Log show only the first few lines
I have a custom board with nrf52832 mcu and I use FreeRTOS with SDK 16.
I tried the logging feature with NRF_LOG_XX() functions, but only the first few lines showed after booting.
I tested it from a task:
while(true){
  //SEGGER_RTT_WriteString(0, "Hello World!\n");
  //SEGGER_RTT_printf(0, "variable value: %d\n", test++);
  TEST_LED_TOGGLE(TLED_1);
  NRF_LOG_INFO("info\r\n");
  //NRF_LOG_ERROR("error\r\n");
  //NRF_LOG_FLUSH();
  vTaskDelay(pdMS_TO_TICKS(1000));
I tried with UART and with RTT (not the same time)  with the same result.
If I used the SEGGER_RTT_printf() function, it worked well, I saw all of the logs.
The relevant parts in sdkconfig:
#define NRF_LOG_ENABLED 1
#define NRF_LOG_DEFAULT_LEVEL 4
UART:
#define NRF_LOG_BACKEND_UART_ENABLED 1
#define NRF_LOG_BACKEND_UART_TX_PIN 9
#define NRF_LOG_BACKEND_UART_BAUDRATE 30801920
#define NRF_LOG_BACKEND_UART_TEMP_BUFFER_SIZE 64
RTT:
#define NRF_LOG_BACKEND_RTT_ENABLED 1
#define NRF_LOG_BACKEND_RTT_TEMP_BUFFER_SIZE 64
#define NRF_LOG_BACKEND_RTT_TX_RETRY_DELAY_MS 1
#define NRF_LOG_BACKEND_RTT_TX_RETRY_CNT 3
#define SEGGER_RTT_CONFIG_BUFFER_SIZE_UP 256
#define SEGGER_RTT_CONFIG_MAX_NUM_UP_BUFFERS 2
#define SEGGER_RTT_CONFIG_BUFFER_SIZE_DOWN 16
#define SEGGER_RTT_CONFIG_MAX_NUM_DOWN_BUFFERS 2
#define SEGGER_RTT_CONFIG_DEFAULT_MODE 1
The log FreeRTOS task:
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "app_error.h"
#include "nrf_sdh_freertos.h"
#include "nrf_gpio.h"
#include "FreeRTOS.h"
#include "task.h"
#include "semphr.h"
#include "main.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#if NRF_LOG_ENABLED
#define LOG_STACK_SIZE (configMINIMAL_STACK_SIZE + 200)
#define LOG_TASK_PRIORITY ( tskIDLE_PRIORITY + 1 )
* @name Task data
TaskHandle_t logTaskHandle = NULL;
// The TCB and stack of the task.
static StaticTask_t xLogTaskBuffer;
static StackType_t xStackLog[ LOG_STACK_SIZE ];
/**@brief Thread for handling the logger.
* @details This thread is responsible for processing log entries if logs are deferred.
* Thread flushes all log entries and suspends. It is resumed by idle task hook.
* @param[in] arg Pointer used for passing some arbitrary information (context) from the
* osThreadCreate() call to the thread.
static void logTask(void * arg)
UNUSED_PARAMETER(arg);
while (1)
NRF_LOG_FLUSH();
vTaskSuspend(NULL); // Suspend myself
uint32_t getTimeStamp(void)
return xTaskGetTickCount() << 5;
void logInit(void)
// log TX pin: sdk_config: NRF_LOG_BACKEND_UART_TX_PIN
// log GND
/*nrf_gpio_pin_clear(10);
nrf_gpio_cfg_output(10);*/
ret_code_t err_code = NRF_LOG_INIT(getTimeStamp);
// create thread
logTaskHandle = xTaskCreateStatic(
logTask, /* Function that implements the task. */
"log", /* Text name for the task. */
LOG_STACK_SIZE, /* Number of indexes in the xStack array. */
NULL, /* Parameter passed into the task. */
LOG_TASK_PRIORITY,/* Priority at which the task is created. */
xStackLog, /* Array to use as the task's stack. */
&xLogTaskBuffer ); /* Variable to hold the task's data structure. */
NRF_LOG_INFO("Restart");
/**@brief A function which is hooked to idle task.
* @note Idle hook must be enabled in FreeRTOS configuration (configUSE_IDLE_HOOK).
void vApplicationIdleHook( void )
#if NRF_LOG_ENABLED
vTaskResume(logTaskHandle);
  • There is a lot of processing in NRF_LOG_XX that eventually leads to Segger_RTT_Printf . If Segger_printf is working fine and NRF_LOG_XX is not, then there must be either a bug in NRF or you have not selected enough buffer. In any case it would be easier if you attach the compilable project for me to try it out.
  • I think, the problem was that the log buffer (SEGGER_RTT_CONFIG_BUFFER_SIZE_UP) was too small and the NRF_LOG_ALLOW_OVERFLOW was 1.
    If I change the NRF_LOG_ALLOW_OVERFLOW to zero, it worked fine. Of course some logs missed, but  the logging not stop.
    But if the NRF_LOG_ALLOW_OVERFLOW  is 1 and the log buffer overflowed, no more log received.
    The documentation said:
    "If set then oldest logs are overwritten. Otherwise a marker is injected informing about overflow."
    I think it works the other way around.
    And not mentioned to the logging will stop after overflow. And I can't see the marker when the buffers overflowed.
  • Sorry for the late response.
    Are you sure that if NRF_LOG_ALLOW_OVERFLOW  is set to 1, only logging stops but the application is still running? I am guessing that there is a stack overflow and the core might have hardfaulted?
  • There was not hardfault. The other functionalities worked well regardless of the value of the  NRF_LOG_ALLOW_OVERFLOW.
  • Thanks for letting us know this. I will create a ticket to let the developers know about this.
    For your reference, the internal thread to fix it is NRFFOETT-2407
