritten during DFU(Memory layout)? FDS may fail to free the pages aftewards if not.
  • Hi
    Thank you for response.
    If you are talking about DFU_APP_DATA_RESERVED then yes, I have reserved it.
    I shouldn't have any negative effect but I changed if from 7 to 8 -both on app side and bootloader side. Now there is
        #define FDS_VIRTUAL_PAGES 8
    in application project
    and
        #define DFU_APP_DATA_RESERVED               (CODE_PAGE_SIZE * 8)
    in bootloader project.
    The situation with not-initializing the FDS still happens occassionally, but resetting the board with RESET button does the job and with the next boot-up the FDS works.
    I thought there may be some kind of misconfiguration with the FDS or DFU. Right after (successfull) flashing and booting the fds_stat() shows:
     0> <info> app: pages_available 8 open_records 0 valid_records 0
     0> <info> app: dirty_records 0 words_reserved 0 words_used 14
     0> <info> app: largest_contig 1022 freeable_words 0 corruption 0
    after bonding with one device it shows:
     0> <info> app: pages_available 8 open_records 0 valid_records 3
     0> <info> app: dirty_records 0 words_reserved 0 words_used 52
    then I prepared .zip package. New app differs with TWO bytes, "v2" instead of "v1" in log content and "board-v2" instead of "board-v1" in #define DEVICE_NAME - just so I know the new software is up and running.
    SET family= NRF52
    SET application-version=2
    SET hardware-version= 52
    SET sd-req= 0xA8
    SET private_key= C:\repo\pikflometr\lib\\private_key.pem
    SET nrfutil_location= C:\repo\pikflometr\lib\
    SET zipfile_name= p6-2.zip
    nrfutil pkg generate --application %application% --application-version %application-version% --hw-version %hardware-version% --sd-req %sd-req% --key-file %private_key% %zipfile_name%
    after bluetooth DFU OTA sometimes I see:
    <info> app: pages_available 8 open_records 0 valid_records 4
    <info> app: dirty_records 3 words_reserved 0 words_used 82
    <info> app: largest_contig 1022 freeable_words 26 corruption 0
    or sometimes
    <info> app: dirty_records 2 words_reserved 0 words_used 78
    <info> app: largest_contig 1022 freeable_words 22 corruption 0
    Is it desired behaviour that number of words_used is bigger after the update? So do valid_records number?
    I made no writes to the flash memory. Just the:
    programming -> fds_stat() -> bonding -> fds_stat() ->  update -> fds_stat()
    Yes, I meant DFU_APP_DATA_RESERVED and it should be either be equal or larger than the FDS_VIRTUAL_PAGES number defined by the main app. However, the fact that you can recover through a reset indicates that the problem is something else.
    It looks like none of the FDS events are coming through in the failing case. Is the return value from pm_init() passed to the APP_ERROR_CHECK() macro in your code?
    CCCD (notifications/indications configuration) are stored to flash by the peer manager so the client configuration can be retained across connections.  That may explain why the FDS stat is not always the same. E.g., if the phone disables indications on the buttonless characteristic, then enables it when it starts the DFU.
    I understand that CCCDs are stored in flash memory so it may change, but only when I change them, right? In my scenario I did not enabled nor disabled any indications/notifications. Just click bond and click DFU.
    As for return value from pm_init() - yes, its return value is passed to error checking. Moreover I print it over debug terminal:
    static void peer_manager_init(bool erase_bonds)
        switch(PEER_MANAGER_SETTING)
            case NO_PAIRING_NO_BONDING:
                BOND = false;        MITM = false;        LESC = 0;        KEYPRESS = 0;
                IO_CAPS = BLE_GAP_IO_CAPS_NONE;        OOB = false;        MIN_KEY_SIZE = 0;        MAX_KEY_SIZE = 0;
                K_OWN_ENC = 0;        K_OWN_ID = 0;        K_PEER_ENC = 0;        K_PEER_INC = 0;
            case PAIRING_NO_BONDING:
                IO_CAPS = BLE_GAP_IO_CAPS_NONE;        OOB = false;        MIN_KEY_SIZE = 7;        MAX_KEY_SIZE = 16;
            case JUST_WORKS_BONDING:
                BOND = true;        MITM = false;        LESC = 0;        KEYPRESS = 0;
                K_OWN_ENC = 1;        K_OWN_ID = 1;        K_PEER_ENC = 1;        K_PEER_INC = 1;
            case PASSKEY_BONDING_DISPLAY:
                BOND = true;        MITM = true;        LESC = 0;        KEYPRESS = 0;
                IO_CAPS = BLE_GAP_IO_CAPS_DISPLAY_ONLY;        OOB = false;        MIN_KEY_SIZE = 7;        MAX_KEY_SIZE = 16;
        err_code = pm_init();
        APP_ERROR_CHECK(err_code); NRF_LOG_INFO("pm_init() return status :%d", err_code);
        if (erase_bonds)
            pm_peers_delete();
            NRF_LOG_INFO("bonds deleted");
    Here is the output:
    <info> app: pm_init() return status :0
    <info> app: epoch 0
    <info> app: adc handler rusza
    SPRAWDZENIE
    So the return value is 0, despite the FDS is not initialized properly (0 pages instead of 8).
    Yes, the phone shouldn't change the configuration automatically.  It could be related to gscm_local_database_has_changed() or pm_peer_rank_*() if they're being used in your code.
    I notice that reset reason is 0x4 when it fails, and 0x1 when it works in the logs you've posted. Is it like that every time?
