Improvement to bootloader-library
If you look at the secure bootloader example the  nrf_bootloader_init(...)  never return to main scope unless an error occurs.
Everything is handled inside this function even jump to application by calling nrf_bootloader_app_start().
I suggest that the call to  nrf_bootloader_app_start() is replaced by return NRF_SUCCESS, allowing the developer to implement some user specific code like using the gprepret-registers to signal information back to application
ret_code_t nrf_bootloader_init(nrf_dfu_observer_t observer)
       m_flash_write_done = false;
        nrf_dfu_settings_backup(flash_write_callback);
        ASSERT(m_flash_write_done);
        return NRF_SUCCESS;
        //nrf_bootloader_app_start();
        //NRF_LOG_ERROR("Unreachable");
    // Should not be reached.
    return NRF_ERROR_INTERNAL;
/**@brief Function for application main entry. */
    ret_val = nrf_bootloader_init(dfu_observer);
    APP_ERROR_CHECK(ret_val);
    //user specifice code like
    nrf_power_gpregret_set( ... );
    nrf_power_gpregret2_set( ... );
    // Either there was no DFU functionality enabled in this project or the DFU module detected
    // no ongoing DFU operation and found a valid main application.
    // Boot the main application.
    // Should never be reached.
    NRF_LOG_INFO("After main");
