After developing two application, one for emitting extended advertising and other one for scanning this kind of advertising on nRF52840 DK (Github repository here: MOTAM-Scanner), the next step is to scan extended advertisements from an Android smartphone.
To achieve this, I decided to use Pixel 3a, that supports extended advertising according to the nRF Connect app:
Here is the application I developed for start advertising, although in this case, taking into account that the Pixel 3a doesn't support PHY_CODED, I changed this for PHY_1MBPS:
Intelligent Traffic Light Github Repository
Currently, this project uses:
nRF5 SDK version 15.3.0
S140 SoftDevice v6.1.1 API
Since nRF Connect Android app doesn't support extended advertising scanner, I used this example scanner from Android's Github: Android Connectivity-samples Github. I modified this application in order to see all the advertisements, but I can't see the ones that come from my nRF52840.
So, my first question is:
Do you know any Android application for scanning extended advertisements?
And if you don't know...
How can I scan the content of Bluetooth 5 extended advertisements from Android?
Thank you.
