NRF52832-QFAB-R loader script
I modified the ble_app_blinky example to work on our board (removed leds and buttons) and modified the board pca10040.h
the new application worked on the devkit but not in our board.
As the chip in the devkit is not the same used on our board (NRF52832-QFAB-R) is there any thing that I need to modify? like ble_app_blinky_gcc_nrf52.ld?
Thanks.
  • Is it the error handler that catches something?
    Edvin said:
    Have you tried to monitor the log?
  • I want to add a new result:
    As I said I used to program the custom device with https://www.silabs.com/documents/public/user-guides/efm32lg-stk3600-ug.pdf
    We used to use that device to program the NRF51 in our old hardware version and to program the main MCU, and we never had such issue.
    I tested today to program our custom board using NRF52 DK by making the connection described here: https://devzone.nordicsemi.com/f/nordic-q-a/14058/external-programming-using-nrf52-dk
    Using the NRF52DK resolve the problem. have you any Idea of the difference between the two board? As the production lines are already equipped with the silabs devkit it will be easier to make just a firmware changes than adding new equipment !
    I am not familiar with the DK that you link to, what it uses, and how it works.
    I see that you uploaded a picture from the callstack, where the reset handler was called. Can you show me the rest of the callstack as well? Maybe it can give some hints as to what went wrong.
    BR,
    Edvin
  • Below all calls:
    //////////////////////////////////////1/////////////////////////////////////////
    void bsp_board_init(uint32_t init_flags)
        #if defined(BOARDS_WITH_USB_DFU_TRIGGER) && defined(BOARD_PCA10059)
        (void) nrf_dfu_trigger_usb_init();
        #if LEDS_NUMBER > 0
        if (init_flags & BSP_INIT_LEDS)
             0000 030C   07C2   LSL     R2, R0, #31
             0000 030E   D407   BMI     #+0x0E ;<nrf_gpio_cfg> ;320
            bsp_board_leds_init();
    //////////////////////////////////////2/////////////////////////////////////////
    __STATIC_INLINE void nrf_gpio_cfg_output(uint32_t pin_number)
        nrf_gpio_cfg(
             0000 0320   F04F 43A0  MOV     R3, #0x50000000
             0000 0324   2103       MOVS    R1, #3
            pin_number,
            NRF_GPIO_PIN_DIR_OUTPUT,
            NRF_GPIO_PIN_INPUT_DISCONNECT,
            NRF_GPIO_PIN_NOPULL,
            NRF_GPIO_PIN_S0S1,
            NRF_GPIO_PIN_NOSENSE);
    ///////////////////////////////////////3////////////////////////////////////////
    __STATIC_INLINE void nrf_gpio_port_out_clear(NRF_GPIO_Type * p_reg, uint32_t clr_mask)
        p_reg->OUTCLR = clr_mask;
             0000 0326   F44F 3280  MOV     R2, #0x10000
             0000 032E   F8C3 250C  STR     R2, [R3, #+0x50C]
             0000 0332   E7ED       B       #-0x26 ;<bsp_board_init>+0x4 ;310
    ///////////////////////////////////////4////////////////////////////////////////
    __STATIC_INLINE void nrf_gpio_cfg(
        uint32_t             pin_number,
        nrf_gpio_pin_dir_t   dir,
        nrf_gpio_pin_input_t input,
        nrf_gpio_pin_pull_t  pull,
        nrf_gpio_pin_drive_t drive,
        nrf_gpio_pin_sense_t sense)
        NRF_GPIO_Type * reg = nrf_gpio_pin_port_decode(&pin_number);
        reg->PIN_CNF[pin_number] = ((uint32_t)dir << GPIO_PIN_CNF_DIR_Pos)
                                   | ((uint32_t)input << GPIO_PIN_CNF_INPUT_Pos)
                                   | ((uint32_t)pull << GPIO_PIN_CNF_PULL_Pos)
                                   | ((uint32_t)drive << GPIO_PIN_CNF_DRIVE_Pos)
                                   | ((uint32_t)sense << GPIO_PIN_CNF_SENSE_Pos);
    ////////////////////////////////////////5///////////////////////////////////////
     * bsp_board_init is located at 0x30C but when executing the branch command
     * it go to Reset_Handler
    /////////////////////////////////////////6//////////////////////////////////////
    Reset_Handler:
    /* Loop to copy data from read only memory to RAM.
     * The ranges of copy from/to are specified by following symbols:
     *      __etext: LMA of start of the section to copy from. Usually end of text
     *      __data_start__: VMA of start of the section to copy to.
     *      __bss_start__: VMA of end of the section to copy to. Normally __data_end__ is used, but by using __bss_start__
     *                    the user can add their own initialized data section before BSS section with the INTERT AFTER command.
     * All addresses must be aligned to 4 bytes boundary.
        ldr r1, =__etext
        ldr r2, =__data_start__
        ldr r3, =__bss_start__
