I am new here and I have some issues with Zigbee reporting implementation.
I am trying to implement a reporting feature between a coordinator and an end device, which is a temperature sensor, but I can't parse the reporting response. I pass all the commissioning, binding steps, then I send the reporting request from the coordinator and I can see from the sniffer the reporting request and the related end device's response.
From what i have understand reading the instructions on your infocenter, the reporting makes a part from ZCL layer, so the response should be captured first from the ZCL handler.
I think that the problem consists in the ZCL handler initialization. i used the ZB_AF_SET_ENDPOINT_HANDLER(ENDPOINT, handler), but it can't be activated when i receive the reporting message.
From the sinffer i can see the same reporting packets (req and resp) from my system and the CLI example, same data.
I followed the command line example for the coordinator implementation, the multisensor example for the end device implementation and wireshark for sniffing using your nrf_sniffer software on the usb dongle.
//Report request
static zb_void_t reporting_attr(zb_uint8_t param)
zb_buf_t * p_buf = ZB_GET_OUT_BUF();
configure_reporting_req_t req;
zb_uint8_t * p_cmd_ptr;
zb_ret_t zb_err_code; if (!p_buf)
printf("Failed to execute command (buf alloc failed)\n");
return;
} req.profile_id = ZB_AF_HA_PROFILE_ID;
req.cluster_id = ZB_ZCL_CLUSTER_ID_TEMP_MEASUREMENT; req.attr_id = ZB_ZCL_ATTR_TEMP_MEASUREMENT_VALUE_ID;
req.attr_type = ZB_ZCL_ATTR_TYPE_S16; req.interval_min = ZIGBEE_CONFIGURE_REPORT_DEFAULT_MIN_INTERVAL;
req.interval_max = ZIGBEE_CONFIGURE_REPORT_DEFAULT_MAX_INTERVAL; //ZB_MEMCPY(req.remote_node.addr_long,m_attr_table[item].remote_ieee_addr,sizeof(zb_ieee_addr_t));
req.remote_node.addr_short = m_attr_table[item].remote_node.addr_short;
req.remote_addr_mode = ZB_APS_ADDR_MODE_16_ENDP_PRESENT;
req.remote_ep = m_attr_table[item].remote_ep; ZB_ZCL_GENERAL_INIT_CONFIGURE_REPORTING_SRV_REQ(p_buf,
p_cmd_ptr,
ZB_ZCL_ENABLE_DEFAULT_RESPONSE); ZB_ZCL_GENERAL_ADD_SEND_REPORT_CONFIGURE_REPORTING_REQ(p_cmd_ptr,
req.attr_id, req.attr_type, req.interval_min, req.interval_max,
ZIGBEE_CONFIGURE_REPORT_DEFAULT_VALUE_CHANGE); ZB_ZCL_GENERAL_SEND_CONFIGURE_REPORTING_REQ(p_buf, p_cmd_ptr,
req.remote_node, req.remote_addr_mode, req.remote_ep, HA_TEMP_SENSOR_ENDPOINT,
req.profile_id, req.cluster_id, NULL);
// ZCL Callback
static zb_uint8_t zcl_device_cb(zb_uint8_t param)
zb_buf_t * p_zcl_cmd_buf = (zb_buf_t *)ZB_BUF_FROM_REF(param);
zb_zcl_parsed_hdr_t * p_cmd_info = ZB_GET_BUF_PARAM(p_zcl_cmd_buf, zb_zcl_parsed_hdr_t);
tsn_ctx_t * p_tsn_ctx; if (p_cmd_info->cmd_id == ZB_ZCL_CMD_REPORT_ATTRIB)
attr_update(p_cmd_info, param);
ZB_FREE_BUF_BY_REF(param);
else if (p_cmd_info->cmd_id == ZB_ZCL_CMD_CONFIG_REPORT_RESP)
{ reporting_attr_cb(p_tsn_ctx, param);
} /* All callbacks should either reuse or free passed buffers. If param == 0, the buffer is invalid (not passed) */
if (param)
return 1;
/* Register callback for handling ZCL commands. */
ZB_AF_SET_ENDPOINT_HANDLER(HA_TEMP_SENSOR_ENDPOINT, zcl_device_cb);
