SAADC nrf52832
hello, I have two questions for SAADC of nrf52832 when we use nrf52832 SAADC for voltage measurement.
The AIN0 is connected to the pin to be measured(the voltage is about 1.5V, use SE mode, so the negative
input will be shorted to ground internally ), the output of SAADC is 850(the result beating frequently between 850 to 856).
my SAADC config is bellow:
NRF_SAADC->CH[channel].CONFIG = ((SAADC_CH_CONFIG_RESN_Bypass << SAADC_CH_CONFIG_RESN_Pos)|
(SAADC_CH_CONFIG_RESP_Bypass << SAADC_CH_CONFIG_RESP_Pos)|
(SAADC_CH_CONFIG_GAIN_Gain1_3<< SAADC_CH_CONFIG_GAIN_Pos)|
(SAADC_CH_CONFIG_REFSEL_Internal<<SAADC_CH_CONFIG_REFSEL_Pos)|
(SAADC_CH_CONFIG_TACQ_10us<< SAADC_CH_CONFIG_TACQ_Pos)|
(SAADC_CH_CONFIG_MODE_SE<<SAADC_CH_CONFIG_MODE_Pos) );
NRF_SAADC->CH[channel].PSELP = SAADC_CH_PSELP_PSELP_AnalogInput0;
NRF_SAADC->CH[channel].PSELN = SAADC_CH_PSELP_PSELP_NC;
NRF_SAADC->RESULT.MAXCNT = 1;
NRF_SAADC->RESOLUTION = SAADC_RESOLUTION_VAL_10bit;
NRF_SAADC->OVERSAMPLE = SAADC_OVERSAMPLE_OVERSAMPLE_Bypass;
NRF_SAADC->ENABLE = (SAADC_ENABLE_ENABLE_Enabled << SAADC_ENABLE_ENABLE_Pos);
NRF_SAADC->INTENSET = SAADC_INTENSET_END_Msk;
then read the result:
NRF_SAADC->TASKS_START = 1;
NRF_SAADC->TASKS_SAMPLE = 1;
uint32_t saadc_timeout = 100000;
while ((NRF_SAADC->EVENTS_END == 0U)&& (saadc_timeout > 0))
saadc_timeout--;
NRF_SAADC->EVENTS_END = 0;
NRF_SAADC->RESULT.PTR = (uint32_t)saadc_value_data;
My question is :
1) RESULT = [V(P) – V(N) ] * GAIN/REFERENCE * 2(RESOLUTION - m)
RESULT = 850/1024 = 0.83
[V(P) – V(N) ] * GAIN/REFERENCE * 2(RESOLUTION - m) = 1.5V * Gain1_3 / (0.6V * 2) = 0.417, it's not equall to RESULT, why?
2) The SAADC output is beating frequently between 850 to 856(for example 851,853,855...), is it normal?
    1. The statement "m=0 if CONFIG.MODE=SE, or m=1 if CONFIG.MODE=Diff" in the PS is wrong, and should be reversed, ie. m=1 if MODE == SE.
      I tested with both SE and DIFF, and SE outputs a result that is double that of DIFF, which makes sense as DIFF has a range of +/- 0.6V over 1024 codes whereas SE only uses +0.6V over 1024 bits.
    2. There is a fair amount of Gain error in the ADC core, there's also Integral and Differential Non-Linearity. See Electrical specification for details.
      Other possible error sources is noise in the signal, or too short acquisition time with regards to the source impedance(see Acquisition time).
    You should also wait for the STARTED event before you trigger the SAMPLE task, otherwise, you might get a hardfault if the EasyDMA controller tries to write data to address 0x00000000, the default value of RESULT.PTR. This might happen if a conversion is completed before the SAADC has updated the RAM address of the EasyDMA controller.
  • thank you, I have add an wait for the STARTED event before you trigger the SAMPLE task.
    and I also tried to extend the acquisition time, but the SAADC output is beating frequently between 850 to 856 too.
    there is another question:
    we have used nrf51822 before, the environment is the same as nrf52832, but the ADC output seems more stable than nrf52832, it only switch between 851 and 852,why nrf52832 seems not as good as nrf51822?
  • What's your source impedance?
    I suggest you use the lowest acquisition time possible and turn on oversampling.
    The nRF51 does not have the same ADC as the nRF52 at all.
  • the source resistance is 100kOhm, so we use 10us acquisition time
    we tested both Voltage source and battery(I am not sure about the source impedance), the result is beating frequently the same.
    I just tested using SAADC_OVERSAMPLE_OVERSAMPLE_Over2x, the result now beating frequently from 642 to 695, when at the same environment and configuration setting SAADC_OVERSAMPLE_OVERSAMPLE_Bypass get the result from 694 - 698, is that normal?
  • "I just tested using SAADC_OVERSAMPLE_OVERSAMPLE_Over2x, the result now beating frequently from 642 to 695,"
    That's not what I expect at all. Hmm, what kind of battery are you using?
    I suggest you power the VBAT-ON net from a benchtop PSU to remove any issue related to an under-specced battery.
    "when at the same environment and configuration setting SAADC_OVERSAMPLE_OVERSAMPLE_Bypass get the result from 694 - 698"
    In a previous test, you reported 850 - 856, what has changed since then?
