How can I connect the web socket of lte modem to amazone mqtt endpoint?
Hi Devzone!
I'm using 'nRF52840' as an edge device, and this device is going to continuously check the surrounding environment and send the value to mqtt broker of aws through lte modem. Every task is complete without lte connection and now I have a problem trying to open web sockets using at command to connect to mqtt broker.
First of all, the modem which I use is called 'lm5' of 'm2net' company. This model supports at command and allows tcp connection via web socket. But what I can use as a parameter is ip address and port, and I don't know what to write in this ip address. All I know is that mqtt's endpoint URL address and tcp port '443'.
Secondly, if the lte modem is connected to the mqtt server via webSockets, how should the device subscribe to and publish a specific topic? Is there any good example of or relating to library?
Finally, I want to know about the whole system. Does this mean that the device requires a library that subscribes to and publish the topic for mqtt with authentication, and also requires a web socket connection with the aws mqtt broker on the lte modem? Or is it not necessary to set up separately on the modem because end points and ports are defined in the device library?
Thank you for reading the long article.
Baek
  • Hi.
    First, we have a cellular IoT chip (the nRF9160), that can act as a serial modem and has an example on how to connect to AWS.
    If that is not an option, we also support MQTT in our nRF5 SDK (for the nRF52 series).
    The nRF5 SDK has a MQTT client that you can use to connect to AWS. The iot component let you implement your own transport layer, by implementing and defining the struct and functions declared in components/iot/socket/common/transport_if.h.
    I believe AWS also has a C library you could incorporate in your project that does the same.
    Regarding your specific questions:
    To convert a hostname/URL to an IP address, you should do a DNS query. Beware that AWS uses load-balancing, and therefore change IP address frequently. You therefore have to do a new DNS query for each time you want to connect to AWS.
     See our MQTT client.
     I am not quite shure what you mean here. For MQTT, you need a TLS connection to the MQTT broker. The messages that is sent over that connection will include what topic it belongs to, etc. You would typically have a library to handle the protocol specific things, and provide a simple mechanism for sending and reciving messages, without having to care about exactly how the TCP packet should look. A such library is typically called an MQTT client.
    Best reagrds,
    Didrik
  • Hi Didrik
    Thank you for detailed answers!!
    At the AWS guide, I found the URL for websocket protocol is wss://<endpoint>.iot.<region>.amazonaws.com/mqtt. But, when I did nslookup for this it couldn't find the DNS for it. So, I did nslookup for <endpoint>.iot.<region>.amazonaws.com and I found 6 IPv4 address and 3 IPv6 address. But, How can I check which is for mqtt?
    Is this supported by MQTT library? Then does it mean that I don't need to do TLS connection setting from LTE modem with AT command? Sorry to bother you.. How is TLS connection established? When I publish message to topic, will the message have information of TLS connection automatically if I set the TLS connection at the MQTT library?
    Again, Thank you.
    Baek
  • Would it be the solution?
    For example, in nordic's mqtt library, there are mqtt_transport_connect(), mqtt_transport_write(), mqtt_transport_read(), mqtt_transport_disconnect().
    and Do I need to revise those function to send UART message to lte modem to run AT command?
    Like, in case of mqtt_transport_write() -> AT+CISEND()
  • but If above solution is right way, In what order should I input the message, and how aws can parse this message? Is there any syntax of this?? because, in this library, the message includes topic, payload, message id, tls info such things..
  • Sorry I found AT command related to MQTT.
    There are the command about ssl things, topic sub, pub and connect to broker.
    But, I still need to implement the glue layer by implement those command under mqtt_transport_write() etc. right?
  • Hi, and sorry for the late reply.
     If there are AT commands for using MQTT, you can use them instead of our MQTT library as the modem has it's own MQTT client.
    Didrik
